Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-12-2010, 13:36 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 680512 Status: Offline Thanks Meter: 2 | C5212 Flashing with OneNAND I will have the Samsung C5212 in my hands in two days, and I already downloaded SGT-C5212 OneNAND Downloader v0.5 Lite for PNX6512 and the latest firmware C5212XEIK1. I've flashed many Samsung handsets before, usually by using the included data cable, and I know I can do the same with this one, but all I see in online forums is a problem with flashing the slave's IMEI. If this problem occurs, will I be able to fix it without using UST pro or any other tool? Correct me if I'm wrong, but If I tick the "Don't auto NAND format" box in the downloader, won't both IMEI's remain intact? (When I flashed D900i in the past, if you didn't tick that box, the IMEI reset to zeroes) If that method doesn't work, will I be able to use EEPROM files with this downloader to fix it? Here is the downloader interface, with the settings I'm going to use: [img]http://3.bp.********.com/_5-0uC-56dek/S-qfVb-d3eI/AAAAAAAAAA4/_PjtU9jDxyw/s1600/C5212+Flasher.jpg[/img] Thank you! |
The Following 2 Users Say Thank You to Porgos For This Useful Post: |
05-15-2010, 15:16 | #2 (permalink) |
Member: 680512 Status: Offline Thanks Meter: 2 | Anyone knows if the settings I suggested will work? I don't want to flash it unless I know the second SIM will work ok, without its IMEI getting tampered with. Also, this mobile has some notable bugs, such as the voice clarity feature flunctuates the voice volume... |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
