Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
09-02-2013, 17:35 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: KANCHEEPURAM, VANDAVASI
Member: 1618492 Status: Offline Sonork: 100.1619678 QQ 2483222717 Thanks Meter: 488 | Dead boot repair done Samsung I9103 sucessfully wit free tool Tested by me Dead boot repair done Samsung I9103 sucessfully wit free tool Tested by me This tool can fix it by USB cable only so no need to disassemble the phone and no need to use JTAG boxes even. To use this tool you need to enter APX mode ( Volume Up key + Home Key ) then connect USB cable to Phone. After you repair the dead phone it will be into Download Mode, So you can Flash it with Original Firmware. update the driver manually goto device manager/APX drive right click nd show d path 2 update. driver is included n d zip file. Then run the GT-I9103 windows batch file there type 1 and press enter nd it vil start d process. after finish it vil go into odin download mode .use odin nd update using original stock firmware below given. Download: Samsung I9103 Galaxy R Dead Phone Fix by USB Firmware Download Odin Download Pit file Download |
The Following 7 Users Say Thank You to ...::: SERVICETEAM89 :::... For This Useful Post: |
10-10-2013, 14:49 | #3 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1330910 Status: Offline Sonork: nginx Thanks Meter: 1 | ( Volume Up key + Home Key ) @SERVICETEAM89 sir,for some other types of mobile phones by USB Fix Dead Phone there is not?? or maybe can use that file as above .. Last edited by Dbubblegumz; 10-10-2013 at 14:58. |
12-02-2013, 12:20 | #6 (permalink) |
Junior Member Join Date: Feb 2008
Member: 711315 Status: Offline Thanks Meter: 4 | Hi, I downloaded all the files required, install the driver manually and run the batch file. It was fine in the beginning but it just got stuck at the "Formatting partition 2 BCT please wait... " Then after a while, the program will just close like nothing happened. What is the cause of this? I did everything correctly but still got stuck. [IMG][/IMG] |
01-10-2014, 06:12 | #15 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: panadura
Member: 1183779 Status: Offline Sonork: 123 Thanks Meter: 10 | I need samsung GT-I9103 Full firmware files... Quote:
