Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-06-2013, 09:58 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: India Age: 39
Member: 804115 Status: Offline Sonork: 1658994 Thanks Meter: 13 | Experts please help n7100 |
05-06-2013, 10:42 | #3 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Quote:
Download Firmware:- Hotfile.com: One click file hosting: N7100XXALIE_ODDALI9_INU_India_Android_4.1.1.zip Flash With Correct Downloader & Your Done.. Regards, | |
05-06-2013, 10:43 | #4 (permalink) | |
Download Firmware:- Hotfile.com: One click file hosting: N7100XXALIE_ODDALI9_INU_India_Android_4.1.1.zip Firmware Update Steps: - From the folder you extracted Odin program to double click on Odin.exe. - Check these Options: Re.Partition, Auto Reboot, and F.Reset Time. - Click PIT button and select the *.pit file. - Now you have to select the Firmware files from the folder you extracted them to and each file must be in the right place: PDA: CODE_N7100xxxxxx_554452_REV00_user_low_ship.tar.md 5 PHONE: MODEM_N7100xxxxx_REV02_REV04_CL1145430.tar.md5 CSC: CSC_Oxx_N7100Oxxxxxx_CL547448_REV00_user_low_noshi p.tar.md5 - Turn your phone off and wait for 10 seconds the put it into Download Mode. - To enter Download Mode: Press Volume Down key + Home key + Power. - Keep pressing the above keys till you see a warning! message on the screen. - Press Volume Up key to enter to Download Mode. - Now you should connect USB cable to phone and PC. - In case the PC starts installing some USB drivers then wait till it is done completely. - Look at Odin's window and make sure it detects the Com port that your phone takes: If the phone's drivers is installed correctly you will see 0:[COMxx] when xx is the com port number so everything is OK. - Click Start button to let Odin downloads the selected firmware files into your phone. - during the update process it is very risky to stop the program or remove USB cable from phone so let it done without any interruption. - When the update process is done the phone will be rebooted. - If you see PASS! word at Odin's window then the update was successful. - Disconnect your phone and wait till it is fully on. - It is better to do Full Reset by this Code: *2767*3855# and let the phone rebooted. - After it is on again you can use the setup wizard to select your favorite settings and enjoying your updated phone. Regards, | |
The Following 3 Users Say Thank You to ..::CHAIN::.. For This Useful Post: |
05-06-2013, 16:35 | #5 (permalink) |
Member: 804115 Status: Offline Sonork: 1658994 Thanks Meter: 13 | first of us thakns for the support when i try to flash stuck on pit mapping.trying to different flash files and boxes eg.spt z3x asnsam same result get pit for mapping not flashing |
05-06-2013, 16:48 | #6 (permalink) |
Freak Poster Join Date: Jun 2012 Location: India Pune
Member: 1778852 Status: Offline Sonork: 100.1641316 Thanks Meter: 231 | Narendra pune contact me with yahoo , [email protected] , |
