Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-30-2010, 16:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: in CPU
Member: 77854 Status: Offline Thanks Meter: 126 | *Final & tested solution E2120 hang ,restart problems by Dr.NaBiL* Many problems appear for the bad e2120 try many solutions but device return back with same problems or phone stops when flashing the final tested report: 1- flashing this full flash uploaded by me will solve many problems,rebuild imei after flash make it like label Multiupload.com - upload your files to multiple file hosting sites! 2-flash TFS file any version with any box(hwk,ns,ust,z3x) 3-for phones stops during flashing this step is so important, open device clean pcb & small heat cpu & flash ic(slight heat to avoid damage pcb) the solution works on 30 sets all good never come back thx Dr.NaBiL |
The Following 103 Users Say Thank You to Dr.Nabil For This Useful Post: |
05-31-2010, 12:54 | #14 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | if you have z3x box you will do solve restart problem e2120b E2120b restart problem soluition 100% working E2120b restart problem soluition from z3x procedure 1,select e2120b model 2,do erase 1st 3,do flash e2120bddill1.cla,e2120bddil1.tfs this two type file 4,do fill imei tap e2120b of imei 5,do custom then it will take process to write imei of that after that you will check this mobile it will good condition 1000% attention pls :dont insert battery while process 1st & last thanks suppose if you get success dont forget to press thanks butten |
The Following 3 Users Say Thank You to umarmsn For This Useful Post: |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
