Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 05-13-2012, 05:51   #1 (permalink)
Member: 1028741
Flash Samsung Champ Deluxe Duos c3312
I'm trying to flash this Samsung Champ Deluxe Duos C3312 using Flashtool E2 but its not working the setup is as follow(in the links screenshot)
it throws an error
the error below
not working
Im using original USB cable
The infineon driver responds with this error below
infineon USB Driver
The USB driver X seems to kind of working but it throws an error this one below
Channel 1 is succesfully opened.
Please wait while setting up phone...
+CBC: 3,0
Error: Battery level to low to proceed in USB mode
USB mode not set. Close window and try again
Old 05-14-2012, 19:26   #2 (permalink)
Member: 1028741
nevermind I solved it by using flashtool ver 4.68.3.44
DLL interface: 3.86.
I used Infineon USB driver, hit start USB1 connect to the phone while pressing volume down and lock key. and voila!
Old 06-22-2012, 11:07   #3 (permalink)
Member: 761762
which firmware did u use for C3312 ? i flashed mine today and now ChatOn and opera says "Unavailable". i flashed with C3312XELB1..is this UK firmware where ChatOn is not avialable ? Also plz tell me if there is any way to increase jar size..i want to installed java version of Angry Birds on my GT-C3312. thank u pal.
Old 06-24-2012, 04:51   #4 (permalink)
Member: 1028741
I flashed it with the C3312XXLB1_OXELA5 too. That firmware is russian version. I think the ChatOn should work but for Opera Mini you have to redownload from official site. I also wanted to increase jar size but from my research it seems that its not possible.
Try going to keypad/dial mode and type *#272*TIME#
don't type TIME but type the current time for example if the time was 12:44 PM you will
type *#272*1244#
got it?
From there ,you can select an array of user content based on region.
There INS,INU,KOR,RTL,SEK,SER,SKZ and DEFAULT.
I think you're from india ? so select INU
Old 10-12-2012, 09:46   #5 (permalink)
Member: 761762
I was going following tips in the given link for flashing my Samsung Champ Duos Deluxe C3312 ( Samsung Champ Deluxe C3312: Updating Firmware) and somethin went wrong after pressing USB1 . Now i'm getting this "Firmware upgrade encountered an issue. Please select recovery mode in Kies and try again." message. As u must be knowing samsung champ duos deluxe is not supported in Kies for firmware upgrade. I cant even turn on my fone as the same message appears.
Please Help!!!!
Old 11-10-2012, 03:36   #6 (permalink)
c_ajaya's Avatar
Member: 476676
same as mine and kies asks for recovery code.IS there any solution for repairing recovery and installing firmeare for sam c3312.
Old 03-07-2013, 05:15   #7 (permalink)
Member: 1623940
c3312 hang problem
problem solved with infineon flash tool.
Old 04-06-2013, 12:57   #8 (permalink)
Member: 1877210
Sonork: gilcatred
C3312
pleas i need a french firmware for my Samsung c3312. all the once i have been downloading has no french language. can you help ...
Old 04-08-2013, 13:32   #9 (permalink)
Member: 418578
also confused with the Russian language
here is the french one
C3312JPLD1 - Download - 4shared
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-01-2000 23:28
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.30993 seconds with 11 queries
