Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
04-24-2018, 16:02 | #1 (permalink) |
Major Poster Join Date: Sep 2016 Location: Serbia Age: 26
Member: 2627895 Status: Offline Thanks Meter: 6 | G920F hidden.img failed. Any suggestions? Firmware: G920F_v7.1.1_XXU5EQH1-201709112_HOME Log (Odin 3.12): <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/062> Odin engine v(ID:3.1203).. <ID:0/062> File analysis.. <ID:0/062> SetupConnection.. <ID:0/062> Initialzation.. <ID:0/062> Get PIT for mapping.. <ID:0/062> Firmware update start.. <ID:0/062> SingleDownload. <ID:0/062> sboot.bin <ID:0/062> cm.bin <ID:0/062> boot.img <ID:0/062> recovery.img <ID:0/062> system.img <ID:0/062> cache.img <ID:0/062> hidden.img <ID:0/062> FAIL! <ID:0/062> <ID:0/062> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) Firmware: G920FXXU5DQA7_G920FOXA4DPGW Log (Z3X Samsung Tool PRO v31.4): File analysis... OK Total file size: 0xDB8C1840 (3512 Mb) Searching USB Flash interface... COM62 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Flashing done (time - 00:03:33) Done with Samsung Tool PRO v.31.4 After flashing both files phone keeps resetting in recovery. I also attempted many more, but they either get hidden.img error or they complete but reboot in recovery. (And no matter what you do it stays bricked in recovery mode.) Any solution or suggestions? I have also attempted flashing without hidden, but it still gets stuck in recovery. |
04-24-2018, 16:06 | #2 (permalink) | |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | Quote:
frp on bro? If not why not try 4 part file? | |
04-24-2018, 16:36 | #3 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | hey bro just open the full firmware .tar in 7zip or winrar and extract only the hidden.img archive then rename it as hidden.img.tar and flash in ap or pda in z3x box or odin and the phone will work. |
04-25-2018, 11:58 | #4 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | Quote:
G920F pit file for branded firmwares Hint: if you have Multi firmware Open CSC file with WinRAR and extract PIT file from it and you can use it... | |
04-27-2018, 12:58 | #5 (permalink) |
Member: 2627895 Status: Offline Thanks Meter: 6 | Thank you all for wonderful help, problem was SOLVED! I attempted all of the suggested solutions, sadly none worked. But after long hours of searching, and trying differnet things i found the fix! Here's direct link to it: http://forum.gsmhosting.com/vbb/f684...olved-2246222/ (#8) And a big shoutout to vasko_bojilov, the solution provided fixed the issue. |
