Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-18-2018, 11:56 | #1 (permalink) |
Junior Member Join Date: Mar 2018 Location: UK
Member: 2822188 Status: Offline Thanks Meter: 0 | G935F FRP Removal 7.0 2018 I have come across an issue with one of my S7 Edge's. No matter what I try I cannot get the FRP removed. I have browsed the forum quite extensively and can't seem to find a solution so thought I would post. I can't downgrade the firmware, I can't right combination firmware to unlock ADB for either Z3X or Octopus to work on. When I use Z3X it just gets a Samsung splash screen loop. The firmware it is on does not seem to be exploitable via the usual means. The only firmware that will write to the phone is: G935FXXS2DRAA Would be grateful for any advice. Thanks |
03-19-2018, 11:04 | #8 (permalink) |
No Life Poster Join Date: Jul 2017
Member: 2737570 Status: Offline Thanks Meter: 117 | Ur firmware doesn’t support urt cable method . So just flash it with any frimware u have no combination require . Then try urt frp coz some firmware doesnt work with urt cable method just did it n pass it quickly . Hope this Would be Helpful Best regards .. All qnc file in one place http://cuon.io/QNC All cert file in one place http://cuon.io/CERTTTTT Code is !_Ht_UtplLSwwfFy9ILBO4g |
03-19-2018, 12:24 | #9 (permalink) |
Crazy Poster Join Date: May 2016
Member: 2569608 Status: Offline Thanks Meter: 63 | It's easy 1st U Flash combination Then you Flash full firmware from updato.com they normally provide HOME CSC in the firmware which allows usb debugging to be enabled after flash.. works on everything else should work in this case |
03-19-2018, 14:28 | #10 (permalink) | |
Member: 2822188 Status: Offline Thanks Meter: 0 | Quote:
Sent from my SM-N950F using Tapatalk | |
