Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 02-17-2017, 01:40   #16 (permalink)
Member: 2514853
Ok . When i flash your file. Up to 50%. The screen show "IFW flash failed". So it's problem about emmc? Or other way to fix ? Thaks u, Angelo Cruz!
Old 02-17-2017, 18:24   #17 (permalink)
Angelo Cruz's Avatar
Member: 8012
Thanks Meter: 124
Itīs hardware problem , you have to change emmc ic .
The Following 2 Users Say Thank You to Angelo Cruz For This Useful Post:
Old 02-17-2017, 23:41   #18 (permalink)
Member: 2514853
I can run boot android samsung from SD Card? And I use card for replacing samsung" emmc ?
The Following User Says Thank You to smalldragon1102 For This Useful Post:
Old 02-26-2017, 00:43   #19 (permalink)
Member: 2689161
Flash error
Hey
I have a GT-P5210 too with same problem.
No respons on screen, not charge and computer see it as Cloverview device.
I have tryed your files, but I get this error
XFSTK-STATUS SN: 82230E250C8D8494 Unknown Ack code:0, aborting ...
What to do ?
Please help
Have a nice day
The Following User Says Thank You to jarenfeldt For This Useful Post:
Old 03-20-2017, 13:18   #20 (permalink)
Member: 2377800
Sonork: nono
Thanks Meter: 48
Angelo Cruz pleas i opened xFSTK-Downloader and i have p5200 connected good with driver but when i open xFSTK-Downloader not show nothing
Old 03-22-2017, 10:39   #21 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
same problem as you.
The Following User Says Thank You to GSM SNIPER For This Useful Post:
Old 03-22-2017, 12:30   #22 (permalink)
Member: 8012
Thanks Meter: 124
What is not showing ??
xFSTK-Downloader not opening ?
xFSTK-Downloader doesnīt detect device?
Follow instructions , itīs a simple procedure .
Use Windows XP or Windows 7 32bits , select proper device in xFSTK-Downloader ( itīs CloverviewPlus ( CLVP A0/B0/B1 ) )
The Following User Says Thank You to Angelo Cruz For This Useful Post:
Old 03-24-2017, 00:27   #23 (permalink)
Member: 2698886
my samsung gt-s5260p is dead, not ON again and not charging after i flashed it's with multiloader, its only enter to download mode when i connect it with my PC while holding the vol key and send..please i need help asap thanks
The Following User Says Thank You to admart123 For This Useful Post:
Old 04-18-2017, 18:21   #24 (permalink)
Member: 2708072
Thanks Meter: 2
hi!
I have Samsung tab 5200 in a brick condition
Tried to use your method to write files. Intel Soc drivers and xFSTK-downloader installed. The manager sees the device as CloverviewPlus. Everything is normal. But xFSTK interface is only an empty window and there is no way to do anything. what is the problem? Can I do this via a command line using xFSTK-solo keys?
The Following 2 Users Say Thank You to Aleks2609 For This Useful Post:
Old 04-23-2017, 13:30   #25 (permalink)
Member: 2708072
Thanks Meter: 2
flash all three files using PhoneFlashTool 100%. What else? Odin3 does'n see my p5200 yet
Old 04-27-2017, 12:31   #26 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
I try also whit phoneflashtool but when i try to flash files he give erorr sboot.bin is not a valid flash file.
Old 06-27-2017, 15:38   #27 (permalink)
Member: 1612872
Sonork: 1613495
Thanks Meter: 178
For me I can not see the tablet
And the driver is already installed
In addition I find not where to insert the files
Old 06-27-2017, 15:59   #28 (permalink)
Member: 1612872
Sonork: 1613495
Thanks Meter: 178
Problem resolved with version 1.7.0 I managed to flash
But I bind that the apariel has a hard pribleme
Old 06-27-2017, 23:28   #29 (permalink)
Member: 2723959
Thanks Meter: 49
IF your device can be seen by ODIN..i can help you repair it!! I can get the FACTORY Files for you to flash....IF anyone is interested...let me know
Old 07-20-2017, 17:08   #30 (permalink)
Member: 1830522
gt-P5220 BOOT REPAIR SOLUTION
Hi guys , someone can help me with GT_P5220 dead in cloverview. Thanks
Page generated in 0.22607 seconds with 9 queries
