Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-14-2014, 21:14 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 600811 Status: Offline Thanks Meter: 19 | HELP GALAXY S2! after flashing gets stuck on the logo. Have flashei with all roms available and the equipment starts but gets stuck on the logo. Anyone have a solution? excuse my english |
03-14-2014, 21:34 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Next thing to try is probably to flash a kernel If your GSII has the folowing symptoms :
But if your symptoms are the mentioned above, PLUS the symptoms below
It's time to open up ODIN and start reviving your phone! | |
03-14-2014, 21:38 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First of all, let's just have a quick glance of how ODIN looks like, and where we should put the files : As the picture clearly shows, the green rectangle is where you can tick. Those 2 which are ticked must remain that way. And the red one is well... Where you SHOULDN'T touch ONLY FLASH WITH RE-PARTITION TICKED AND A PIT FILE IF YOU ARE SURE THAT THE FLASH WILL SUCCEED. Which means that you CANNOT have a damaged USB, corrupted drivers and such. When recovering from a soft brick, it is recommended, not mandatory, to have Re-partition ticked with a .PIT file. So you must be extra careful when you are using a .PIT and Re-Partition. And obviously, the red box is the one where you can't and don't want to mess with But where are the files going, you say? .PIT -> PIT APBOOT -> BOOTLOADER (or PDA if flashed alone) CODE -> PDA MODEM -> PHONE CSC -> CSC ***If you have a 1 file .tar package, then flash it in PDA*** There is only 1 way to recover a soft bricked phone. How to recover from a NAND corruption? |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-14-2014, 21:41 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Recovering a soft bricked phone 1) Grab the Recovery Package, and you'll see a bunch of .tar files. Take a look at the names. You'll see CODE, MODEM, CSC and .PIT. Put each one in its place. 2) Turn off your phone. Enter Download mode by presing Volume Down + Home + Power button. 3) Plug in your phone. It will show you, in a yellow box in ODIN, ID:COMx (x being the number displayed, sometimes displays 7, sometimes displays 9) First try flashing WITHOUT the .PIT and re-partition. And only if it DOESN'T WORK OR FIX then you flash with the .PIT and Re-Partition ticked. 4) Once ready and done all your prayers, press Start. Wait patiently. It usually takes 5 minutes to flash. Have you done everything correctly until now? Then... Congratulations on recovering your phone! Now, if your problem is the NAND rw coruption, and wasn't fixed by the above fix, then follow these steps : 5) Download the Kernel. Flash it in PDA. Without ticking Re-Partitioning 6) Successful? Nice, hope is still present. 7) Flash the recovery package, following steps 1-4 This should fix your issue. If it does not, then : WARNING : FLASHING A BOOTLOADER IS DANGEROUS. FLASH WITH EXTREME CAUTION. 8) Download the Bootloader. Flash it as PDA or Bootloader in ODIN. Without ticking Re-Partitioning 9) Flash the Kernel, as in step 5 10) Flash the recovery package, like in steps 1-4 And that will fix any of your issues I hope that this guide was helpful, and if it was, hit the thanks button! |
