Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
10-01-2012, 18:42 | #2 (permalink) |
No Life Poster Join Date: Jan 2011 Location: algeria
Member: 1503017 Status: Offline Thanks Meter: 447 | C6112_OneNAND_Downloader_v0.7.rar | FilesIn.com Run Samsung C6112 Downloader. Make Sure these two options are checked: MASTER + SLAVE. Set Com number and Speed. In MASTER section check: BIN + TFS and Check With common CSC. For BIN field select: C6112xxxxx_Master.cla For TFS field select: C6112xxxxx_Master.tfs For CSC field select: C6112Oxxxxx.csc In SLAVE section check: BIN + TFS For BIN field select: C6112xxxxx_Slave.cla For TFS field select: C6112xxxxx_Slave.tfs Press START button and connect cable to phone with battery. After the Program detect the Flash ID you can press DOWNLOAD to start the process. After all is Done turn on the Phone and do full reset: *2767*3855#. |
