Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-25-2014, 14:46 | #2 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | SELECT FILE LIKE THIS IN FLASHING TOOL S5220xxxxx_psi.fls S5220xxxxx_slb.fls S5220xxxxx_BSY.fls S5220xxxxx_CDS.fls S5220Oxxxxx_CSC.dffs - Make sure of the following options: USB Port = 1 Baud Rate = 921600 # Channels = 1 Communication Driver = Infineon USB Driver - Click NEXT> button ( at the lower right corner ). - Click Start USB1 button at the new window. - Press Volume + and - Keys on the phone and connect USB cable to it. - If all is OK the the Update will start automatically. - You will see that the program will upload the selected firmware files one by one. - When the process is done correctly you will see Success word on the program window with Green line under it. |
The Following 2 Users Say Thank You to mobite For This Useful Post: |
06-25-2014, 16:10 | #5 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Update Tools: - Original S5220 Firmware Package. Download S5220XXLC3 OXELAA zip - Original Flashtool Program. http://www.4shared.com/zip/NKi_JH4pce/S5220.html - Original USB Cable. Firmware Update Steps: - First you need to let your PC install the needed USB drivers, And to do that remove battery from the phone and insert it back, Now press Volume + and - keys and keep them like that and insert USB cable into the phone, When windows ask you to install the drivers you can let it search inside the Flashtool folder. After that reboot your PC. - Run Flashtool program and make sure that ( Custom Order ) is checked and also ( Erase whole flash before download ) is selected too. - Press Ctrl + O each time you want to select one of the Firmware Files and select them in this Order: S5220xxxxx_psi.fls S5220xxxxx_slb.fls S5220xxxxx_BSY.fls S5220xxxxx_CDS.fls S5220Oxxxxx_CSC.dffs - Make sure of the following options: USB Port = 1 Baud Rate = 921600 # Channels = 1 Communication Driver = Infineon USB Driver - Click NEXT> button ( at the lower right corner ). - Click Start USB1 button at the new window. - Press Volume + and - Keys on the phone and connect USB cable to it. - If all is OK the the Update will start automatically. - You will see that the program will upload the selected firmware files one by one. - When the process is done correctly you will see Success word on the program window with Green line under it. - Disconnect phone and turn it on then make full reset: *2767*3855#. |
The Following 2 Users Say Thank You to gcceleghg For This Useful Post: |
06-25-2014, 21:44 | #7 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2163458 Status: Offline Thanks Meter: 1 | My problem is i like to change my sim card. my samsung aprove only t-mobile and i like to put VIP (macedonia) if anyone know how to do that tell me plz |
The Following User Says Thank You to aleksandartodor For This Useful Post: |
03-31-2018, 17:48 | #12 (permalink) | |
Junior Member Join Date: Apr 2010
Member: 1277043 Status: Offline Sonork: 06767uhj6u76 Thanks Meter: 5 | Quote:
odin tool -> Samsung Odin Flash Tool V3.13.1 firmware link How To Update Samsung S5220 Star 3 Firmware By Flashtool and USB Cable | |
