Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 06-19-2012, 12:54   #1 (permalink)
Member: 1159663
Sonork: bydolek
Thanks Meter: 10
how to flash samsung s5830i
help me
Old 06-19-2012, 12:59   #2 (permalink)
Member: 1774014
some body canna hel , how to flash and unlock s 5830i
Old 06-19-2012, 13:05   #3 (permalink)
mohideen77752's Avatar
Member: 1772238
Sonork: 100.1617698
Thanks Meter: 125
what problem on your phone
Old 06-19-2012, 19:01   #4 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
Thanks Meter: 122
use odin to flash s5830
Old 06-19-2012, 19:16   #5 (permalink)
::GSM-27::'s Avatar
Member: 19423
Sonork: 69566
Thanks Meter: 244
Originally Posted by sreesree8 View Post
help me
Hotfile.com: One click file hosting: S5830IXXLD3_S5830IODDLD2_INS.zip
Open Odin in your computer and reboot your phone so that it can enter in the Download Mode. The download mode in Galaxy ACE S5830i can be entered by pressing down on Volume Down Key + OK button, and holding both simultaneously press the Power Button .
Now, connect your phone to the computer with the help of USB cable. Once connected, you can see that the ID: COM section has turned Yellow in Odin.
Now, Click on “PIT” to select “cooperve_0623.pit” and then click on “PDA” tab to select “S5830iXXLD3_S5830iODDLD2_RST_S5830iDDLD1_HOME.tar .md5”.
After selecting the files, Click “Start” to start the update process. After successfully the process, disconnect your phone and reboot.
After rebooting, the device will show up the Home Screen or Language preferences, indicating you to disconnect your phone.
Old 06-19-2012, 19:22   #6 (permalink)
Member: 1503017
Thanks Meter: 395
S5830-Flashguide
all samsung flashing & dowloader programs
Old 06-20-2012, 07:54   #7 (permalink)
tsb_ms's Avatar
Member: 851014
Sonork: 6655
Thanks Meter: 21
sreesree8
Member: 1159663
Sonork: bydolek
help me
flow here by steep.......
1.download Odin3 v1.85
2. run this Odin3 v1.85
3. Bootloader : DefaultCalDataWithBoot_S5830iXXKK5_REV00.tar
4. PDA : PDA_S5830iXXKL1_REV00.tar
5. PHONE : MODEM_S5830iXXKK5_REV00.tar
6. CSC: GT-S5830i-MULTI-CSC-OXEKK4_RST.tar
7. volium up+volium down+power button
8. now bootloader show
9. connect ur phone use usb with pc will be show yeallow in id.com on the odin
10. star
goodluck bro
The Following User Says Thank You to tsb_ms For This Useful Post:
Old 07-26-2012, 15:11   #8 (permalink)
ASIEDU ANNOR's Avatar
Member: 510345
Thanks Meter: 30
my s5830i restarts
i have s5830i and it cannot boot. the only thing it does is rebooting
Old 07-26-2012, 15:14   #9 (permalink)
Member: 510345
Thanks Meter: 30
Hi all,
I bought my Galaxy Ace S5830i last month. I hadn't installed Samsung Kies until yesterday, when I launched it it prompted a firmware upgrade. First I tried to use kies to upgrade but whenever the upgrade process started (Kies started downloading the firmware files) my device automatically got disconnected..I tried reinstalling kies, restarting my phone but nothing worked.
I then decided to use odin(v1.87) to flash the firmware on my device but it kept failing at first step itself. Here's what it said :-
<ID:0/010> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> S5830iXXLF3_S5830iODDLF1_RST_S5830iDDLF1_HOME.tar. md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/010> Odin v.3 engine (ID:10)..
<ID:0/010> File analysis..
<ID:0/010> SetupConnection..
<ID:0/010> Initialzation..
<ID:0/010> Set PIT file..
<ID:0/010> DO NOT TURN OFF TARGET!!
<ID:0/010> Get PIT for mapping..
<ID:0/010> Firmware update start..
<ID:0/010> sbl.bin
<ID:0/010> NAND Write Start!!
<ID:0/010> BcmCP.img
<ID:0/010>
<ID:0/010> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
I am at my wits end now so can anyone please help me sort out this problem?
Old 08-03-2012, 13:19   #10 (permalink)
Member: 510345
Thanks Meter: 30
unkock s5830
you can use either SGtool (setool) or z3 box to unlock
Old 02-14-2013, 18:40   #11 (permalink)
Member: 100241
Thanks Meter: 19
s5830i
i can make download on s5830i i press volume up+volume down + key power ,
the phone power on but nothing on the screen.
i try second step , volume down +home button+power key ,the phone a power on.
i have riff box can anyone help me?
thanks.
Old 02-14-2013, 18:41   #12 (permalink)
Member: 100241
Thanks Meter: 19
i want to enter my phone download mode.
Old 02-27-2013, 15:46   #13 (permalink)
Member: 1343970
Thanks Meter: 2
bother same time press vol+,vol- and power
Old 04-11-2013, 03:09   #14 (permalink)
Member: 1914612
good day.. my s5830i is rooted and replace the firmware apk file, can i still flash my phone using odin. what is the procedure thanks...
Old 04-11-2013, 04:15   #15 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 782
Firmware Update Steps:
- Run Odin flasher and check these options: Re-Partition, Auto Reboot, F.Reset Time.
- Now you have to select the Firmware files that will be used by Odin to Update your phone:
PIT: cooperve_0623.pit
BOOTLOADER: DefaultCalDataWithBoot_S5830ixxxxx_REV00.tar.md5
PDA: PDA_S5830ixxxxx_REV00.tar.md5
PHONE: MODEM_S5830ixxxxx_REV00.tar.md5
CSC: GT-S5830i-MULTI-CSC-Oxxxxx.tar.md5
- Put your phone into Download Mode: Press Volume Down Key + Home + Power.
- Connect USB cable to phone and PC and install drivers ( If needed ).
- Make sure that Odin can detect the Com Port number of your connected phone.
- Click Start button on Odin program to begin the update process.
- Odin flasher will update your phone then will restart it automatically.
flsher here::::::::::::S5570_S5670_S5830_Odin Multi Downloader v4.38 - Download - 4shared
S5830 Firmware:
Android 2.2.1:
Android 2.3.3:
- S5830JPKP9 Arabic
- S5830JVKP2 Turkey
- S5830XWKPF / XWKP5 TPL Poland (T-mobile)
- S5830XWKPK / TMHKP1 Hungary (T-mobile)
- S5830XWKPO / XENKP2 Netherlands
- S5830XWKPO / LUXKP1 Luxembourg
- S5830XWKPU / TPLKP2 Poland (T-mobile)
- S5830XWKPY / OXFKP5 BHT Bosnia
- S5830XWKPY / OJCKP2 XFA South Africa
- S5830XWKPY / WINKP2 Italy Wind
- S5830XWKS9 / KPNKP2 Netherlands KPN
Android 2.3.4:
- S5830BVKQ7 / BVKQ6 IDE Poland (Orange)
- S5830BVKQ9 / IDEKQ4 Poland (Orange)
- S5830BVKQ9 / FTMKQ6 France (Orange)
- S5830XWKPY / OXXKPA PAN Hungary Telenor
Android 2.3.5:
- S5830BGKS5 / XECKS1 Spain Moviestar
- S5830BOKS3 / DTMKS1 Germany T-Mobile
- S5830BUKS2 / SFRKS2 SFR France
- S5830BUKS2 / VODKS1 United Kingdom (Vodafone)
- S5830BUKS2 / VGRKS3 Greece (Vodafone)
- S5830BUKS2 / VDFKS1 Netherlands Vodafone
- S5830JPKS2 Arabic
- S5830XWKR2 / OXEKP4 SEB Baltic
- S5830XWKR2 / OXFKS3 ORO Romania (Orange)
- S5830XWKR2 / PROKP2 Belgium / Luxemburg
- S5830XWKS2 / XENKS1 Netherlands
- S5830XWKS3 / VIRKP1 United Kingdom
- S5830XWKS9 / XENKS1 Netherlands
- S5830XWKS9 / OXXKS2 ATO Austria
- S5830XWKS9 / VNZKP5 NEW ZEALAND
- S5830XWKSD / METKP6 Ireland (Meteor)
Android 2.3.6:
- S5830ANKT1 / EPLKT3 Germany E-Plus
- S5830BGKT4 / XECKT4 Spain Moviestar
- S5830BOLH1 / CROLG1 Croatia T-Mobile
- S5830BUKT2 / SFRKT1 France SFR
- S5830BVKT3 / AMNKT1 Spain (Orange)
- S5830BVKT3 / FTMKT1 France (Orange)
- S5830BVKT5 / AMNKT2 Spain Orange
- S5830DXKT6 / OLBKT3 THL Thailand
- S5830DXKT7 / OLBKT3 XXV Vietnam
- S5830FOKP1 / HEFKP2 XEF France
- S5830HRKT2 / OROKT2 Romania Orange
- S5830XWKPY / SEKKP6 Ukraine Complete
- S5830XWKT6 / OXXKT3 TPH Portugal
- S5830XWKT7 / OXFKT1 NEE Nordic countries
- S5830XWKT7 / TMHKP1 Hungary T-Mobile
- S5830XWKTE / EPLKP3 Germany (E-Plus)
- S5830XWKTQ / PRTKT3 Poland Play
- S5830XWKTQ / FRELT2 France Free Mobile
- S5830XWKTQ / EIRKT1 Ireland eMobile
- S5830XWKTQ / METKT1 Ireland Meteor
- S5830XWKTQ / O2IKT1 Ireland O2
- S5830XWKTQ / VIAKT3 Germany O2
- S5830XWKTS / WINKT1 Italy WIND
S5830B Firmwares:
Android 2.3.3:
Android 2.3.4:
Android 2.3.6:
- S5830BVJLP4 / UVILP2 ZVV Brazil VIVO
- S5830BVJLP4 / ZTALP1 Brazil Claro
S5830C Firmwares:
Android 2.3.6:
- S5830CVJLB3 / ZTALB2 Brazil Claro
- S5830CVJLH1 / ZTALH1 Brazil Claro
- S5830CVJLK4 / ZTALK1 Brazil Claro
- S5830CVSLA1 / TFGLA1 EBE Ecuador
- S5830CVSLL1 / TFGLL1 EBE Ecuador
S5830D Firmwares:
Android 2.3.4:
S5830i Firmwares:
Android 2.3.6:
- S5830IBGLH4 / XECLH2 Spain Moviestar
- S5830IDXLD2 / OLBLD1 XME Malaysia
- S5830IDXLD2 / OLBLD1 XSE Indonesia
- S5830IDXLD2 / OLBLD1 XSP Singapore
- S5830IDXLF1 / OLBLD1 MM1 Singapore
- S5830IDXLF1 / OLBLD1 SIN Singapore SingTel
- S5830IDXLF1 / OLBLD1 STH Singapore StarHub
- S5830IDXLF1 / OLBLD1 XME Malaysia
- S5830IDXLF1 / OLBLD1 XSE Indonesia
- S5830IDXLF1 / OLBLD1 XSP Singapore
- S5830IDXLF1 / OLBLD1 XTC Philippines Sun
- S5830IDXLF1 / OLBLD1 XXV Vietnam
- S5830IDXLK1 / OLBLD1 XME Malaysia
- S5830IDXLK1 / OLBLD1 XSE Indonesia
- S5830IDXLK1 / OLBLD1 XTC Philippines Sun
- S5830IDXLK1 / OLBLD1 MM1 Singapore
- S5830IDXLK1 / OLBLD1 SIN Singapore SingTel
- S5830IDXLK1 / OLBLD1 STH Singapore StarHub
- S5830IDXLK1 / OLBLD1 THL Thailand
- S5830IDXLK1 / OLBLD1 XSP Singapore
- S5830IDXLK1 / OLBLD1 XXV Vietnam
- S5830IDXMB1 / OLBLD1 Southeast Asia
- S5830IXXKL1 / OXEKK4 Russia Complete
- S5830IXXLA2 / OCELA1 KPN Netherlands
- S5830IXXLA2 / OCELA1 XEN Netherlands
- S5830IXXLA2 / OJVLA2 XFE South Africa
- S5830IXXLA4 / OXXLA2 PAN Hungary Telenor
- S5830IXXLA4 / OXXLA2 ATO Austria
- S5830IXXLC2 / PRTLC1 Poland Play
- S5830IXXLD3 / OXXLA2 ATO Austria
- S5830IXXLE2 / OXFLD1 TRA Croatia
- S5830IXXLE2 / OXFLD1 SIM Slovenia Si.mobil
- S5830IXXLE2 / OXFLD1 ORO Romania Orange
- S5830IXXLF3 / ODDLF1 SLK Sri Lanka
- S5830IXXLF3 / ODDLF1 TML Bangladesh
- S5830IXXLK2 / ODDLJ1 SLK Sri Lanka
- S5830IXXLK2 / ODDLJ1 TML Bangladesh
- S5830IXXLK3 / OXXLH1 ATO Austria
- S5830IXXLK3 / EPLLK1 Germany E-Plus
- S5830IXXLK3 / OXFLK1 CMF Macedonia
- S5830IXXLK3 / OXFLK1 COA Romania Cosmote
- S5830IXXLK3 / OXFLK1 SIM Slovenia Si.mobil
- S5830IXXLK3 / OXFLK1 TRA Croatia
- S5830IXXLK3 / OXFLK1 TSR Serbia Telekom
- S5830IXXLK3 / OXFLK1 TWO Croatia TELE2
- S5830IXXLK3 / OXFLK1 VIM Macedonia
- S5830IXXLK3 / MOTLH1 Slovenia Mobitel
- S5830IXXLK3 / TMHLI1 Hungary T-Mobile
- S5830IXXMA1 / OCEMA1 XEN Netherlands
- S5830IXXMA1 / OCEMA1 KPN Netherlands
- S5830IZSLD2 / OZSLA3 TGY Hong Kong
- S5830IZSLF1 / OZSLA3 TGY Hong Kong
- S5830IZSLK1 / OZSLA3 TGY Hong Kong
- S5830IZSLK1 / OZSLA3 TWM Taiwan Chunghwa
S5830L Firmwares:
Android 2.3.3:
- S5830LUBKP8 / UWEKP3 PGU Guatemala
- S5830LUBKPF / UWMKP4 CGU Guatemala Tigo
Android 2.3.4:
- S5830LUBKPA / CHTKP3 Chile (Telefonica)
- S5830LUBKPA / UVEKP2 UFN Argentina (Moviestar)
- S5830LUMKP3 / TCEKP3 Mexico Telcel
Android 2.3.6:
- S5830LUBKPF / UWMKP4 CGU Colombia Comcel
- S5830LUBKPK / COMKP3 Colombia (Comcel)
- S5830LUBKPL / UBKPL CHT Chile (Telefonica)
- S5830LUBKPL / CHEKP5 Chile (Entel PCS)
- S5830LUBLP1 / CHELP1 Chile Entel PCS
- S5830LUBLP3 / UVELP1 UFN Argentina Moviestar
- S5830LUBLP3 / CHTLP2 Chile Telefonica
- S5830LUBLP3 / UUBLP2 TTT Trinidad and Tobago
- S5830LUBLP3 / UWELP1 PGU Guatemala
S5830M Firmwares:
Android 2.3.6:
- S5830MUMLB1 / TCELB1 Mexico Telcel
- S5830MUMLJ1 / TCELJ1 Mexico Telcel
- S5830MUMLK1 / TCELK1 Mexico Telcel
- S5830MUMLL1 / TCELL1 Mexico Telcel
- S5830MVSLA1 / TFGLA1 CHT Chile Telefonica
- S5830MVSLA1 / TFGLA1 TMM Mexico Movistar
- S5830MVSLG1 / TFGLG1 COB Colombia Moviestar
- S5830MVSLK2 / TFGLK4 COB Colombia Moviestar
- S5830MVSLL1 / TFGLL1 CHT Chile Telefonica
- S5830MVSLL2 / TFGLL3 TMM Mexico Movistar
- S5830MVSMC1 / TFGMC1 CHT Chile Telefonica
- S5830MWHLA1 / UUBLA1 TTT Trinidad And Tobago
- S5830MWHLA1 / UUBLA1 VNO Venezuela
- S5830MWHLB1 / ZZZLB1 CHL Chile Claro
- S5830MWHLB1 / PSNLB1 Argentina Personal
- S5830MWHLB2 / CHELB1 Chile Entel PCS
- S5830MWHLF2 / CHELF1 Chile Entel PCS
- S5830MWHLF2 / CHLLF1 Chile Claro
- S5830MWHLJ1 / UUBLJ1 TTT Trinidad and Tobag
- S5830MWHLK1 / COMLK1 Colombia Comcel
- S5830MWHLK2 / COMLK2 Colombia Comcel
- S5830MWHLK2 / UUBLK1 TTT Trinidad and Tobago
- S5830MWHLL1 / CHELL1 Chile Entel PCS
- S5830MWHLL1 / CHLLL1 Chile Claro
S5830T Firmwares:
Android 2.3.4:
- S5830TDVKQ3 / TELKQ3 Australia (Telstra)
Android 2.3.6:
- S5830TDCKT6 / THLKT2 THL Thailand
- S5830TDVKQD / TELKQD Australia Telstra
Samsung S5830V Firmwares:
Android 2.3.6:
- S5830VDULJ2 / VAULG1 Australia Vodafone
S5830Z Firmwares:
Android 2.3.6:
- S5830ZXXLK3 / OXELH1 RTL Ukraine
- S5830ZXXLK3 / OXELH1 Russia Complete
- S5830ZXXLK3 / OXELH1 SKZ Kazakhstan
The Following User Says Thank You to mobilehelper For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.78855 seconds with 8 queries
