Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
09-10-2014, 14:16 | #1 (permalink) |
Crazy Poster Join Date: Nov 2013 Location: lahoer pakistan
Member: 2075753 Status: Offline Sonork: 1647349 Thanks Meter: 67 | How to Remove Samsung account for Samsung Note 3 Solution work 100% Solution=1 First of all I have to say that I've created this account just to share what I did with this problem. It took me, after doing dozens of hard reset and flashing firmwares, 10 minutes. Maybe, the seller never activated the phone (that's what happened to me) and this screen is appearing by mistake. So what you have to do if this is your case is to connect the headphones that came with the phone and press the button for 1-2 sec. Then the S Voice will appear and there you can use voice commands. So you just say "Start Settings" and it will open the setting where you have to activate the activation lock (maybe isn't necessary, but that way worked) but this time using your samsung account. Then you just have to do a factory reset (from the settings, not from the recovery) and your phone will be unlocked. It will restart and then you can set it up normally. Hope this works for you as it do for me. Solution=2 Goto accessibility option which is available on the first screen where you select language..then goto Text to speech option..then from the settings goto Install voice data and try to download any language..It will ask you to enter samsung account details...Enter your own samsung account details..once the download is complete..go back to screen where it was showing abnormal factory reset and then enter your samsung account..It will go through. Note:NOW YOU PHONE IS PERFECTAMENTE WORKING and WITH YOUR SAMSUNG ACCOUNT, WARNING FIRST OF WIPE/F.RESET OF CHECK IF "REACTIVATION LOCK BUTTON IS "UNCHECKED", that's all, if this can help many of you, thanked if you want |
11-16-2014, 22:44 | #3 (permalink) |
Freak Poster Join Date: Aug 2013 Location: El Pais de las Maravillas.
Member: 1994657 Status: Offline Thanks Meter: 93 | Quote: |
