Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-10-2014, 16:46 | #2 (permalink) |
Junior Member Join Date: Apr 2014 Location: Bangladesh,Dhaka,Manaikganj
Member: 2175029 Status: Offline Sonork: Moshiur Rahaman Thanks Meter: 3 | samsung T705 Official Firmware samsung T705 Official Firmware T705XXU1ANE9 Android 4.4.2 KitKat Firmware for Galaxy Tab S 8.4 SM-T705- How to Install Check battery percentage, your device should have at least 90% battery power Turn on USB Debugging mode, go to Settings-Developer Options-USB Debugging Backup important data and settings to external storage- follow this guide Install USB driver for your device on your computer- Download Samsung USB Driver How to Install Android 4.4.2 KitKat Official Firmware on Galaxy Tab S 8.4 T705 through Odin odin3-v3.07-Samsung-Galaxy-S4-GT-I9500-GT-I9505-600x438 Download Android 4.4.2 XXU1ANE9 Firmware for Galaxy Tab S 8.4 T705 Download Odin 3.07 Switch off your Tablet and boot Galaxy Tab S 8.4 T705 into Download Mode by pressing and holding the Volume Down and Power keys together until you get the warning message, now press Volume Up key to proceed to Download Mode. Extract the downloaded Odin3.07 zip file and run the Odin3 v3.07.exe file as an administrator (Right click on the .exe file and click on Run as administrator) Now connect your Galaxy Tab S 8.4 T705 to your computer via USB cable In Odin3 screen, you should see a COM Port number like “0:[COM7]” at ID:COM section and “Added!” text at the message box. This means your device has been detected by Odin3. Make sure that, only the “Auto Reboot” and “F. Reset Time” options are checked. Now, extract the downloaded firmware zip file, you’ll find a firmware file with extension .tar.md5 In Odin screen, click on PDA button (if you are using the latest Odin Version, then click on AP button instead of PDA) and select the firmware file with .tar.md5 extension (The firmware file look something like: T705XXDLJ5_T705ODDDLI7_INU.tar.md5) Now, click on the Start button to begin the installation process, wait few moments. Once completed, you would see “PASS!” message in ID:COM port having green background Your Tablet should automatically reboot after completion You can now disconnect your Tablet from computer |
