Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
08-28-2014, 17:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 969318 Status: Offline Thanks Meter: 82 | Flash G900F Fail!! |
08-29-2014, 18:21 | #3 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: vn
Member: 162379 Status: Offline Thanks Meter: 178 | Quote:
am upload | |
08-29-2014, 19:11 | #4 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
1- Press and Hold Volume Down Key + Home Key then press Power key, And if you get the warning message release all keys and press Volume Up key to enter the Download Mode. 2- Press and Hold Volume Down Key then press Power button, And if you get the warning message release all keys and press Volume Up key to enter the Download Mode. 3- Press and Hold Volume Down Key + Volume Up Key then press Power Key, And if you get the warning message release all keys and press Volume Up key to enter the Download Mode. | |
08-29-2014, 19:15 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Samsung SM-G900F - for Europe Check the current firmware of your mobile, You can check it from Setting > About Phone, Or you can use this easy code *#1234# Installing the new Firmware into your Samsung Galaxy S5 Device: 1- After you put your mobile into Download Mode, Use the USB cable to connect it to your computer. 2- You have to wait until Windows detects the device and installs any needed drivers. 3- Look at Odin3 program's window, If the program detects your connected device correctly, You should see its COM Port number (0:[COMxx]). 4- You are ready to install the new firmware files into your Samsung mobile, Click Start button to begin. 5- After you click the Start button, Odin3 program will start to install the selected firmware files into the connected device. 6- Odin3 program will restart your Samsung mobile automatically after installing the firmware. 7- Wait until your mobile is restarted. 8- Look again at Odin3 program's window, If your see PASS! word in green, Then the update was done successfully. 9- Disconnect your mobile. 10- When the mobile is fully on, Check the new installed firmware version. 11- Now you are ready to use the device, So reinsert the SIM and Memory cards, Restore your backup, And customize it. You can update your device firmware version without using any PIT file, So use the PIT file only if you need to fix your device partitions. When you get one big file inside the firmware package, Then it should be selected as a PDA (AP) file only, And do not check Re-Partition option or use PIT file at all. |
