Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
08-31-2010, 21:09 | #1 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1381647 Status: Offline Thanks Meter: 0 | I need help, and flash tutorials for Samsung E2120 I have a Samsung E2120 GT, when I switch it on it starts and restarts in a loop, I want the flash may be his will solve the problem, but I do not know how to do it with USB cable, someone a solution would he? I want a tutorial for flash, I have " E2120CBIH1.rar " firmware, I wonder if it contains the English or French language if no-wr-I find it? ************************************************** Thank **** ********************************************* Bonjours; J'ai un Samsung E2120 GT, quand je l'allume il démarre et redémarre en boucle, je voudrais le flasher peut être que sa règlera le problème, mais je sais pas comment m'y prendre avec le cable USB d'origine, quelqu'un aurait-il la solution ? j'ai le firmware " E2120CBIH1.rar ", je voudrais savoir s'il contient la langue anglais ou française si non ù pourais -je le trouver ? ************************************************** **** Merci |
09-01-2010, 16:45 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | 1- Get E2120 Flasher 2- Run the program and select COM port 3- Select BIN & TFS files each one in his field 4- Press START and Connect the phone to cable 5- When the program activate Download Button Press it to start flashing 6- After the process done the program will show up A msg box tell u that For More Guides See Here Good Flashing For All |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
