Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 10-13-2008, 22:05   #1 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,078
i8510 iNNOV8 SAMSUNG FIRMWARE + DOWNLOADER + DRIVERS + MANUEL
here is a first complete thread about i8510 iNNOV8 SAMSUNG
FIRMWARE:
i8510XEHI2.zip
i8510XEHI5.ZIP
FLASHER (downloader):
Apollo_v5.24.rar
Apollo v5.27.rar
DRIVERS (for phone & pda):
i8510 PHONE + PDA DRIVERS FOR Apollo
inside archive :
-phone drivers Samsung_PC_Studio_7_7.1.30.8.exe
-pda drivers SSDN_V1.1.808.7165_SETUP_whql.exe
-Apollo v5.27.exe + unrar.dll
-msxml.msi
-Samsung S60 Phone ROM Image download Manual (English).doc
MANUEL (documents):
Samsung_I8510_Eng_8gb_quick_start_guide.pdf
Samsung_I8510_UM_EU_Eng_16GB.pdf
Samsung_i8510_SVCM_final_Anyservice_080821.pdf
VIDEOS:
Samsung I8510 INNOV8 test - sample video 2.flv
innov8_video1.mp4
SOME GADGETS:
nokia_e3_demosis.rar
Quake.zip
The Following 121 Users Say Thank You to allal123 For This Useful Post:
Old 10-14-2008, 13:05   #2 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,078
How to download ROM Image for Samsung S60 Phones
1. Preparation
A. Apollo v5.25
B. USB driver for Apollo
i. PDA : SSDN_V1.1.808.7165_SETUP_whql.exe
ii. PHONE : SAMSUNG Mobile USB DRIVER(4.40.7.0) v1.6.zip
C. unrar.dll for Apollo
D. MS xml parser : Msxml.msi
E. USB Cable
F. I8510 phone with almost fully charged battery(more than 3 battery bars)
2. Concepts and Cautions
A. Binary is devided for 2 images, PDA and Phone. PDA image consists of CODE and CSC.
B. Do Not power off the phone or disconnect cable during download.
C. Use right version of Apollo written in ‘Release Note’.
D. Vesions of CODE, CSC and PHONE should be matched correctly according to ‘Release Note’ when you download. If the combination is wrong, phone may not work.
E. Phone LCD will show the downloading progress bar when you download CODE and CSC, however it will not show the progress bar during PHONE download. Instead Apollo shows the progress.
3. USB Driver Installation
A. Excute SSDN_V1.1.808.7165_SETUP_whql.exe to setup PDA driver.
B. Unzip SAMSUNG Mobile USB DRIVER(4.40.7.0) v1.6.zip, setup PHONE driver with setup.exe.
4. How to make sure Driver installation
A. Launch Apollo.
B. How to make sure PDA Driver
i. Power on the phone with 1 + 4 button pressed.(PDA Download Mode)
ii. When you connect phone to PC, you can see the message like the picture below. This means PDA Driver is installed well.
C. How to make sure PHONE Driver
i. Power off the phone and Power on with 7 + * key pressed.(MODEM DOWNLOAD Mode)
ii. When you connect phone to PC, you can see the message like the picture below. This means PHONE Driver is installed well.
5. Release
A. PHONE Release
i. Phone binary is release by Modem Team, the releationship between PDA and PHONE is written in ‘Release Note’. Therefore you should check ‘Release Note’ to know correct CODE and CSC version for PHONE.
ii. In myProject, you can find the ‘Release Note’ at Baseband Binary.
B. PDA release consists of CODE and CSC.
i. FULL(CODE + CSC) Release
1. CODE and several CSC are released concurrently, in myProject CODE and CSC will be zipped as one file. The zip file is uploaded in Phone Binary part.
2. There exists PreSetTable.xml with some binary files in the zip file.
ii. CODE Release
1. After FULL Release, modified CODE is released without CSC modification.
2. In myProject, it is uploaded at Phone Binary part. There are CODE binary and PreSetTable.xml in the zip file.
iii. CSC Release
1. Without modification for CODE, modified CSC is released.
2. In myProject, it is uploaded at CSC Binary part, there are CSC binary and PreSetTable.xml in the zip file.
6. How to Download
!!! Make sure CODE, CSC, PHONE mapping in ‘Release Note’, and then download with the correct version . After download, press *#1234# and check CODE, CSC and PHONE version . This is very important!!!
i. CODE + CSC + PHONE Download(FULL Release)
1. In myProject, download FULL Release and PHONE binary.
2. Launch Apollo, press button to select PHONE binary.
3. Press button and select PreSetTable.xml.
4. Choose Country at ‘Country:’ , choose Operator at ‘ Operator:’.
5. Confirm CODE and CUSTOM version.
6. Power on the phone with 4 + * key pressed(ALL DOWNLOAD Mode)
7. When you connect phone to PC with USB, Modem is attached.
8. In PDA Status, check all the settings below are fine(default settings)
9. Select Model Name at ‘Model:’.
10. Press to start all download.
11. After PHONE is download first, the device will be re-booted automatically. And then CODE and CSC will be downloaded. If the phone is not re-booted automatically, detach the usb cable of the phone and power off. Power on with 1+4 key pressed, and the re-attach to PC. Then PDA binary will be downloaded automatically.
ii. PHONE Download Only
1. Proceed from the step’i-1.’ to ’i-3.’
2. Turn on the device with 7 + * key pressed(Modem Download Mode)
3. Do from ‘i.-7’ to ‘i.-9’.
4. Press button to start download.
iii. CODE + CSC Download Only
1. Do ‘i.-1’ , ‘i-3’, ‘i-4’, ‘i-5’.
2. Turn on the device with 1 + 4 key pressed and connect to PC to attach PDA part.
3. Do ‘i.-8’.
4. Press button to start PDA download.
iv. CODE Download Only
1. In myProject, Download CODE Release and unzip.
2. Do ‘i.-3’~’i-5’.
3. Power On the phone with 1 + 4 key pressed and connect to PC with USB to attach PDA part.
4. At PDA Status, Select ‘CODE’. Check options like this.
5. Press button to start download.
v. CSC Download Only
1. In myProject, download CSC Release and unzip.
It is impossible to download only with CSC Release in case of some Releases(before 2008/09/11 version) . In this case, to download the binary find CODE binary first that is mapped the CSC you want to download, in myProject. Unzip CODE, and overwrite the CSC and then Do things below.
2. Do ‘i.3~5’.
3. Power on the phone with 1 + 4 key pressed. Connect the device to PC then PDA is attached.
4. Select CSC at PDA Status. Uncheck ‘Bootloader’ option.
5. Press to start download.
7. Troubleshooting
A. If the device is not attached after the Driver installation,
i. Change USB Cable and Phone.
ii. Try with another PC.
iii. Consult R&D Team.
B. Download stops in the middle
i. Close and launch Apollo again then try again.
ii. Check the phone is charged enough.
C. Download doesn’t start
i. Check the connection between Apollo and a phone.
ii. Select an image again.
iii. Check the image is not damaged.
iv. Check Apollo version matches with the image.
D. Phone doesn’t boot up after downloading
i. Check CODE, CSC and PHONE Vesion
good luck
The Following 70 Users Say Thank You to allal123 For This Useful Post:
Old 10-14-2008, 16:21   #3 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,261
Good job man
keep it up like this all the time
good flashing for all
The Following 2 Users Say Thank You to tsarkh For This Useful Post:
Old 10-14-2008, 17:17   #4 (permalink)
Member: 460864
Hi
This version firmware have polish language??
Thanks for recipient.. and sorry for my English..
Old 10-14-2008, 17:20   #5 (permalink)
Temporary banned !!
Member: 69157
Sonork: 100.107865
Thanks Meter: 471
No. Both files are for Russian
The Following User Says Thank You to Mickey Mouse For This Useful Post:
Old 10-14-2008, 17:28   #6 (permalink)
bigboy85's Avatar
Member: 682554
Sonork: 1601123
Thanks Meter: 222
hi mates those firware has spanish lenguage inside?
and by the way thanks for share all this information thats greeeat!!
Old 10-15-2008, 08:54   #7 (permalink)
Member: 148908
Thanks Meter: 115
thanks very good working %
The Following User Says Thank You to max0066 For This Useful Post:
Old 10-15-2008, 09:32   #8 (permalink)
Member: 3279
Thanks Meter: 19
i am looking for chinese language with simple chinese input
Old 10-15-2008, 20:49   #9 (permalink)
Member: 848659
So has anyone tried it yet and what all does it do ?
The Following User Says Thank You to diddlyday For This Useful Post:
Old 10-15-2008, 20:55   #10 (permalink)
Member: 205475
Thanks Meter: 177
good work man but if u can give us arabic languag
Old 10-15-2008, 23:53   #11 (permalink)
Member: 876977
what exactly is this firmware for?
I have just got the samsung innov8 i8510 8gb, But I am wondering what all this firmware stuff does, i cannot find it anywhere on the internet.
1. Is it unofficial firmware?
2. is it better than the official firmware?
3. What is Apollo? what does it do?
I am just wondering what i can do with my new phone so your help would be great thanks
Nirok
Old 10-16-2008, 09:33   #12 (permalink)
Member: 877146
Hi!
I ask an important question! THere is italian language with the new firmware?
Old 10-16-2008, 20:08   #13 (permalink)
Member: 72679
Thanks Meter: 19
does it contain english language
and it compatable with the unlocked phone
Old 10-16-2008, 20:33   #14 (permalink)
Member: 233729
Thanks Meter: 13
Nirok
Hi mate,
Q: I am wondering what all this firmware stuff does?
A: It debrand phones.
Q: Is it unofficial firmware?
A: Its official firmware released by Samsung.
Q: Is it better than the official firmware?
A: If you are russain then I8510XEHI5 is unique firmware to debrand your newly I8510.
Q: What is Apollo? what does it do?
A: Apollo is the downloader, which allows I8510XEHI5 official firmware to download on I8510.
Note: I8510XEHI5 is consist language pack of Russain or Romanian etc.
Best Regards
H.S
The Following User Says Thank You to Hellosamir For This Useful Post:
Old 10-16-2008, 20:36   #15 (permalink)
Member: 233729
Thanks Meter: 13
Hi mate,
Yes it has english language and compatable on unlocked phone.
Best Regards
H.S
i8910 OMNIA SAMSUNG FIRMWARE + DOWNLOADER + DRIVERS + MANUAL allal123 Samsung Flashers, Software, Firmware. 114 03-10-2015 11:47
I8510 innov8 samsung croatian language trabant gti Samsung Flashers, Software, Firmware. 0 04-14-2009 10:37
Samsung i8510 INNOV8 - 16GB (Unlocked) IPMART ipmart WebShop 0 12-23-2008 06:40
Page generated in 0.50222 seconds with 9 queries
