Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: www.heidari-gsm.com Age: 25
Member: 44742 Status: Offline Thanks: 82
| The method here is rather straightforward. It has been tested on my two D500 phones without a single problem 1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them. 2. Active your IR connection or hook your USB cable into the phone. For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring. For USB connection, the one I tested is from fonefunshop 3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done. 4. Run 'Uploader.exe' program and add a jad file. 5. Enable Serial Java download - #*536963#. 6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off! Select second option - "2.Serial Download" 7. Let upload and softick PPP access the net if you installed a firewall. -More details-------------------------------------------------------- If you are using a USB cable, please take the following steps: 1. deactive Softick PPP, and exit it. 2. connect the cable, 3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again. 4. run Softick PPP 5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 \Device\ss_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem) 6. active Softick PPP. 7. run Uploader.exe 8. ...... For IR users, 1. deactive Softick PPP, and exit it. 2. active your IR connection。 3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....' 4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again. 5. run Softick PPP. 6. enable IRDA interface support in 'Settings->Options' 7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 \Device\0000010b', if not, go back to the first step 8 .... please choose USB in '1 PPP UP' for your IR connection If you do see the progress bar but the phone freezes for a couple of seconds and then it reboots itself, it may mean that the connection is all right, but the Softick PPP is not actived or your device is not ticked in settings. Please also check your firewall settings to let Softick PPP and uploaded.exe access the net and act as a server. Have fun. saeed-gsm |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks: 114
| Quote:
yeah what ever! @saeed thanks bro keep it up! | |
| | #7 (permalink) |
| Junior Member Join Date: Jun 2006
Member: 301084 Status: Offline Thanks: 0
| here on my web space i can only leave on for 4 a while goto here http://mysite.orange.co.uk/javastuff |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to install Java games on Nokia 6600? | weimings | Java, iOS, Android, Symbian development | 1 | 01-22-2009 10:04 |
| how I can install java games on samsung e730? | feddy22 | Samsung Media, Games, Ringtones | 1 | 12-28-2005 23:56 |
| How to install java games on 902SH??? | mnn | Sharp | 0 | 10-22-2005 17:16 |
| Installing java games on x60 | markguar85 | Panasonic | 0 | 08-31-2005 12:40 |
| How can I install java games on X-5???? | Khala_Manson | Wallpaper, Applications, RingTones, etc | 0 | 08-02-2005 17:49 |
