Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 03-21-2014, 12:41   #1 (permalink)
Member: 661195
Thanks Meter: 31
Unhappy N7100 stuck at samsung logo
I have n7100 stuck at Samsung logo.I try to flash many time with many firmware with Odin.but fail.can't enter recovery mode.When I press Vol up+Home+Power to enter recovery mode, show android guy for a few second and phone will restart.
product name:GT-N7100
CUSTOM BINARY DOWNLOAD:NO
CURRENT BINARY:OFFICIAL
SYSTEM STATUS:OFFICIAL
I try sd card method.Tera term showing
PMIC rev = PASS2(4)
mmc_initialize: mmc->capacity = 30777344
þ
+UART READY
after nothing.is Emmc chip error?solution please.
can someone upload N7100 multiple firmware package.
Thanks,
[email protected]
Old 03-21-2014, 17:44   #2 (permalink)
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 2,563
What version was the phone?
And try to change battery
Regards,
Axecom
Old 03-21-2014, 19:03   #3 (permalink)
hand2hand's Avatar
Member: 1476841
Thanks Meter: 201
1.....software
2,,,efs repair
3.emmc ic repair by gpg ya atf box
same p[roblem
final change emmc ic
The Following User Says Thank You to hand2hand For This Useful Post:
Old 03-21-2014, 19:32   #4 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
1. Has the phone been rooted or modified in any way?
2. Are you running a custom rom?
3. Were you flashing something when this happened?
4. Or is the phone 100% stock?
5. And lastly did you try charging it while off with the OEM charger and cable until the LED light turns green?
Old 03-21-2014, 19:36   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
First, if you are rooted, I HIGHLY ADVISE you to make a backup ROM (see How to Make Backup ROM). And after making backup ROM, do MAKE A BACKUP of your internal storage by copying everything to your hard disk. If something goes wrong, you will be able to do a factory reset in stock Android recovery and get all of your settings, apps, photos, and videos back.
Also, if you are on a ROM like CM10, AOKP, or any ROM that’s non-Samsung, non-TouchWiz, you will definitely need to do a factory reset. You can also do a factory reset in CWM Recovery BEFORE unrooting, that will not erase the contents of your internal storage (then you can skip the backups).
If you are returning your phone for warranty, run Triangle Away app before unrooting, that will erases any traces of root. (Also installing a stock firmware DOES NOT increase binary count.)
This method is using ODIN and Windows computer. If you have Linux or Mac computer, you can also use Mobile ODIN PRO (on Play Store) to do the same thing.
Unroot/unbrick your Galaxy Note 2.
Go to either Samsung-updates or SamFirmware and download a compatible stock firmware for your Galaxy Note 2. For example, if you have the international Galaxy Note 2, search for model GT-N7100 and download the appropriate firmware for your country. If your country firmware does not exist you can use one that’s close to it, these firmwares will work on all GT-N7100.
And flash again with odin
Old 06-16-2015, 18:31   #6 (permalink)
Member: 2400462
Sonork: 100.1667107
Thanks Meter: 4
if you get recovery mode u just need reset efs otherwise you need change emmc chip
Old 06-16-2015, 19:26   #7 (permalink)
Cheater -Don't Deal with him-
Member: 2408477
Thanks Meter: 50
try to flash Samsung repair File in odin 3.7
Page generated in 0.13578 seconds with 8 queries
