Need HELP fast!!!! Ok, i just got my cable for my E700, its the cable for e700/s500, how am i supposed to do now? Do i leave the simcard in it? Do i need to leave the battery in it? Do i need to start the telephone when im gonna write Imei, please help me... I want to change the Imei because its locked, do i need to flash anyway? What I need to know is how iam supposed to do "step by step" with my phone to write new Imei and wích programs I need to get! Do i need any drivers for my computer to recognise my phone? (Com port) It says my Version is: PE700.05 E700CGDC4 ????? I´ve tried to search but dont fin answers to my questions! :rolleyes: |
what do u want to do to ur e700 make it clear b4 u start ur stiory man..... ur post makes no sense repost ur objective |
Better now? ;) |
read posts about e700 unlock, just follow the link http://forum.gsmhosting.com/vbb/foru...to_forumsearch then tip "E700 unlock" and read about in this forum! All i know that you don't need cabel and pc to unlock e700, the code will be enough, but you can use nasirian samsung tool for v200,s500,e710 imei changer and unlocker i think it would work with e700! good luck !!!!! =;P |
U CAN TRY TO TIP THIS CODE : *2767*688# , BUT I THINK THAT IN PHONE MUST BE INSERTED NON ACCEPTABLE SIM-CARD, AND THEN TIP THIS CODE! I DIDN'T TRY BUT OTHERS SAYS IT WORKS! TO CHANGE IMEI USE "UST 6 PRO" or NASIRIYAN SAMSUNG TOOLS link FOR subject in forum (links 4 download included under subject)-> http://forum.gsmhosting.com/vbb/show...X100_E710_S500 |
Ive got this cable!!!!!!!!!! http://unlockeasy.com/catalog/product_info+1036.html Bought it in sweden but its the same as on the site!!! |
I tried Nasiriyan tools but when i tried to re write IMEI it just said "12 section Not Exist"...????? |
Ok, WINimei seems to work, WHAT should i change my IMEI to??? Wich numbers do i need to change and to what numbers? just any numbers or do i need to calculate? Please answer fast, tried to search on samsung but didnt find any, sorry :( Can i for ex. take an IMEI from my old sgh 210r and use it instead? EDIT: I´ve tried to change the IMEI in WINIMEI, everything works fine but it doesnt change the iemi, i still have the same imei? First i pressed NEW, then i filled in some other numbers than my ordinary imei, then i pressed WRT IMEI and generated the code and everything worked but it didnt change the imei.. :( One more question, in the beginning you have to choose your country, i have several sweden choises but wich of them do i have to use? Sweden (TLA) Sweden (XEE) Sweden (COV) Sweden (TET) Sweden (TEN) Sweden (TDC) ??? What does those mean? I have main Vers. E700CGDC4 and H/W vers. MP 3.600 And im using WINimei ver. 2.11 |
oh good ! i will be join |
UST 6 Doesnt work...just get wrong message when it loads :( |
Made som progress, atleast the Network lock is gone, but i still need to change the IMEI! ;) |
@ forevo for nasriyan tool click test mode button first when it goes to 33% wait for about 2 minutes click in section where you enter the imei after you've entered imei then press the imei button nasriyan tools works, tested by many and me |
Hi, ivé tried both WINIMEI, ****ryian and other tools, none of them changes the IMEI on my e700, WINimei says it does but it doesnt, i still have the same, when i try with for ex. Samsung service tools by Myky it just says "illage data" when i press "read" button and then it says "12 Section Not Exist !" When i press "IMEI"...what is wrong? Do you have any working programs for e700? Doesnt anyone have or can make step by step pictures so that all noobs like me can follow them instead of making alot of threads ;) I just need to change the IMEI nothing more |
