Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-18-2014, 13:17 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | check "full download " add boot files then try again must work |
The Following User Says Thank You to luckymobile jalandhar For This Useful Post: |
03-18-2014, 13:20 | #3 (permalink) |
Insane Poster Join Date: Nov 2011 Location: cubao, quezon city
Member: 1691939 Status: Offline Sonork: 100.1653858 Thanks Meter: 17 | usb problem.. thick full download then choose the exact firmware... thick port search, u can see a frappe there, then thick it, then tick download |
The Following User Says Thank You to mtajwed For This Useful Post: |
03-18-2014, 14:34 | #7 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Please be sure to complete the following steps: Run Samsung S5230 Downloader and select BRCM2133. multiloader v5.67 - Download - 4shared If you want to flash Boot files then check: Full Download For Boot select the Boot files Folder from the Firmware folder which you want to use. For Apps select: apps_compressed.bin For Rsrc1 select: Rsrc_S5230_Open_Europe_Common.rc1 For Rsrc2 select: Rsrc2_S5230(Low).rc2 For Factory FS select: FactoryFs_S5230_Open_Europe_Common.ffs Put the phone into download mode: Press Volume down + Camera + Power. Connect the phone to PC by USB cable and click Port Search to make sure of good connection. Click Download to start the process and wait till the phone rebooted. Do full reset : *2767*3855# Firmwares Here: Files of : S5230 Folder You know you have to s5230 model? (G / H / R / K / M / N / W) or simply s5230 They are different firmwares |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-18-2014, 14:36 | #9 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | S5230 Star Files of : S5230 Folder S5230G Star Files of : S5230G Folder S5230H Star Files of : S5230H Folder |
