Samsung Ativ S I8750 (WP8) Hard Reset tutorial, firmware and flashing guide Samsung Ativ S I8750 Hard Reset by hardware button key combination 1. Make sure you have enough battery life. 2. Turn off the Ativ-S phone by pressing the power button and holding it for a few seconds then scroll down to turn off the phone. 3. Press the Volume Down Key + Power Key to turn on the unit 4. Still hold the volume down key, the release Power Key. 5. Wait for the startup screen booting with an exclamation mark " ! " then release the volume down key. 6. Press the following buttons in the following order: press the volume up (high volume key) ==> press volume key down (low volume key) ==> press the power key ==> press volume down key. 7. Wait a moment and look at the screen, a message such as loading new software will start the hard reset process tested and approuved |
The european unbranded version of the firmware and the flasher are now available on the support for the download Downloader WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe Firmware I8750XXAMA3_I8750TMOAMA3.zip BR Alex |
How to install the firmware? When I install qualcomm drivers , it gives me an error in cmd, when trying to scan INF files to cleanup |
thanks in advance |
Is this GDR2? If so, could you explain how to flash it? Thanks. |
GT-i8750 Ativ S flashing manual a) Unpack the file "GT-I8750_XXBME1_R_signed.zip" in the same folder where is the file "GT-I8750_OXABME1_R_SIGNED.csc" b) start the program WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe c) where is the orange folder select "GT-I8750 XXBME1_R_signed.wp8" d) where is the green folder select "GT-I8750_OXABME1_R_SIGNED.csc" e) In the area "dl option" tick "all" and "csc" f) Select ths csc code you may prefer between the shown ones (DBT, ATO,BTU,ITV,XEF,XEO) g) Put the mobile in download mode (pwr on + volume up + camera) and connect to the usb port (Install the drivers if needed - you can find them in This folder ) h) the mobile should be now visible on the flashing software software: click on Start and wait for the end of the process (about 6 minutes) http://www.xtcclip.co.uk/ativ_s.jpg BR Alex |
Thanks sir for a full guide...anyway i am stuck on drivers , System ask for Qualcomm Msm drivers, But i am unable to install them u provided the deivers . Tried on win Xp and 7, |
you can try these drivers too Zippyshare.com - I8750 FLASHTOOL+DRIVER.rar anyway in the folder "testcertificate" There is a certificate file and the following instructions Quote:
Alex |
I installed the test certificate, but when i try to install the driver it tells me : Failed to set attribute to "some sys", error 2 Failed to delete "same sys", error 2 and so for every sys ... I also tried installing the SamsungUSBDriver you provided as an alternative but my Ativ S isn't recognized. My system is Win7 and everything I tried was with Administrator rights... Can you help me ? :S |
Hello I am also trying to flash an ATIV S that won't boot but it's not being detected either. In Device Manager is appears as "USB DOWNLOADER" USB\VID_045E&PID_062B The screen itself shows a Windows Phone logo and below that a black arrow facing down inside of a yellow circle and beneath that it says "Download Mode" |
Download Done, the second drivers above u posted worked like a charm , But after flash need hardreset , thanks anyway once again ..... |
Help, I installed all ferraments for this rom and WP8_SMD_binary_USB_Downloader_Ver_3.2_completo and does not open the start button asim like this photo in an open way, please what does this missing flash this rom, I thank all |
can u plz share any other firmware for this phone , phone hangs on start up , worked with ur provided firmware for some days , re flashed again but no vain , further help will be appreciated , |
i have an ativ -s and i can't seem to be able to install the driver for the download mode... can you help me? |
