Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 06-11-2013, 09:40   #1 (permalink)
Member: 772951
Thanks Meter: 146
Samsung Ativ S I8750 (WP8) Hard Reset tutorial, firmware and flashing guide
Hard Reset by hardware button
key combination
1. Make sure you have enough battery life.
2. Turn off the Ativ-S phone by pressing the power button and holding it for a few seconds then scroll down to turn off the phone.
3. Press the Volume Down Key + Power Key to turn on the unit
4. Still hold the volume down key, the release Power Key.
5. Wait for the startup screen booting with an exclamation mark " ! " then release the volume down key.
6. Press the following buttons in the following order: press the volume up (high volume key) ==> press volume key down (low volume key) ==> press the power key ==> press volume down key.
7. Wait a moment and look at the screen, a message such as loading new software will start the hard reset process
tested and approuved
The Following 8 Users Say Thank You to imeis For This Useful Post:
Old 07-10-2013, 07:21   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,051
The european unbranded version of the firmware and the flasher are now available on the support for the download
Downloader
WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe
Firmware
I8750XXAMA3_I8750TMOAMA3.zip
Alex
Last edited by ...:::::NP™:::::...; 05-09-2017 at 14:32. Reason: Firmware & tools download link update
The Following User Says Thank You to moulnisky For This Useful Post:
Old 07-23-2013, 20:52   #3 (permalink)
Member: 1984858
How to install the firmware?
When I install qualcomm drivers , it gives me an error in cmd, when trying to scan INF files to cleanup
Old 08-03-2013, 18:28   #4 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Alex
can u update the procedure plz ,
thanks in advance
Old 08-05-2013, 18:14   #5 (permalink)
Member: 924867
Is this GDR2? If so, could you explain how to flash it? Thanks.
Old 08-06-2013, 20:47   #6 (permalink)
moulnisky's Avatar
Member: 947561
GT-i8750 Ativ S flashing manual
a) Unpack the file "GT-I8750_XXBME1_R_signed.zip" in the same folder where is the file "GT-I8750_OXABME1_R_SIGNED.csc"
b) start the program WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe
c) where is the orange folder select "GT-I8750 XXBME1_R_signed.wp8"
d) where is the green folder select "GT-I8750_OXABME1_R_SIGNED.csc"
e) In the area "dl option" tick "all" and "csc"
f) Select ths csc code you may prefer between the shown ones (DBT, ATO,BTU,ITV,XEF,XEO)
g) Put the mobile in download mode (pwr on + volume up + camera) and connect to the usb port (Install the drivers if needed - you can find them in This folder )
h) the mobile should be now visible on the flashing software software: click on Start and wait for the end of the process (about 6 minutes)
Alex
Old 08-06-2013, 21:01   #7 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Thanks sir for a full guide...anyway i am stuck on drivers ,
System ask for Qualcomm Msm drivers,
But i am unable to install them u provided the deivers . Tried on win Xp and 7,
Old 08-06-2013, 21:04   #8 (permalink)
moulnisky's Avatar
Member: 947561
you can try these drivers too
Zippyshare.com - I8750 FLASHTOOL+DRIVER.rar
anyway in the folder "testcertificate" There is a certificate file and the following instructions
============== How to Add Test Certificate ===============
Test certificate may need to be applied to Windows
before installing the USB host driver. A same certificate
will only need to be added once. Follow the steps listed
below to add test certificate to the system under test.
1. Launch Windows Explorer and locate the certificate
file qcusbtest.cer
2. Right-click on qcusbtest.cer and choose Install Certificate.
3. Follow instructions and place the certificate in the
following certificate stores:
Trusted Publishers
Trusted Root Certification Authorities
Step 1 through 3 will need to be repeated to place the certificate
in more than one certificate stores.
4. On Windows Vista, open a Command Prompt with "Run as
administrator" and issue the following command:
bcdedit -set testsigning on
For pre-Vista Windows versions, skip this step.
5. Reboot the system.
Alex
Old 08-06-2013, 21:06   #9 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Alex
Thanks one again .. Will test tomorrow and post result ..
The Following User Says Thank You to shahjee For This Useful Post:
Old 08-07-2013, 14:48   #10 (permalink)
Member: 1996270
I installed the test certificate, but when i try to install the driver it tells me :
Failed to set attribute to "some sys", error 2
Failed to delete "same sys", error 2
and so for every sys ...
I also tried installing the SamsungUSBDriver you provided as an alternative but my Ativ S isn't recognized.
My system is Win7 and everything I tried was with Administrator rights...
Can you help me ? :S
Old 08-09-2013, 23:12   #11 (permalink)
Member: 197391
Thanks Meter: 2
Hello I am also trying to flash an ATIV S that won't boot but it's not being detected either.
In Device Manager is appears as "USB DOWNLOADER"
USB\VID_045E&PID_062B
The screen itself shows a Windows Phone logo and below that a black arrow facing down inside of a yellow circle and beneath that it says "Download Mode"
The Following User Says Thank You to petard For This Useful Post:
Old 08-17-2013, 11:01   #12 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Alex
Thanks Sir with ur guide phone flashed ,
Download Done,
the second drivers above u posted worked like a charm ,
But after flash need hardreset ,
thanks anyway once again .....
Old 08-17-2013, 23:25   #13 (permalink)
Member: 2004377
Help, I installed all ferraments for this rom and WP8_SMD_binary_USB_Downloader_Ver_3.2_completo and does not open the start button asim like this photo in an open way, please what does this missing flash this rom, I thank all
Old 09-07-2013, 10:07   #14 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Alex
hello sir ,
can u plz share any other firmware for this phone ,
phone hangs on start up ,
worked with ur provided firmware for some days ,
re flashed again but no vain ,
further help will be appreciated ,
Old 09-12-2013, 14:20   #15 (permalink)
Member: 2024027
i have an ativ -s and i can't seem to be able to install the driver for the download mode... can you help me?
Page generated in 0.25662 seconds with 9 queries
