Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-11-2013, 09:40 | #1 (permalink) |
Freak Poster Join Date: May 2008 Age: 48
Member: 772951 Status: Offline Thanks Meter: 146 | Samsung Ativ S I8750 (WP8) Hard Reset tutorial, firmware and flashing guide Samsung Ativ S I8750 Hard Reset by hardware button key combination 1. Make sure you have enough battery life. 2. Turn off the Ativ-S phone by pressing the power button and holding it for a few seconds then scroll down to turn off the phone. 3. Press the Volume Down Key + Power Key to turn on the unit 4. Still hold the volume down key, the release Power Key. 5. Wait for the startup screen booting with an exclamation mark " ! " then release the volume down key. 6. Press the following buttons in the following order: press the volume up (high volume key) ==> press volume key down (low volume key) ==> press the power key ==> press volume down key. 7. Wait a moment and look at the screen, a message such as loading new software will start the hard reset process tested and approuved |
The Following 8 Users Say Thank You to imeis For This Useful Post: |
07-10-2013, 07:21 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | The european unbranded version of the firmware and the flasher are now available on the support for the download Downloader WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe Firmware I8750XXAMA3_I8750TMOAMA3.zip BR Alex Last edited by ...:::::NP™:::::...; 05-09-2017 at 14:32. Reason: Firmware & tools download link update |
The Following User Says Thank You to moulnisky For This Useful Post: |
08-03-2013, 18:28 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Quote:
thanks in advance Last edited by moulnisky; 10-09-2013 at 23:13. | |
08-06-2013, 20:47 | #6 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | GT-i8750 Ativ S flashing manual a) Unpack the file "GT-I8750_XXBME1_R_signed.zip" in the same folder where is the file "GT-I8750_OXABME1_R_SIGNED.csc" b) start the program WP8_SMD_binary_USB_Downloader_Ver_3.2_(Fix_Stabili ty_Issue).exe c) where is the orange folder select "GT-I8750 XXBME1_R_signed.wp8" d) where is the green folder select "GT-I8750_OXABME1_R_SIGNED.csc" e) In the area "dl option" tick "all" and "csc" f) Select ths csc code you may prefer between the shown ones (DBT, ATO,BTU,ITV,XEF,XEO) g) Put the mobile in download mode (pwr on + volume up + camera) and connect to the usb port (Install the drivers if needed - you can find them in This folder ) h) the mobile should be now visible on the flashing software software: click on Start and wait for the end of the process (about 6 minutes) BR Alex Last edited by moulnisky; 10-09-2013 at 04:32. |
08-06-2013, 21:01 | #7 (permalink) |
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Thanks sir for a full guide...anyway i am stuck on drivers , System ask for Qualcomm Msm drivers, But i am unable to install them u provided the deivers . Tried on win Xp and 7, |
08-06-2013, 21:04 | #8 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | you can try these drivers too Zippyshare.com - I8750 FLASHTOOL+DRIVER.rar anyway in the folder "testcertificate" There is a certificate file and the following instructions Quote:
Alex | |
08-06-2013, 21:06 | #9 (permalink) | |
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Quote: | |
The Following User Says Thank You to shahjee For This Useful Post: |
08-07-2013, 14:48 | #10 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1996270 Status: Offline Thanks Meter: 0 | I installed the test certificate, but when i try to install the driver it tells me : Failed to set attribute to "some sys", error 2 Failed to delete "same sys", error 2 and so for every sys ... I also tried installing the SamsungUSBDriver you provided as an alternative but my Ativ S isn't recognized. My system is Win7 and everything I tried was with Administrator rights... Can you help me ? :S |
08-09-2013, 23:12 | #11 (permalink) |
Junior Member Join Date: Nov 2005
Member: 197391 Status: Offline Thanks Meter: 2 | Hello I am also trying to flash an ATIV S that won't boot but it's not being detected either. In Device Manager is appears as "USB DOWNLOADER" USB\VID_045E&PID_062B The screen itself shows a Windows Phone logo and below that a black arrow facing down inside of a yellow circle and beneath that it says "Download Mode" |
The Following User Says Thank You to petard For This Useful Post: |
08-17-2013, 11:01 | #12 (permalink) | |
Download Done, the second drivers above u posted worked like a charm , But after flash need hardreset , thanks anyway once again ..... | |
08-17-2013, 23:25 | #13 (permalink) |
Member: 2004377 Status: Offline Thanks Meter: 0 | Help, I installed all ferraments for this rom and WP8_SMD_binary_USB_Downloader_Ver_3.2_completo and does not open the start button asim like this photo in an open way, please what does this missing flash this rom, I thank all |
09-07-2013, 10:07 | #14 (permalink) | |
can u plz share any other firmware for this phone , phone hangs on start up , worked with ur provided firmware for some days , re flashed again but no vain , further help will be appreciated , Last edited by moulnisky; 10-09-2013 at 23:13. | |
