samsung c3222 phone lock samsung c3222 phone lock . how to solved . can i solved with out box. i have hwk , can i unlock via usb by hwk. thanks in advanced. |
I need the unlock code for the samsung sgh-t459 gravity please!!!!!! |
i am very new at unlocking so i will be grateful for advice on which wayto go |
In display phonelock code try to call emergency on top right button. After connect insert code *2767*3855# After disconnect delete # only and write # again, and ur phone will reset and restart. Tested by me 100000% GOOD LUCK BRO..... :):):) Note: All data in phone will erase |
HWK support C3222 RJ45 cable only, usb not support.. |
C3222 PHONE LOCK DONE WITH Z3X 1. remove battery from phone 2. press and hold volume down and sim swaping button on the right top side of the phone 3. inset usb cable ,phones enter in DFU mode use direct unlock option http://i48.tinypic.com/fvioon.jpg br, !!M.AW@!S!! |
i need samsung driver pack 1.3 |
--------------------------- 5/9/2013 5:37:48 PM ----------------------------- Selected model: C3222 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222WDSKC4 Phone CSC: C3222WXSEKC4 Phone BT ADDR: 0007-AB-FC574B Phone IMEI: 35704404117872 Deactivated MSL - FAIL Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222WDSKC4 Phone CSC: C3222WXSEKC4 Phone BT ADDR: 0007-AB-FC574B Phone IMEI: 35704404117872 Deactivated MSL - FAIL Elapsed time: 20 second, sw ver: 3.5.0040 ---------------------------------------------------------------------------- ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM6 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Aborted by user Elapsed time: 2069 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- when use usb show popup "Access violation at address 007B6C5C in module 'Samsung.exe'. Read of address 00000000." then the program stop work something wrong with my procedure??? |
In display phonelock code try to call emergency on top right button. After connect insert code *2767*3855# After disconnect delete # only and write # again, and ur phone will reset and restart. Tested by me 100000% GOOD LUCK BRO..... Note: All data in phone will erase thank's bro it's amazing |
C3222 PHONE LOCK DONE WITH Z3X 1-remove battery 2-insert micro usb cable to phone 3- insert micro usb to z3x box 4-press read info (codes) button 5-wait untill software shows finish work 6-then remove the phone and turn on 6-then insert the code shows (FREEZE): means freeze code is phone lock code http://img208.imageshack.us/img208/2663/69693726.jpg |
In display phonelock code try to call emergency on top right button. After connect insert code *2767*3855# After disconnect delete # only and write # again, and ur phone will reset and restart. Tested by me 100000% yes its done thax very much grt job |
samsung c3222 phone lock Quote:
nice solution for z3x user.. thanku sir. |
