Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 11-10-2012, 16:53   #1 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 199
samsung c3222 phone lock
samsung c3222 phone lock . how to solved . can i solved with out box. i have hwk , can i unlock via usb by hwk. thanks in advanced.
Old 11-10-2012, 17:07   #2 (permalink)
Member: 1834645
I need the unlock code for the samsung sgh-t459 gravity please!!!!!!
Old 11-10-2012, 17:09   #3 (permalink)
Member: 1834645
i am very new at unlocking so i will be grateful for advice on which wayto go
Old 11-10-2012, 17:20   #4 (permalink)
Member: 622382
Thanks Meter: 199
open new thread. why u post other thread, u r brand or problem difrent. why u post other thread.
Old 11-10-2012, 22:48   #5 (permalink)
.::GEANECIV::.'s Avatar
Member: 853097
Sonork: 100.1622287
Thanks Meter: 129
In display phonelock code try to call emergency on top right button.
After connect insert code *2767*3855#
After disconnect delete # only and write # again, and ur phone will reset and restart.
Tested by me 100000%
GOOD LUCK BRO.....
Note: All data in phone will erase
Old 11-10-2012, 22:59   #6 (permalink)
Member: 853097
Sonork: 100.1622287
Thanks Meter: 129
HWK support C3222 RJ45 cable only, usb not support..
The Following User Says Thank You to .::GEANECIV::. For This Useful Post:
Old 11-11-2012, 05:57   #7 (permalink)
Member: 622382
Thanks Meter: 199
GOOD LUCK BRO.....
thanks for help. this proced work for me
Old 01-04-2013, 16:25   #8 (permalink)
m.awais.as's Avatar
Member: 1284347
Sonork: 100.1592292
Thanks Meter: 974
C3222 PHONE LOCK DONE WITH Z3X
1. remove battery from phone
2. press and hold volume down and sim swaping button on the right top side of the phone
3. inset usb cable ,phones enter in DFU mode
use direct unlock option
br,
[email protected]!S!!
The Following 2 Users Say Thank You to m.awais.as For This Useful Post:
Old 01-04-2013, 18:32   #9 (permalink)
Member: 424895
Thanks Meter: 3
i need samsung driver pack 1.3
Old 05-09-2013, 12:39   #10 (permalink)
Member: 1306217
Thanks Meter: 17
--------------------------- 5/9/2013 5:37:48 PM -----------------------------
Selected model: C3222
Selected com port: COM6
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone SW: C3222WDSKC4
Phone CSC: C3222WXSEKC4
Phone BT ADDR: 0007-AB-FC574B
Phone IMEI: 35704404117872
Deactivated MSL - FAIL
Elapsed time: 33 second, sw ver: 3.5.0040
Phone Detected
Phone in TAT MODE
Elapsed time: 20 second, sw ver: 3.5.0040
Press "volume down" + "lock" and connect USB cable to phone
Connect to control pipe... OK
Aborted by user
Elapsed time: 2069 second, sw ver: 3.5.0040
when use usb show popup
"Access violation at address 007B6C5C in module 'Samsung.exe'. Read of address 00000000."
then the program stop work
something wrong with my procedure???
Old 05-12-2013, 12:27   #11 (permalink)
Member: 1935752
Thanks Meter: 2
GOOD LUCK BRO.....
thank you for this info i will try and see
Old 05-26-2013, 16:35   #12 (permalink)
Member: 1398380
GOOD LUCK BRO.....
thank's bro it's amazing
Old 06-13-2013, 12:02   #13 (permalink)
Member: 1417077
Sonork: 100.1626477
Thanks Meter: 30
1-remove battery
2-insert micro usb cable to phone
3- insert micro usb to z3x box
4-press read info (codes) button
5-wait untill software shows finish work
6-then remove the phone and turn on
6-then insert the code shows (FREEZE):
means freeze code is phone lock code
Old 04-22-2014, 05:43   #14 (permalink)
mccecc's Avatar
Member: 140564
Thanks Meter: 15
yes its done thax very much grt job
Old 10-01-2014, 15:32   #15 (permalink)
Member: 1181277
Thanks Meter: 13
Thumbs up samsung c3222 phone lock
br,
nice solution for z3x user..
thanku sir.
Page generated in 0.66078 seconds with 7 queries
