Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 08-21-2013, 15:16   #1 (permalink)
SAYAN_KULTI's Avatar
Member: 1338657
Sonork: 100.1620835
Thanks Meter: 159
samsung e1207t blinking & imei reper solution
1, flash by og flasher
CONNECT Z3X BOX , USE E210 RJ45 CABLE & SELECT COM PORT
AFTER FLASH BLINKING DONE BUT IMEI 000000000000000
2,OPEN Z3X SELECT MODEL E1202 & REPAIR CUSTOM
The Following 3 Users Say Thank You to SAYAN_KULTI For This Useful Post:
Old 08-21-2013, 15:20   #2 (permalink)
Member: 1293395
Sonork: 100.1657302
Thanks Meter: 87
flash tool plzzzzzzzzzzz
Old 08-21-2013, 16:12   #3 (permalink)
Member: 1338657
Sonork: 100.1620835
Thanks Meter: 159
Download samsung E1207T flasher.rar from Sendspace.com - send big files the easy way
HERE DAWNLODE LINK, ENJOY,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 08-21-2013, 16:21   #4 (permalink)
.::PankajMobileWorld::.'s Avatar
Member: 1910515
Thanks Meter: 289
http://forum.gsmhosting.com/vbb/f200...-hare-1612689/
Old 12-23-2013, 20:01   #5 (permalink)
Member: 1146989
Thanks Meter: 6
e1207t Blinkingsolution
First Erase Nor then Flash then only blinking problem solved 100%%%%%%%%%%%%%%
Old 01-29-2014, 15:49   #6 (permalink)
Member: 955009
Thanks Meter: 13
succesfully flashed without imie lost and no need to repair imei thanks
Old 04-30-2014, 15:32   #7 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Imei repair successfully
The Following User Says Thank You to papoo For This Useful Post:
Old 07-29-2014, 09:01   #8 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 161
Selected speed port: 230400
Please, connect phone and press power button 3 seconds
Phone Detected
Sending loader1... OK
Flash ID: F816
Sending loader2... OK
Please wait for patching firmware...
Patch block
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone master IMEI: 00000000000000
Phone slave IMEI: 00000000000000
Phone SW: E1207TDDMJ1
Phone CSC: E1207TODDLJ2
Phone BT ADDR: 0000-00-000000
Phone SN: RZ1DC073M7
Deactivated MSL - TRUE
Write master imei - ok
Write slave imei - ok
Repair - ok
Elapsed time: 128 second, sw ver: 3.5.0040
Prosis Done But Imei Still Same 0000000000000
Old 11-02-2014, 09:29   #9 (permalink)
johnaccell's Avatar
Member: 1215525
Thanks Meter: 25
helpfull post.
tested file and procedure
Old 10-06-2017, 05:40   #10 (permalink)
Member: 2166052
Sonork: 100.1678339
Thanks Meter: 56
Normal Cable works or not ??
Old 10-06-2017, 05:58   #11 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,107
Hi,
You can use com interface RJ45 cable, which SAM Tool box J750 cable do you have.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Page generated in 0.19865 seconds with 8 queries
