Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
01-12-2012, 13:51 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,976 | Samsung e2652 successfully flash done with flasher . Samsung e2652 successfully flash done with flasher . here driver & flasher flashtool_e2_rou.zip - 4shared.com - online file sharing and storage - download here flash file . Hotfile.com: One click file hosting: E2652XEKB2.rar Gide here for flash .
here more with done logo . 1st step 2nd step azimbahar |
The Following 8 Users Say Thank You to aZimBahar For This Useful Post: |
01-13-2012, 13:25 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | Device synchronized. Injecting EBL-Loader (RPSI). Injecting EBL Boot-loader is active EBL version: 6180_Bootloader_10.0_MKEYSKEY 10..0 Boot mode is: BB Using: Faster CRC, Writing all blocks Package length is 16384 - protocol: 3.32 Baud rate set to 921600 Get flash id. CFI stage 1 Flash ID is: 220800EC CFI stage 2 Boot process finished Start downloading item 'CODE:CATFISH.fls'' from file 'F:\z3x\e2650\E2652XEKB2\E2652XXKB2\E2652XXKB2_BIN .fls''. Erasing all flash memory Sending sec-pack. Load region 0 Use flash pre-erase. Sending data. WARNING: Target EBL does not support NVM handling Sending end-pack. Checksum OK (0xC525) Verify OK Process time was 2 min 54 sec. Start downloading item 'CODE:CATFISH.fls'' from file 'F:\z3x\e2650\E2652XEKB2\E2652XXKB2\E2652XXKB2_CDS .fls''. Sending sec-pack. Load region 0 Use flash pre-erase. Sending data. WARNING: Target EBL does not support NVM handling Sending end-pack. Checksum OK (0x558F) Verify OK Process time was 3.2 sec. Start downloading item 'CUST:temp_GT-E2652_OXE.dffs'' from file 'F:\z3x\e2650\E2652XEKB2\E2652XXKB2\E2652OXEKB2_CS C.dffs''. Sending sec-pack. Load region 0 Use flash pre-erase. Sending data. Sending end-pack. Verify OK Process time was 1 min 35 sec. Start downloading item 'CODE:temp_UI_IMAGE.fls'' from file 'F:\z3x\e2650\E2652XEKB2\E2652XXKB2\E2652XXKB2_UI_ IMAGE.fls''. Sending sec-pack. Load region 0 Use flash pre-erase. Sending data. WARNING: Target EBL does not support NVM handling Sending end-pack. Checksum OK (0xFE03) Verify OK Process time was 19.8 sec. Start downloading item 'BOOT CORE SLB:dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls'' from file 'F:\z3x\e2650\E2652XEKB2\E2652XXKB2\E2652XXKB2_psi _flash.fls''. Sending sec-pack. Load region 0 Use flash pre-erase. Sending data. Sending end-pack. Checksum OK (0x8005) Verify OK Process time was 1875 msec. Total time was 5 min 1 sec. Channel 1 is succesfully closed. |
02-05-2012, 11:47 | #10 (permalink) | |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,976 | Quote:
02-06-2012, 14:56 | #12 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | Process time was 30.0 sec. An EBL must be injected. None was found in the downloaded file. For some systems there must be an injected EBL. The file specified for download does not contain an injected EBL. Check that the file is correct for the target. This error can also occur on a normal boot time out, in which case just try again. Channel 1 is succesfully closed. |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
