Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
10-08-2008, 20:51 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 376497 Status: Offline Thanks Meter: 0 | Samsung E490 flash problem Samsung Rocker v1.06g Loaded 400 models Avaiable COM ports: , COM1, COM3 ThreadGUI started ThreadProtocol started OS: NT family, Ver:5.1 Boot loader protocol type: passive Memory interface type: 1 Setup loader: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fsl3.sre Setup loader base addr: 0x00000000 Flash loader: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre Flash loader base addr: 0x30000000 Stack base addr: 0x20000000 Stack buffers: 1 0: 0x20000000 - 0x23ffffff [64 MB (67108864 Bytes)] Opened COM3 at 115200 baud PC transfer speeds (COM3): 57600 115200 230400 460800 921600 Loading S-record file (RangeCheck=Off) File: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fsl3.sre SRE line 181: IGNORING: S70500000000FA There is 1 memory region in the S-record file: 1: 0x00000000 - 0x00000b3f = 2880 Bytes Loading S-record file (RangeCheck=Off) File: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre SRE line 31857: IGNORING: S70530000000CA There is 1 memory region in the S-record file: 1: 0x30000000 - 0x3007c6f7 = 509688 Bytes Loading S-record file (RangeCheck=On) File: D:\GSM\E490_firmware\E490XEGB1_s3.s3 SRE line 3547: IGNORING: S70520020000D8 SRE line 3548: IGNORING: S011000070616870655F72666132652E7333DD SRE line 4720: IGNORING: S70520010000D9 SRE line 4805: IGNORING: S70520040000D6 SRE line 4808: IGNORING: S70520000000DA SRE line 4811: IGNORING: S70522000000D8 SRE line 1482114: IGNORING: S70520042000B6 SRE line 1498261: IGNORING: S70521FC0000DD There are 7 memory regions in the S-record file: 1: 0x20000000 - 0x2000001b = 28 Bytes 2: 0x20010000 - 0x20014927 = 18728 Bytes 3: 0x20020000 - 0x2002dd93 = 56724 Bytes 4: 0x20040000 - 0x20040533 = 1332 Bytes 5: 0x20042000 - 0x216ccb5b = 23636828 Bytes 6: 0x21fc0000 - 0x21fff117 = 258328 Bytes 7: 0x22000000 - 0x22000017 = 24 Bytes SendFile=D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre, Mode=3 Power on mobile ! TalkToBootLoader (using COM3) Talking to passive bootloader Bootloader V1.1 using UART1 ROM mask ID: 0x000200a3 ( ) ID register: 0x000200a3 (ES2) Bootloader type: 6 (0) Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 2880 bytes in 1 region(s) Send: 0x00000000 - 0x000006ff (=1792) Send: 0x00000700 - 0x00000b3f (=1088) Talking to setup loader Setup loader V1.1 using UART1 Setup loader type: 4 Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 509688 bytes in 1 region(s) Send: 0x30000000 - 0x300006ff (=1792) Send: 0x30000700 - 0x30000dff (=1792) Send: 0x30000e00 - 0x300014ff (=1792) Send: 0x30001500 - 0x30001bff (=1792) Send: 0x30001c00 - 0x300022ff (=1792) Send: 0x30002300 - 0x300029ff (=1792) Send: 0x30002a00 - 0x300030ff (=1792) Send: 0x30003100 - 0x300037ff (=1792) Send: 0x30003800 - 0x30003eff (=1792) Send: 0x30003f00 - 0x300045ff (=1792) Send: 0x30004600 - 0x30004cff (=1792) Send: 0x30004d00 - 0x300053ff (=1792) Send: 0x30005400 - 0x30005aff (=1792) Send: 0x30005b00 - 0x300061ff (=1792) Send: 0x30006200 - 0x300068ff (=1792) Send: 0x30006900 - 0x30006fff (=1792) Send: 0x30007000 - 0x300076ff (=1792) Send: 0x30007700 - 0x30007dff (=1792) Send: 0x30007e00 - 0x300084ff (=1792) Send: 0x30008500 - 0x30008bff (=1792) Send: 0x30008c00 - 0x300092ff (=1792) Send: 0x30009300 - 0x300099ff (=1792) Send: 0x30009a00 - 0x3000a0ff (=1792) Send: 0x3000a100 - 0x3000a7ff (=1792) Send: 0x3000a800 - 0x3000aeff (=1792) Send: 0x3000af00 - 0x3000b5ff (=1792) Send: 0x3000b600 - 0x3000bcff (=1792) Send: 0x3000bd00 - 0x3000c3ff (=1792) Send: 0x3000c400 - 0x3000caff (=1792) Send: 0x3000cb00 - 0x3000d1ff (=1792) Send: 0x3000d200 - 0x3000d8ff (=1792) Send: 0x3000d900 - 0x3000dfff (=1792) Send: 0x3000e000 - 0x3000e6ff (=1792) Send: 0x3000e700 - 0x3000edff (=1792) Send: 0x3000ee00 - 0x3000f4ff (=1792) Send: 0x3000f500 - 0x3000fbff (=1792) Send: 0x3000fc00 - 0x300102ff (=1792) Send: 0x30010300 - 0x300109ff (=1792) Send: 0x30010a00 - 0x300110ff (=1792) Send: 0x30011100 - 0x300117ff (=1792) Send: 0x30011800 - 0x30011eff (=1792) Send: 0x30011f00 - 0x300125ff (=1792) Send: 0x30012600 - 0x30012cff (=1792) Send: 0x30012d00 - 0x300133ff (=1792) Send: 0x30013400 - 0x30013aff (=1792) Send: 0x30013b00 - 0x300141ff (=1792) Send: 0x30014200 - 0x300148ff (=1792) Send: 0x30014900 - 0x30014fff (=1792) Send: 0x30015000 - 0x300156ff (=1792) Send: 0x30015700 - 0x30015dff (=1792) Send: 0x30015e00 - 0x300164ff (=1792) Send: 0x30016500 - 0x30016bff (=1792) Send: 0x30016c00 - 0x300172ff (=1792) Send: 0x30017300 - 0x300179ff (=1792) Send: 0x30017a00 - 0x300180ff (=1792) Send: 0x30018100 - 0x300187ff (=1792) Send: 0x30018800 - 0x30018eff (=1792) Send: 0x30018f00 - 0x300195ff (=1792) Send: 0x30019600 - 0x30019cff (=1792) Send: 0x30019d00 - 0x3001a3ff (=1792) Send: 0x3001a400 - 0x3001aaff (=1792) Send: 0x3001ab00 - 0x3001b1ff (=1792) Send: 0x3001b200 - 0x3001b8ff (=1792) Send: 0x3001b900 - 0x3001bfff (=1792) Send: 0x3001c000 - 0x3001c6ff (=1792) Send: 0x3001c700 - 0x3001cdff (=1792) Send: 0x3001ce00 - 0x3001d4ff (=1792) Send: 0x3001d500 - 0x3001dbff (=1792) Send: 0x3001dc00 - 0x3001e2ff (=1792) Send: 0x3001e300 - 0x3001e9ff (=1792) Send: 0x3001ea00 - 0x3001f0ff (=1792) Send: 0x3001f100 - 0x3001f7ff (=1792) Send: 0x3001f800 - 0x3001feff (=1792) Send: 0x3001ff00 - 0x300205ff (=1792) Send: 0x30020600 - 0x30020cff (=1792) Send: 0x30020d00 - 0x300213ff (=1792) Send: 0x30021400 - 0x30021aff (=1792) Send: 0x30021b00 - 0x300221ff (=1792) Send: 0x30022200 - 0x300228ff (=1792) Send: 0x30022900 - 0x30022fff (=1792) Send: 0x30023000 - 0x300236ff (=1792) Send: 0x30023700 - 0x30023dff (=1792) Send: 0x30023e00 - 0x300244ff (=1792) Send: 0x30024500 - 0x30024bff (=1792) Send: 0x30024c00 - 0x300252ff (=1792) Send: 0x30025300 - 0x300259ff (=1792) Send: 0x30025a00 - 0x300260ff (=1792) Send: 0x30026100 - 0x300267ff (=1792) Send: 0x30026800 - 0x30026eff (=1792) Send: 0x30026f00 - 0x300275ff (=1792) Send: 0x30027600 - 0x30027cff (=1792) Send: 0x30027d00 - 0x300283ff (=1792) Send: 0x30028400 - 0x30028aff (=1792) Send: 0x30028b00 - 0x300291ff (=1792) Send: 0x30029200 - 0x300298ff (=1792) Send: 0x30029900 - 0x30029fff (=1792) Send: 0x3002a000 - 0x3002a6ff (=1792) Send: 0x3002a700 - 0x3002adff (=1792) Send: 0x3002ae00 - 0x3002b4ff (=1792) Send: 0x3002b500 - 0x3002bbff (=1792) Send: 0x3002bc00 - 0x3002c2ff (=1792) Send: 0x3002c300 - 0x3002c9ff (=1792) Send: 0x3002ca00 - 0x3002d0ff (=1792) Send: 0x3002d100 - 0x3002d7ff (=1792) Send: 0x3002d800 - 0x3002deff (=1792) Send: 0x3002df00 - 0x3002e5ff (=1792) Send: 0x3002e600 - 0x3002ecff (=1792) Send: 0x3002ed00 - 0x3002f3ff (=1792) Send: 0x3002f400 - 0x3002faff (=1792) Send: 0x3002fb00 - 0x300301ff (=1792) Send: 0x30030200 - 0x300308ff (=1792) Send: 0x30030900 - 0x30030fff (=1792) Send: 0x30031000 - 0x300316ff (=1792) Send: 0x30031700 - 0x30031dff (=1792) Send: 0x30031e00 - 0x300324ff (=1792) Send: 0x30032500 - 0x30032bff (=1792) Send: 0x30032c00 - 0x300332ff (=1792) Send: 0x30033300 - 0x300339ff (=1792) Send: 0x30033a00 - 0x300340ff (=1792) Send: 0x30034100 - 0x300347ff (=1792) Send: 0x30034800 - 0x30034eff (=1792) Send: 0x30034f00 - 0x300355ff (=1792) Send: 0x30035600 - 0x30035cff (=1792) Send: 0x30035d00 - 0x300363ff (=1792) Send: 0x30036400 - 0x30036aff (=1792) Send: 0x30036b00 - 0x300371ff (=1792) Send: 0x30037200 - 0x300378ff (=1792) Send: 0x30037900 - 0x30037fff (=1792) Send: 0x30038000 - 0x300386ff (=1792) Send: 0x30038700 - 0x30038dff (=1792) Send: 0x30038e00 - 0x300394ff (=1792) Send: 0x30039500 - 0x30039bff (=1792) Send: 0x30039c00 - 0x3003a2ff (=1792) Send: 0x3003a300 - 0x3003a9ff (=1792) Send: 0x3003aa00 - 0x3003b0ff (=1792) Send: 0x3003b100 - 0x3003b7ff (=1792) Send: 0x3003b800 - 0x3003beff (=1792) Send: 0x3003bf00 - 0x3003c5ff (=1792) Send: 0x3003c600 - 0x3003ccff (=1792) Send: 0x3003cd00 - 0x3003d3ff (=1792) Send: 0x3003d400 - 0x3003daff (=1792) Send: 0x3003db00 - 0x3003e1ff (=1792) Send: 0x3003e200 - 0x3003e8ff (=1792) Send: 0x3003e900 - 0x3003efff (=1792) Send: 0x3003f000 - 0x3003f6ff (=1792) Send: 0x3003f700 - 0x3003fdff (=1792) Send: 0x3003fe00 - 0x300404ff (=1792) Send: 0x30040500 - 0x30040bff (=1792) Send: 0x30040c00 - 0x300412ff (=1792) Send: 0x30041300 - 0x300419ff (=1792) Send: 0x30041a00 - 0x300420ff (=1792) Send: 0x30042100 - 0x300427ff (=1792) Send: 0x30042800 - 0x30042eff (=1792) Send: 0x30042f00 - 0x300435ff (=1792) Send: 0x30043600 - 0x30043cff (=1792) Send: 0x30043d00 - 0x300443ff (=1792) Send: 0x30044400 - 0x30044aff (=1792) Send: 0x30044b00 - 0x300451ff (=1792) Send: 0x30045200 - 0x300458ff (=1792) Send: 0x30045900 - 0x30045fff (=1792) Send: 0x30046000 - 0x300466ff (=1792) Send: 0x30046700 - 0x30046dff (=1792) Send: 0x30046e00 - 0x300474ff (=1792) Send: 0x30047500 - 0x30047bff (=1792) Send: 0x30047c00 - 0x300482ff (=1792) Send: 0x30048300 - 0x300489ff (=1792) Send: 0x30048a00 - 0x300490ff (=1792) Send: 0x30049100 - 0x300497ff (=1792) Send: 0x30049800 - 0x30049eff (=1792) Send: 0x30049f00 - 0x3004a5ff (=1792) Send: 0x3004a600 - 0x3004acff (=1792) Send: 0x3004ad00 - 0x3004b3ff (=1792) Send: 0x3004b400 - 0x3004baff (=1792) Send: 0x3004bb00 - 0x3004c1ff (=1792) Send: 0x3004c200 - 0x3004c8ff (=1792) Send: 0x3004c900 - 0x3004cfff (=1792) Send: 0x3004d000 - 0x3004d6ff (=1792) Send: 0x3004d700 - 0x3004ddff (=1792) Send: 0x3004de00 - 0x3004e4ff (=1792) Send: 0x3004e500 - 0x3004ebff (=1792) Send: 0x3004ec00 - 0x3004f2ff (=1792) Send: 0x3004f300 - 0x3004f9ff (=1792) Send: 0x3004fa00 - 0x300500ff (=1792) Send: 0x30050100 - 0x300507ff (=1792) Send: 0x30050800 - 0x30050eff (=1792) Send: 0x30050f00 - 0x300515ff (=1792) Send: 0x30051600 - 0x30051cff (=1792) Send: 0x30051d00 - 0x300523ff (=1792) Send: 0x30052400 - 0x30052aff (=1792) Send: 0x30052b00 - 0x300531ff (=1792) Send: 0x30053200 - 0x300538ff (=1792) Send: 0x30053900 - 0x30053fff (=1792) Send: 0x30054000 - 0x300546ff (=1792) Send: 0x30054700 - 0x30054dff (=1792) Send: 0x30054e00 - 0x300554ff (=1792) Send: 0x30055500 - 0x30055bff (=1792) Send: 0x30055c00 - 0x300562ff (=1792) Send: 0x30056300 - 0x300569ff (=1792) Send: 0x30056a00 - 0x300570ff (=1792) Send: 0x30057100 - 0x300577ff (=1792) Send: 0x30057800 - 0x30057eff (=1792) Send: 0x30057f00 - 0x300585ff (=1792) Send: 0x30058600 - 0x30058cff (=1792) Send: 0x30058d00 - 0x300593ff (=1792) Send: 0x30059400 - 0x30059aff (=1792) Send: 0x30059b00 - 0x3005a1ff (=1792) Send: 0x3005a200 - 0x3005a8ff (=1792) Send: 0x3005a900 - 0x3005afff (=1792) Send: 0x3005b000 - 0x3005b6ff (=1792) Send: 0x3005b700 - 0x3005bdff (=1792) Send: 0x3005be00 - 0x3005c4ff (=1792) Send: 0x3005c500 - 0x3005cbff (=1792) Send: 0x3005cc00 - 0x3005d2ff (=1792) Send: 0x3005d300 - 0x3005d9ff (=1792) Send: 0x3005da00 - 0x3005e0ff (=1792) Send: 0x3005e100 - 0x3005e7ff (=1792) Send: 0x3005e800 - 0x3005eeff (=1792) Send: 0x3005ef00 - 0x3005f5ff (=1792) Send: 0x3005f600 - 0x3005fcff (=1792) Send: 0x3005fd00 - 0x300603ff (=1792) Send: 0x30060400 - 0x30060aff (=1792) Send: 0x30060b00 - 0x300611ff (=1792) Send: 0x30061200 - 0x300618ff (=1792) Send: 0x30061900 - 0x30061fff (=1792) Send: 0x30062000 - 0x300626ff (=1792) Send: 0x30062700 - 0x30062dff (=1792) Send: 0x30062e00 - 0x300634ff (=1792) Send: 0x30063500 - 0x30063bff (=1792) Send: 0x30063c00 - 0x300642ff (=1792) Send: 0x30064300 - 0x300649ff (=1792) Send: 0x30064a00 - 0x300650ff (=1792) Send: 0x30065100 - 0x300657ff (=1792) Send: 0x30065800 - 0x30065eff (=1792) Send: 0x30065f00 - 0x300665ff (=1792) Send: 0x30066600 - 0x30066cff (=1792) Send: 0x30066d00 - 0x300673ff (=1792) Send: 0x30067400 - 0x30067aff (=1792) Send: 0x30067b00 - 0x300681ff (=1792) Send: 0x30068200 - 0x300688ff (=1792) Send: 0x30068900 - 0x30068fff (=1792) Send: 0x30069000 - 0x300696ff (=1792) Send: 0x30069700 - 0x30069dff (=1792) Send: 0x30069e00 - 0x3006a4ff (=1792) Send: 0x3006a500 - 0x3006abff (=1792) Send: 0x3006ac00 - 0x3006b2ff (=1792) Send: 0x3006b300 - 0x3006b9ff (=1792) Send: 0x3006ba00 - 0x3006c0ff (=1792) Send: 0x3006c100 - 0x3006c7ff (=1792) Send: 0x3006c800 - 0x3006ceff (=1792) Send: 0x3006cf00 - 0x3006d5ff (=1792) Send: 0x3006d600 - 0x3006dcff (=1792) Send: 0x3006dd00 - 0x3006e3ff (=1792) Send: 0x3006e400 - 0x3006eaff (=1792) Send: 0x3006eb00 - 0x3006f1ff (=1792) Send: 0x3006f200 - 0x3006f8ff (=1792) Send: 0x3006f900 - 0x3006ffff (=1792) Send: 0x30070000 - 0x300706ff (=1792) Send: 0x30070700 - 0x30070dff (=1792) Send: 0x30070e00 - 0x300714ff (=1792) Send: 0x30071500 - 0x30071bff (=1792) Send: 0x30071c00 - 0x300722ff (=1792) Send: 0x30072300 - 0x300729ff (=1792) Send: 0x30072a00 - 0x300730ff (=1792) Send: 0x30073100 - 0x300737ff (=1792) Send: 0x30073800 - 0x30073eff (=1792) Send: 0x30073f00 - 0x300745ff (=1792) Send: 0x30074600 - 0x30074cff (=1792) Send: 0x30074d00 - 0x300753ff (=1792) Send: 0x30075400 - 0x30075aff (=1792) Send: 0x30075b00 - 0x300761ff (=1792) Send: 0x30076200 - 0x300768ff (=1792) Send: 0x30076900 - 0x30076fff (=1792) Send: 0x30077000 - 0x300776ff (=1792) Send: 0x30077700 - 0x30077dff (=1792) Send: 0x30077e00 - 0x300784ff (=1792) Send: 0x30078500 - 0x30078bff (=1792) Send: 0x30078c00 - 0x300792ff (=1792) Send: 0x30079300 - 0x300799ff (=1792) Send: 0x30079a00 - 0x3007a0ff (=1792) Send: 0x3007a100 - 0x3007a7ff (=1792) Send: 0x3007a800 - 0x3007aeff (=1792) Send: 0x3007af00 - 0x3007b5ff (=1792) Send: 0x3007b600 - 0x3007bcff (=1792) Send: 0x3007bd00 - 0x3007c3ff (=1792) Send: 0x3007c400 - 0x3007c6f7 (=760) TalkToBootloader: OK Duration: 1:01 SendFile=D:\GSM\E490_firmware\E490XEGB1_s3.s3, Mode=0 TalkToFlashloader (using COM3) Switching over to flash loader SendFile: 5 (ERR_PROTOCOL) ReLoad: 5 (ERR_PROTOCOL) Error code: ERR_PROTOCOL Sorry, an error has occured ! (ERR_PROTOCOL) ThreadProtocol finished ThreadProtocol: 5 ThreadGUI finished Closed COM3 port. ThreadGUI started ThreadProtocol started OS: NT family, Ver:5.1 Boot loader protocol type: passive Memory interface type: 1 Setup loader: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fsl3.sre Setup loader base addr: 0x00000000 Flash loader: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre Flash loader base addr: 0x30000000 Stack base addr: 0x20000000 Stack buffers: 1 0: 0x20000000 - 0x23ffffff [64 MB (67108864 Bytes)] Opened COM3 at 115200 baud PC transfer speeds (COM3): 57600 115200 230400 460800 921600 Loading S-record file (RangeCheck=Off) File: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fsl3.sre SRE line 181: IGNORING: S70500000000FA There is 1 memory region in the S-record file: 1: 0x00000000 - 0x00000b3f = 2880 Bytes Loading S-record file (RangeCheck=Off) File: D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre SRE line 31857: IGNORING: S70530000000CA There is 1 memory region in the S-record file: 1: 0x30000000 - 0x3007c6f7 = 509688 Bytes Loading S-record file (RangeCheck=On) File: D:\GSM\E490_firmware\E490XEGB1_s3.s3 SRE line 3547: IGNORING: S70520020000D8 SRE line 3548: IGNORING: S011000070616870655F72666132652E7333DD SRE line 4720: IGNORING: S70520010000D9 SRE line 4805: IGNORING: S70520040000D6 SRE line 4808: IGNORING: S70520000000DA SRE line 4811: IGNORING: S70522000000D8 SRE line 1482114: IGNORING: S70520042000B6 SRE line 1498261: IGNORING: S70521FC0000DD There are 7 memory regions in the S-record file: 1: 0x20000000 - 0x2000001b = 28 Bytes 2: 0x20010000 - 0x20014927 = 18728 Bytes 3: 0x20020000 - 0x2002dd93 = 56724 Bytes 4: 0x20040000 - 0x20040533 = 1332 Bytes 5: 0x20042000 - 0x216ccb5b = 23636828 Bytes 6: 0x21fc0000 - 0x21fff117 = 258328 Bytes 7: 0x22000000 - 0x22000017 = 24 Bytes SendFile=D:\GSM\Rocker_Full_cracked\Samsung Rocker Crack\data\fl10.sre, Mode=3 Power on mobile ! TalkToBootLoader (using COM3) Talking to passive bootloader Bootloader V1.1 using UART1 ROM mask ID: 0x000200a3 ( ) ID register: 0x000200a3 (ES2) Bootloader type: 6 (0) Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 2880 bytes in 1 region(s) Send: 0x00000000 - 0x000006ff (=1792) Send: 0x00000700 - 0x00000b3f (=1088) Talking to setup loader Setup loader V1.1 using UART1 Setup loader type: 4 Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 509688 bytes in 1 region(s) Send: 0x30000000 - 0x300006ff (=1792) Send: 0x30000700 - 0x30000dff (=1792) Send: 0x30000e00 - 0x300014ff (=1792) Send: 0x30001500 - 0x30001bff (=1792) Send: 0x30001c00 - 0x300022ff (=1792) Send: 0x30002300 - 0x300029ff (=1792) Send: 0x30002a00 - 0x300030ff (=1792) Send: 0x30003100 - 0x300037ff (=1792) Send: 0x30003800 - 0x30003eff (=1792) Send: 0x30003f00 - 0x300045ff (=1792) Send: 0x30004600 - 0x30004cff (=1792) Send: 0x30004d00 - 0x300053ff (=1792) Send: 0x30005400 - 0x30005aff (=1792) Send: 0x30005b00 - 0x300061ff (=1792) Send: 0x30006200 - 0x300068ff (=1792) Send: 0x30006900 - 0x30006fff (=1792) Send: 0x30007000 - 0x300076ff (=1792) Send: 0x30007700 - 0x30007dff (=1792) Send: 0x30007e00 - 0x300084ff (=1792) Send: 0x30008500 - 0x30008bff (=1792) Send: 0x30008c00 - 0x300092ff (=1792) Send: 0x30009300 - 0x300099ff (=1792) Send: 0x30009a00 - 0x3000a0ff (=1792) Send: 0x3000a100 - 0x3000a7ff (=1792) Send: 0x3000a800 - 0x3000aeff (=1792) Send: 0x3000af00 - 0x3000b5ff (=1792) Send: 0x3000b600 - 0x3000bcff (=1792) Send: 0x3000bd00 - 0x3000c3ff (=1792) Send: 0x3000c400 - 0x3000caff (=1792) Send: 0x3000cb00 - 0x3000d1ff (=1792) Send: 0x3000d200 - 0x3000d8ff (=1792) Send: 0x3000d900 - 0x3000dfff (=1792) Send: 0x3000e000 - 0x3000e6ff (=1792) Send: 0x3000e700 - 0x3000edff (=1792) Send: 0x3000ee00 - 0x3000f4ff (=1792) Send: 0x3000f500 - 0x3000fbff (=1792) Send: 0x3000fc00 - 0x300102ff (=1792) Send: 0x30010300 - 0x300109ff (=1792) Send: 0x30010a00 - 0x300110ff (=1792) Send: 0x30011100 - 0x300117ff (=1792) Send: 0x30011800 - 0x30011eff (=1792) Send: 0x30011f00 - 0x300125ff (=1792) Send: 0x30012600 - 0x30012cff (=1792) Send: 0x30012d00 - 0x300133ff (=1792) Send: 0x30013400 - 0x30013aff (=1792) Send: 0x30013b00 - 0x300141ff (=1792) Send: 0x30014200 - 0x300148ff (=1792) Send: 0x30014900 - 0x30014fff (=1792) Send: 0x30015000 - 0x300156ff (=1792) Send: 0x30015700 - 0x30015dff (=1792) Send: 0x30015e00 - 0x300164ff (=1792) Send: 0x30016500 - 0x30016bff (=1792) Send: 0x30016c00 - 0x300172ff (=1792) Send: 0x30017300 - 0x300179ff (=1792) Send: 0x30017a00 - 0x300180ff (=1792) Send: 0x30018100 - 0x300187ff (=1792) Send: 0x30018800 - 0x30018eff (=1792) Send: 0x30018f00 - 0x300195ff (=1792) Send: 0x30019600 - 0x30019cff (=1792) Send: 0x30019d00 - 0x3001a3ff (=1792) Send: 0x3001a400 - 0x3001aaff (=1792) Send: 0x3001ab00 - 0x3001b1ff (=1792) Send: 0x3001b200 - 0x3001b8ff (=1792) Send: 0x3001b900 - 0x3001bfff (=1792) Send: 0x3001c000 - 0x3001c6ff (=1792) Send: 0x3001c700 - 0x3001cdff (=1792) Send: 0x3001ce00 - 0x3001d4ff (=1792) Send: 0x3001d500 - 0x3001dbff (=1792) Send: 0x3001dc00 - 0x3001e2ff (=1792) Send: 0x3001e300 - 0x3001e9ff (=1792) Send: 0x3001ea00 - 0x3001f0ff (=1792) Send: 0x3001f100 - 0x3001f7ff (=1792) Send: 0x3001f800 - 0x3001feff (=1792) Send: 0x3001ff00 - 0x300205ff (=1792) Send: 0x30020600 - 0x30020cff (=1792) Send: 0x30020d00 - 0x300213ff (=1792) Send: 0x30021400 - 0x30021aff (=1792) Send: 0x30021b00 - 0x300221ff (=1792) Send: 0x30022200 - 0x300228ff (=1792) Send: 0x30022900 - 0x30022fff (=1792) Send: 0x30023000 - 0x300236ff (=1792) Send: 0x30023700 - 0x30023dff (=1792) Send: 0x30023e00 - 0x300244ff (=1792) Send: 0x30024500 - 0x30024bff (=1792) Send: 0x30024c00 - 0x300252ff (=1792) Send: 0x30025300 - 0x300259ff (=1792) Send: 0x30025a00 - 0x300260ff (=1792) Send: 0x30026100 - 0x300267ff (=1792) Send: 0x30026800 - 0x30026eff (=1792) Send: 0x30026f00 - 0x300275ff (=1792) Send: 0x30027600 - 0x30027cff (=1792) Send: 0x30027d00 - 0x300283ff (=1792) Send: 0x30028400 - 0x30028aff (=1792) Send: 0x30028b00 - 0x300291ff (=1792) Send: 0x30029200 - 0x300298ff (=1792) Send: 0x30029900 - 0x30029fff (=1792) Send: 0x3002a000 - 0x3002a6ff (=1792) Send: 0x3002a700 - 0x3002adff (=1792) Send: 0x3002ae00 - 0x3002b4ff (=1792) Send: 0x3002b500 - 0x3002bbff (=1792) Send: 0x3002bc00 - 0x3002c2ff (=1792) Send: 0x3002c300 - 0x3002c9ff (=1792) Send: 0x3002ca00 - 0x3002d0ff (=1792) Send: 0x3002d100 - 0x3002d7ff (=1792) Send: 0x3002d800 - 0x3002deff (=1792) Send: 0x3002df00 - 0x3002e5ff (=1792) Send: 0x3002e600 - 0x3002ecff (=1792) Send: 0x3002ed00 - 0x3002f3ff (=1792) Send: 0x3002f400 - 0x3002faff (=1792) Send: 0x3002fb00 - 0x300301ff (=1792) Send: 0x30030200 - 0x300308ff (=1792) Send: 0x30030900 - 0x30030fff (=1792) Send: 0x30031000 - 0x300316ff (=1792) Send: 0x30031700 - 0x30031dff (=1792) Send: 0x30031e00 - 0x300324ff (=1792) Send: 0x30032500 - 0x30032bff (=1792) Send: 0x30032c00 - 0x300332ff (=1792) Send: 0x30033300 - 0x300339ff (=1792) Send: 0x30033a00 - 0x300340ff (=1792) Send: 0x30034100 - 0x300347ff (=1792) Send: 0x30034800 - 0x30034eff (=1792) Send: 0x30034f00 - 0x300355ff (=1792) Send: 0x30035600 - 0x30035cff (=1792) Send: 0x30035d00 - 0x300363ff (=1792) Send: 0x30036400 - 0x30036aff (=1792) Send: 0x30036b00 - 0x300371ff (=1792) Send: 0x30037200 - 0x300378ff (=1792) Send: 0x30037900 - 0x30037fff (=1792) Send: 0x30038000 - 0x300386ff (=1792) Send: 0x30038700 - 0x30038dff (=1792) Send: 0x30038e00 - 0x300394ff (=1792) Send: 0x30039500 - 0x30039bff (=1792) Send: 0x30039c00 - 0x3003a2ff (=1792) Send: 0x3003a300 - 0x3003a9ff (=1792) Send: 0x3003aa00 - 0x3003b0ff (=1792) Send: 0x3003b100 - 0x3003b7ff (=1792) Send: 0x3003b800 - 0x3003beff (=1792) Send: 0x3003bf00 - 0x3003c5ff (=1792) Send: 0x3003c600 - 0x3003ccff (=1792) Send: 0x3003cd00 - 0x3003d3ff (=1792) Send: 0x3003d400 - 0x3003daff (=1792) Send: 0x3003db00 - 0x3003e1ff (=1792) Send: 0x3003e200 - 0x3003e8ff (=1792) Send: 0x3003e900 - 0x3003efff (=1792) Send: 0x3003f000 - 0x3003f6ff (=1792) Send: 0x3003f700 - 0x3003fdff (=1792) Send: 0x3003fe00 - 0x300404ff (=1792) Send: 0x30040500 - 0x30040bff (=1792) Send: 0x30040c00 - 0x300412ff (=1792) Send: 0x30041300 - 0x300419ff (=1792) Send: 0x30041a00 - 0x300420ff (=1792) Send: 0x30042100 - 0x300427ff (=1792) Send: 0x30042800 - 0x30042eff (=1792) Send: 0x30042f00 - 0x300435ff (=1792) Send: 0x30043600 - 0x30043cff (=1792) Send: 0x30043d00 - 0x300443ff (=1792) Send: 0x30044400 - 0x30044aff (=1792) Send: 0x30044b00 - 0x300451ff (=1792) Send: 0x30045200 - 0x300458ff (=1792) Send: 0x30045900 - 0x30045fff (=1792) Send: 0x30046000 - 0x300466ff (=1792) Send: 0x30046700 - 0x30046dff (=1792) Send: 0x30046e00 - 0x300474ff (=1792) Send: 0x30047500 - 0x30047bff (=1792) Send: 0x30047c00 - 0x300482ff (=1792) Send: 0x30048300 - 0x300489ff (=1792) Send: 0x30048a00 - 0x300490ff (=1792) Send: 0x30049100 - 0x300497ff (=1792) Send: 0x30049800 - 0x30049eff (=1792) Send: 0x30049f00 - 0x3004a5ff (=1792) Send: 0x3004a600 - 0x3004acff (=1792) Send: 0x3004ad00 - 0x3004b3ff (=1792) Send: 0x3004b400 - 0x3004baff (=1792) Send: 0x3004bb00 - 0x3004c1ff (=1792) Send: 0x3004c200 - 0x3004c8ff (=1792) Send: 0x3004c900 - 0x3004cfff (=1792) Send: 0x3004d000 - 0x3004d6ff (=1792) Send: 0x3004d700 - 0x3004ddff (=1792) Send: 0x3004de00 - 0x3004e4ff (=1792) Send: 0x3004e500 - 0x3004ebff (=1792) Send: 0x3004ec00 - 0x3004f2ff (=1792) Send: 0x3004f300 - 0x3004f9ff (=1792) Send: 0x3004fa00 - 0x300500ff (=1792) Send: 0x30050100 - 0x300507ff (=1792) Send: 0x30050800 - 0x30050eff (=1792) Send: 0x30050f00 - 0x300515ff (=1792) Send: 0x30051600 - 0x30051cff (=1792) Send: 0x30051d00 - 0x300523ff (=1792) Send: 0x30052400 - 0x30052aff (=1792) Send: 0x30052b00 - 0x300531ff (=1792) Send: 0x30053200 - 0x300538ff (=1792) Send: 0x30053900 - 0x30053fff (=1792) Send: 0x30054000 - 0x300546ff (=1792) Send: 0x30054700 - 0x30054dff (=1792) Send: 0x30054e00 - 0x300554ff (=1792) Send: 0x30055500 - 0x30055bff (=1792) Send: 0x30055c00 - 0x300562ff (=1792) Send: 0x30056300 - 0x300569ff (=1792) Send: 0x30056a00 - 0x300570ff (=1792) Send: 0x30057100 - 0x300577ff (=1792) Send: 0x30057800 - 0x30057eff (=1792) Send: 0x30057f00 - 0x300585ff (=1792) Send: 0x30058600 - 0x30058cff (=1792) Send: 0x30058d00 - 0x300593ff (=1792) Send: 0x30059400 - 0x30059aff (=1792) Send: 0x30059b00 - 0x3005a1ff (=1792) Send: 0x3005a200 - 0x3005a8ff (=1792) Send: 0x3005a900 - 0x3005afff (=1792) Send: 0x3005b000 - 0x3005b6ff (=1792) Send: 0x3005b700 - 0x3005bdff (=1792) Send: 0x3005be00 - 0x3005c4ff (=1792) Send: 0x3005c500 - 0x3005cbff (=1792) Send: 0x3005cc00 - 0x3005d2ff (=1792) Send: 0x3005d300 - 0x3005d9ff (=1792) Send: 0x3005da00 - 0x3005e0ff (=1792) Send: 0x3005e100 - 0x3005e7ff (=1792) Send: 0x3005e800 - 0x3005eeff (=1792) Send: 0x3005ef00 - 0x3005f5ff (=1792) Send: 0x3005f600 - 0x3005fcff (=1792) Send: 0x3005fd00 - 0x300603ff (=1792) Send: 0x30060400 - 0x30060aff (=1792) Send: 0x30060b00 - 0x300611ff (=1792) Send: 0x30061200 - 0x300618ff (=1792) Send: 0x30061900 - 0x30061fff (=1792) Send: 0x30062000 - 0x300626ff (=1792) Send: 0x30062700 - 0x30062dff (=1792) Send: 0x30062e00 - 0x300634ff (=1792) Send: 0x30063500 - 0x30063bff (=1792) Send: 0x30063c00 - 0x300642ff (=1792) Send: 0x30064300 - 0x300649ff (=1792) Send: 0x30064a00 - 0x300650ff (=1792) Send: 0x30065100 - 0x300657ff (=1792) Send: 0x30065800 - 0x30065eff (=1792) Send: 0x30065f00 - 0x300665ff (=1792) Send: 0x30066600 - 0x30066cff (=1792) Send: 0x30066d00 - 0x300673ff (=1792) Send: 0x30067400 - 0x30067aff (=1792) Send: 0x30067b00 - 0x300681ff (=1792) Send: 0x30068200 - 0x300688ff (=1792) Send: 0x30068900 - 0x30068fff (=1792) Send: 0x30069000 - 0x300696ff (=1792) Send: 0x30069700 - 0x30069dff (=1792) Send: 0x30069e00 - 0x3006a4ff (=1792) Send: 0x3006a500 - 0x3006abff (=1792) Send: 0x3006ac00 - 0x3006b2ff (=1792) Send: 0x3006b300 - 0x3006b9ff (=1792) Send: 0x3006ba00 - 0x3006c0ff (=1792) Send: 0x3006c100 - 0x3006c7ff (=1792) Send: 0x3006c800 - 0x3006ceff (=1792) Send: 0x3006cf00 - 0x3006d5ff (=1792) Send: 0x3006d600 - 0x3006dcff (=1792) Send: 0x3006dd00 - 0x3006e3ff (=1792) Send: 0x3006e400 - 0x3006eaff (=1792) Send: 0x3006eb00 - 0x3006f1ff (=1792) Send: 0x3006f200 - 0x3006f8ff (=1792) Send: 0x3006f900 - 0x3006ffff (=1792) Send: 0x30070000 - 0x300706ff (=1792) Send: 0x30070700 - 0x30070dff (=1792) Send: 0x30070e00 - 0x300714ff (=1792) Send: 0x30071500 - 0x30071bff (=1792) Send: 0x30071c00 - 0x300722ff (=1792) Send: 0x30072300 - 0x300729ff (=1792) Send: 0x30072a00 - 0x300730ff (=1792) Send: 0x30073100 - 0x300737ff (=1792) Send: 0x30073800 - 0x30073eff (=1792) Send: 0x30073f00 - 0x300745ff (=1792) Send: 0x30074600 - 0x30074cff (=1792) Send: 0x30074d00 - 0x300753ff (=1792) Send: 0x30075400 - 0x30075aff (=1792) Send: 0x30075b00 - 0x300761ff (=1792) Send: 0x30076200 - 0x300768ff (=1792) Send: 0x30076900 - 0x30076fff (=1792) Send: 0x30077000 - 0x300776ff (=1792) Send: 0x30077700 - 0x30077dff (=1792) Send: 0x30077e00 - 0x300784ff (=1792) Send: 0x30078500 - 0x30078bff (=1792) Send: 0x30078c00 - 0x300792ff (=1792) Send: 0x30079300 - 0x300799ff (=1792) Send: 0x30079a00 - 0x3007a0ff (=1792) Send: 0x3007a100 - 0x3007a7ff (=1792) Send: 0x3007a800 - 0x3007aeff (=1792) Send: 0x3007af00 - 0x3007b5ff (=1792) Send: 0x3007b600 - 0x3007bcff (=1792) Send: 0x3007bd00 - 0x3007c3ff (=1792) Send: 0x3007c400 - 0x3007c6f7 (=760) TalkToBootloader: OK Duration: 59s SendFile=D:\GSM\E490_firmware\E490XEGB1_s3.s3, Mode=4 TalkToFlashloader (using COM3) Switching over to flash loader SendFile: 5 (ERR_PROTOCOL) ReLoad: 5 (ERR_PROTOCOL) Error code: ERR_PROTOCOL Sorry, an error has occured ! (ERR_PROTOCOL) ThreadProtocol finished ThreadProtocol: 5 ThreadGUI finished Closed COM3 port. |
10-08-2008, 22:19 | #2 (permalink) |
Banned Join Date: Aug 2008 Location: GREEN IRAN
Member: 848591 Status: Offline Sonork: 100.1590582 Thanks Meter: 419 | Hi. you can use orginal opti flash for your phone. if cant flash it there is problem in your phone not software or firmware |
The Following User Says Thank You to dejavugsm For This Useful Post: |
samsung E490 flash error !!!!! | msantar | Z3X-Team Products | 1 | 03-12-2010 04:28 |
samsung a400 flashing problem | dantetimoc | Twisterflasher | 8 | 04-24-2005 14:43 |
samsung E600 flashing problem | kinggsm team | UFS2 + UFS3-Tornadoflasher | 1 | 09-22-2004 08:40 |
samsung a300 flash problem | cs55 | VLSI, Conexant, Skyworks and Old Models | 7 | 12-08-2002 13:56 |
Samsung R210s flashing problem | realcool | VLSI, Conexant, Skyworks and Old Models | 9 | 10-02-2002 22:21 |
