Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 10-30-2009, 14:32   #1 (permalink)
KARIM GSM-ZONE's Avatar
Member: 74415
Sonork: gsm.zone
Thanks Meter: 295
Wink Samsung flash guide for s5230,s8000,s8300
Samsung Flash Guide For S5230, S8000, S8300 And More!
by Darkforest on Oct.13, 2009, under Samsung Flash Guides
***Warning!***
Make sure your phone dose not have sim lock before you try and flash. Type *#7465625# and make sure the SIMLOCK is OFF, if it is ON you MUST take it to a shop and have it removed or you will freeze your phone!
First thing to always remember, is BACK UP YOUR PHONE, Pictures,wallpapers,music, and any contacts you have saved on your phone. I am not responsible for any damage to you, your phone, computer, or lost of data in this process. This is a guideline intended for professional technicians.
USE AT YOUR OWN RISK!!!
What you will need:
1. USB cable that came with your phone.
2. New Samsung NPS
Install this software first, it contains the drivers for your phone, and has every thing you need for backup.
3. Multiloader 5.56
4. New firmware
覧覧覧覧蘭Now you are ready to begin覧覧覧覧覧蘭
1. Make sure Samsung PC Studio is installed and communicates with your phone. And unpack the firmware in a folder you can easily find it.
2. Remove the Sim and MicroSD from your phone and replace the battery.
3. MAKE SURE THE PHONE IS OFF AND NOT CONNECTED TO THE COMPUTER.
4. Pixon and JET users : Hold down the 天olume - button on the left or right side differs, and the 鼎amera button on the right, then press the 撤ower button = all three buttons need to be pressed together. Your phone should start up into a red\blue on black bootloader screen.) For U900 While holding the no. 9 button on the phones key pad, tap the power button, the phone screen will come on black with a red stripe that says 泥ownload
5. Now run MultiLoader v5.56
6.Plug the phone up to the computer.
覧覧覧覧覧柚ultiloader Steps覧覧覧覧覧覧覧
1. Select the radio button Example: U900 MSM6275/MSM6280, FOR S5230 BRCM2133, FOR JET LSI6410
2. Select Boot Change
3. Full Download
4. Master rom
5. Then click Boot, and select the boot files from the unpacked firmware folder.
6. Select Amss
**NOTE** You must also select 鄭PPS if you are flashing a 笛ET **NOTE**
7. Rsrc1
8. Rsrc2(Low) Do not use (Mid).r2c. On the JET may there may only be one option (Warning! phone may not restart if you select mid)
9. Select the Factory FS file.
***FOTA and ETC fields are left blank.****
When you are done it should look like this.
10. Click the Port Search button, it will find your phone and show the com port is ready.
11. Click the download button and be patient, this will only take a few minutes to complete.
12. When it痴 finished, it will show 登k complete.
13. Unplug the phone from the USB cable, reinstall the sim and SD card.
*** NOTE Some models and some will not, if yours does not restart at this point, take out the battery a few seconds then reinsert it. NOTE ***
14. Now with every thing is complete, You can perform a hard reset by typing *2767*3855# into the hand set (but not necessary.)
15. When the phone resets type *#1234# into your handset to check your new firmware ver.
***NOTE!***
If your phone fails the flash for any reason, DO NOT TRY AND RESTART IT!!!!! Restart the computer and try the flash again! YES YOU MUST RESTART THE COMPUTER AND FOLLOW MY PREP GUIDE (Beginners guide.)
**NOTE**
If your phone camera does not work after the flash:
Our Moderator DF3 Provided this handy pieces of information.
You need to perform the camera firmware update, Admin codes have been changed on recent FW:
a. Type *#197328640# in the Idle mode, then you can reach the test mode.
b. Select [6] Video
c. Select [3] Camera Firmware update
[Please Wait] will be displayed.
Wait a few minutes then [Please Wait] will be changed to [SUCCESS]
Thank you DF3 For your help!
KARIM
SOURCE:http://darkforestgroup.com/blog/?p=7
The Following 11 Users Say Thank You to KARIM GSM-ZONE For This Useful Post:
Old 12-17-2009, 12:50   #2 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 621
i have one s8300t i write s8300 flash file but signal problem face.so i need s8300t firmware plz help if any one have.
b.r
bahri
Old 01-01-2010, 09:57   #3 (permalink)
Member: 1197692
Thanks Meter: 2
Hi, I need flash/firmware for samsung S8300T. Thanks in advance.
The Following User Says Thank You to jayvinjkb For This Useful Post:
Old 01-01-2010, 21:04   #4 (permalink)
Member: 1197692
Thanks Meter: 2
Hi, i need the firmware, not the guide. thnx
Old 01-17-2010, 11:13   #5 (permalink)
Member: 1211253
thank you very much, buddy
Old 02-09-2010, 18:20   #6 (permalink)
Member: 731904
Thanks Meter: 2
There are a lot of firmwares on that site http://darkforestgroup.com/forum/
Old 03-10-2010, 11:53   #7 (permalink)
Member: 1232683
Hi i have a s8300 which was stupidly flashed with wrong firmware so doesnt boot at all, i know this phone is imei blocked so isnt worth doing
but i have another one same model. that isnt blocked
but the first phone is better condition can i swap imei from phone 2 to phone 1 if i get boot fixed on phone 1
Old 06-06-2010, 16:16   #8 (permalink)
Member: 182006
Thanks Meter: 41
HI
I am new to Samsung flashing .
Question ... if my phone works ok (this one is a gts3650 Genio ) and the only problem is a phone lock code do I need to do a full flash ? or is it posible to only flash the BOOTFILE .If so how do I set up v5.6 ?
Any help appeciated
Steve
Old 06-30-2010, 12:54   #9 (permalink)
Registered User
Member: 97188
Thanks Meter: 4
s8000 flash
tested and works perfect...
i had a samsung s8000, at phone start up it was asking for phone lock. flashed and now works perfect.. thankyou. brian in ireland
The Following User Says Thank You to badbrian For This Useful Post:
Old 07-05-2010, 08:35   #10 (permalink)
Member: 361348
Thanks Meter: 626
bro wheb i flash my s8000 which hang whith multiloader v5.54 or 5.56 i av this error:
Download Start Ch[0]
BootLoader 298.4KB OK[0.3s]
Dbl 154.2KB OK[0.2s]
Wait reset !!
Amss 13739.8KB OK[13.9s]
Error : Apps Write [6.7s]
note that fon connect only in dowload mode when i put it in blue screen it not connect
Old 07-06-2010, 15:06   #11 (permalink)
Member: 1282976
Sonork: www.rifgsm.eu.pn
Thanks Meter: 28
download from here Unlock software, repair and flash tools, service manuals, unlock codes ...
Old 07-16-2010, 20:01   #12 (permalink)
Member: 610662
Thanks Meter: 14
Hello , please free download Multiloader_V5.56 thanks
Old 07-16-2010, 20:08   #13 (permalink)
MasoudSAMSUNG's Avatar
Member: 1153045
Sonork: 100.1638693
Thanks Meter: 123
Download:
The Following User Says Thank You to MasoudSAMSUNG For This Useful Post:
Old 11-19-2010, 17:51   #14 (permalink)
mint centre's Avatar
Member: 195993
Sonork: 100.1653595
Thanks Meter: 128
flashed the s5230 with 3 diffrent flashes for estonian language packs
now "camera failed"
this handset is brand new?
any solution plz?
b. Select [6] Video
tried this but the options above dont key in2 handset menu???
regards
THE KOP...
Old 02-21-2011, 14:55   #15 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
what about s5233a camera failed after flash ? this procedure not work i can't saw any video categary
No flash files for S5230 mobi786 NSPRO 10 02-11-2010 01:21
Need flashing guide for Samsung D900i DeiViz Samsung Flashers, Software, Firmware. 0 11-02-2007 15:01
Total FLASH guide for DUMMIES merten3000 Samsung Flashers, Software, Firmware. 5 09-22-2005 13:54
Setool3 LG 8180/8330 Flashing Guide for N00b's hunk4004 LG 25 06-20-2005 16:10
SAMSUNG flash files for a200/300 , r2xx, n200, n100 , q105 ??????? PTR999 VLSI, Conexant, Skyworks and Old Models 3 09-15-2002 21:04
Page generated in 0.42358 seconds with 8 queries
