Samsung GALAXY Y (young) GT-S5360 Samsung logo only done via Odin Samsung GALAXY Y (young) GT-S5360 Samsung logo only done via Odin http://i871.photobucket.com/albums/a...60GalaxyY1.jpg Status http://i871.photobucket.com/albums/a...r/IMG_1553.jpg Tools Odin 1.85 File http://i871.photobucket.com/albums/a...txter/file.jpg 1st Procedure Hard Reset but no lock Press VOLUME UP + HOME + POWER and wait until the phone enter the Android System Recovery then select wipe date/factory reset & wipe cache partition http://i871.photobucket.com/albums/a...r/IMG_1555.jpg http://i871.photobucket.com/albums/a...r/IMG_1556.jpg Procedure 1) Turn off your phone 2) Remove your SIM Card and SD Card 3) Extract previously downloaded firmware 4) Open ODIN 1.85 on your PC 5) Select from extracted archive: OPS-OPS, Bootloader, Phone-MODEM, PDA-CODE, CSC-CSC (leave EFS and One Package empty) http://i871.photobucket.com/albums/a...txter/1-21.jpg 6) Connect your phone via USB into PC 7) When the screen is turned on hold POWER+VOLUME DOWN+HOME and wait until the phone enters the Download Mode http://i871.photobucket.com/albums/a...g-Galaxy-Y.png 8) If ODIN detected and recognized your phone should light up the first square to the left side 9) Press “Start” button and wait, the process should take ~5 minutes http://i871.photobucket.com/albums/a...txter/2-17.jpg http://i871.photobucket.com/albums/a...txter/3-15.jpg 10) If all goes well your phone should reboot automatically 11) Square should change the color to blue and display “PASS” it means that flashing process was successful Logs Code: <ID:0/018> Added!! http://i871.photobucket.com/albums/a...r/IMG_1560.jpg |
bro i need file link im waiting thankss --------- |
Sir? I have question, what if the phone has already brick? does it could be fix through this? thanks you sir.. |
hai friends, my phone is crashed during i update it through the skies . what can i do now .if u have any backup to flash my phone |
boss the problem with my galaxy y is it is not switching on,,,n the screen holds max for 10 sec so i am not being able to run odin on it,,, what should i do,,, ? :( |
Oh No... my screen split into 2... :eek: |
got one Samsung Galaxy Y Young with hang problem at Samsung Galaxy Y young GT-S5360, PC doesn't detect the phone |
after following all the steps here, my phone is still not working on Odin, it says nothing :( need help badly.. |
HI, need full firmware for S5360T. same problem here.. |
Thank you for this info!!! THANK YOU THANK YOU THANK YOU... SO SO MUCH!!! It worked great. I flashed my S5360l with this file. It worked. I am sooo happy. It took me MONTHS to get to this point!!! |
my samsung galaxy y stocked at welcome screen, I followed this tutorial and solved the problem. But, before my internal storage is 4gb and after fixing it with this tutorial, the internal storage become 190mb only. Can you help me this, so I can bring it back to 4gb. Thanks in advance! |
GT-S5360L Unlocked But show Locked Hey I have a Samsung Galaxys Young GT-S5360L Was Unlocked allready But show Locked is from Claro I think This company put Something on the Software, How can I to Solve this. Can see the Log: Model Selected : GT-S5360L Found Device : 0123456789ABCDEF MODEL : GT-S5360L BOARD ID : GT-S5360L PLATFORM ID : bcm21553 OS VERSION : 2.3.6 BUILD ID : GINGERBREAD BUILD DATE : Fri Jan 6 15:06:44 KST 2012 BUILD VERSION : GINGERBREAD.UHLA1 SOFTWARE VERSION : S5360LUHLA1 IMEI : **************** (GSM)RIL VERSION : BRCM android bcm-ril-090728 (GSM)BASEBAND : S5360LUHLA1 (RIL)SW VERSION : S5360LUHLA1 (RIL)(RIL)HW VERSION : MP 0.700 Found Device : 0123456789ABCDEF Checking Root access: True Backup created..c:\nck_dongle\\temp\samsung_backup\GT-S5360L_*****************\bml15 Unlock Done, Restarting Phone! Regards bedel. |
sir cant detect sam s5360 cant detect pc..installed kies but cant detect plllllllllllllllssssssssssss |
