Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 08-28-2012, 18:31   #1 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 60
Smile Samsung GALAXY Y (young) GT-S5360 Samsung logo only done via Odin
Status
Tools
Odin 1.85
File
1st Procedure Hard Reset but no lock
Press VOLUME UP + HOME + POWER and wait until the phone enter the Android System Recovery then select wipe date/factory reset & wipe cache partition
Procedure
1) Turn off your phone
2) Remove your SIM Card and SD Card
3) Extract previously downloaded firmware
4) Open ODIN 1.85 on your PC
5) Select from extracted archive: OPS-OPS, Bootloader, Phone-MODEM, PDA-CODE, CSC-CSC (leave EFS and One Package empty)
6) Connect your phone via USB into PC
7) When the screen is turned on hold POWER+VOLUME DOWN+HOME and wait until the phone enters the Download Mode
8) If ODIN detected and recognized your phone should light up the first square to the left side
9) Press “Start” button and wait, the process should take ~5 minutes
10) If all goes well your phone should reboot automatically
11) Square should change the color to blue and display “PASS” it means that flashing process was successful
Logs
<ID:0/018> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> DefaultCalDataWithBoot_S5360XXKI6_REV05.tar.md5 is valid.
<OSM> PDA_S5360XXKI6_REV05.tar.md5 is valid.
<OSM> MODEM_S5360XXKI6_REV05.tar.md5 is valid.
<OSM> GT-S5360-MULTI-CSC-OXXKI6.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/018> Odin v.3 engine (ID:18)..
<ID:0/018> File analysis..
<ID:0/018> SetupConnection..
<ID:0/018> Initialzation..
<ID:0/018> Set PIT file..
<ID:0/018> DO NOT TURN OFF TARGET!!
<ID:0/018> Get PIT for mapping..
<ID:0/018> Firmware update start..
<ID:0/018> BcmBoot.img
<ID:0/018> NAND Write Start!!
<ID:0/018> HEDGE_NVRAM8_RF_LE.bin
<ID:0/018> sysparm_dep.img
<ID:0/018> Sbl.bin
<ID:0/018> boot.img
<ID:0/018> system.img
<ID:0/018> userdata.img
<ID:0/018> param.lfs
<ID:0/018> BcmCP.img
<ID:0/018> Transmission Complete..
<ID:0/018> Now Writing.. Please wait about 2 minutes
<ID:0/018> Receive Response form LOKE
<ID:0/018> csc.rfs
<ID:0/018> RQT_CLOSE !!
<ID:0/018> RES OK !!
<ID:0/018> Completed..
<OSM> All threads completed. (succeed 1 / failed 0)
<ID:0/018> Removed!!
My Finish Product
The Following User Says Thank You to fertxter For This Useful Post:
Old 11-13-2012, 17:04   #2 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,137
bro i need file link
im waiting
thankss
Old 11-14-2012, 07:58   #3 (permalink)
mohideen77752's Avatar
Member: 1772238
Sonork: 100.1617698
Thanks Meter: 125
im waiting
thankss
brother here is file link galaxy y
Old 12-28-2012, 16:41   #4 (permalink)
Member: 752355
Sonork: napster
Thanks Meter: 3
Sir? I have question, what if the phone has already brick? does it could be fix through this? thanks you sir..
Old 12-29-2012, 10:43   #5 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 60
Wink
if you cant enter into download mode you cant use this my thread solution, but if you can't enter in download mode you mean dead boot you to repair by using JTAG like riff box
Old 02-25-2013, 03:25   #6 (permalink)
Member: 1889593
hai friends, my phone is crashed during i update it through the skies . what can i do now .if u have any backup to flash my phone
Old 02-26-2013, 15:38   #7 (permalink)
Member: 1890604
boss the problem with my galaxy y is it is not switching on,,,n the screen holds max for 10 sec so i am not being able to run odin on it,,,
what should i do,,, ?
Old 03-25-2013, 15:16   #8 (permalink)
Member: 1906506
Oh No... my screen split into 2...
The Following User Says Thank You to WaNaWe900 For This Useful Post:
Old 03-28-2013, 11:41   #9 (permalink)
Member: 1241659
Thanks Meter: 158
got one Samsung Galaxy Y Young with hang problem at Samsung Galaxy Y young GT-S5360, PC doesn't detect the phone
Old 04-13-2013, 19:16   #10 (permalink)
Member: 1916484
after following all the steps here, my phone is still not working on Odin, it says nothing need help badly..
Old 04-23-2013, 09:19   #11 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 394
HI, need full firmware for S5360T. same problem here..
Old 04-29-2013, 04:26   #12 (permalink)
Member: 1779577
Sonork: 100.1622810
Thanks Meter: 8
Thank you for this info!!!
THANK YOU THANK YOU THANK YOU... SO SO MUCH!!! It worked great. I flashed my S5360l with this file. It worked. I am sooo happy. It took me MONTHS to get to this point!!!
Old 05-20-2013, 17:43   #13 (permalink)
Member: 1941778
my samsung galaxy y stocked at welcome screen, I followed this tutorial and solved the problem. But, before my internal storage is 4gb and after fixing it with this tutorial, the internal storage become 190mb only. Can you help me this, so I can bring it back to 4gb. Thanks in advance!
Old 06-27-2013, 13:25   #14 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 41
GT-S5360L Unlocked But show Locked
Hey I have a Samsung Galaxys Young GT-S5360L Was Unlocked allready But show Locked is from Claro I think This company put Something on the Software, How can I to Solve this.
Can see the Log:
Model Selected : GT-S5360L
Found Device : 0123456789ABCDEF
MODEL : GT-S5360L
BOARD ID : GT-S5360L
PLATFORM ID : bcm21553
OS VERSION : 2.3.6
BUILD ID : GINGERBREAD
BUILD DATE : Fri Jan 6 15:06:44 KST 2012
BUILD VERSION : GINGERBREAD.UHLA1
SOFTWARE VERSION : S5360LUHLA1
IMEI : ****************
(GSM)RIL VERSION : BRCM android bcm-ril-090728
(GSM)BASEBAND : S5360LUHLA1
(RIL)SW VERSION : S5360LUHLA1
(RIL)(RIL)HW VERSION : MP 0.700
Checking Root access: True
Backup created..c:\nck_dongle\\temp\samsung_backup\GT-S5360L_*****************\bml15
Unlock Done, Restarting Phone!
Regards bedel.
Old 07-19-2013, 08:17   #15 (permalink)
Member: 1224654
Sonork: jaheer
Thanks Meter: 45
sir cant detect sam s5360 cant detect pc..installed kies but cant detect plllllllllllllllssssssssssss
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 21:17
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 06:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 06:46
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-25-1999 16:50
Page generated in 0.40488 seconds with 8 queries
