Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
10-01-2012, 13:25 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Samsung GT-C3303k Champ Samsung Logo only Done via Free Software Samsung GT-C3303k Champ Samsung Logo only Done via Free Software Status Tools 1. Flasher: C3300K_Flash_loader_7.4.4_SSG_v0.5 2. Firmware: C3303KJPJI2 3. MicroUSB 4. C3303k Samsung Champ Phone 5. Prepare Phone Driver Procedure 1. Turn OFF Phone. 2. Connect MicroUSB to Champ. 3. Press Volume Down + Lock key then connect USB Cable to PC 4. Install driver (Driver can be found on C3300K_Flash_loader_7.4.4_SSG_v0.5 folder, 52xdfu)(Manual install it using device manager) When installed, get ready. Re flashing 1. Run Flash loader 7.4.4_SSG_v0.5.exe 2. Click SET MODEL -> Select C3300_LIBRE_Setting_v02.mdl 3. Check Application binary file -> browse for C3300KJP.ptt (From the C3303KJPJI2 folder) 4. Check TFS File -> Browse for C3303KJPJI2.tfs 5. Check CSC File -> Browse for C3303KOJPJI1.csc 6. Click Start 7. Turn OFF Phone. 8. Connect MicroUSB to Champ. 9. Press Volume Down + Lock key then connect USB Cable to PC 10. Wait the flashing finished. (During the Flashing, your phone is off, then when the flashing is finish, you can see the your phone is charging. 11. Remove from USB. Turn on the Phone, My Finish Product Thanks for the view |
The Following 4 Users Say Thank You to fertxter For This Useful Post: |
06-03-2015, 08:59 | #3 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Mashhad-Iran
Member: 2403164 Status: Offline Thanks Meter: 20 | Very Good ! But i have a Problem . I Do Steps Successful . When Select Start , See this Error : Errorid:108 Msg:Error During Communication Intialialization (in initse) and then phone was disconnect . what can i to do for fix this erroe ? |
The Following User Says Thank You to jenabictak For This Useful Post: |
