Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-01-2014, 22:10 | #1 (permalink) |
Junior Member Join Date: Mar 2013 Location: Here, there & everywhere..
Member: 1892980 Status: Offline Thanks Meter: 10 | Samsung GT S3322 Flashing 1) Execute the downloader Execute the ‘Flash loader 7.4.7_SSG_v0.1_Lite.exe’ program. (Notice : Flash loader supports only Single-CSC.) 2) Set Model Click "SET MODEL", and you can select appropriate model. You should choice "C3322_LAKOTA_Setting_v00.mdl" for further advance. 3) Select the binary, TFS, and CSC files Click "Partition Table", and you can select a certain binary. With browsing files, you can choice appropriate Flash-loader partition table all at once. After that, you should activate TFS, CSC. Also you can select the TFS files, and CSC files. (Notice : The buttons of TFS and CSC need to be activated not only after phone image is added first) 4) Select the download mode Click "START" to ready to download binary. (Notice : In this step, the mobile device actually don’t download the binary yet.) 5) Connect the device First, power off the device with battery. After that, connect PC with device using USB cable. (Don’t detach your finger from two keys.) In that case the device will power on and downloader recognize the device automatically 6) Complete download The download process is automatically executed. If "Slot freed for new download" message was shown without any problems, you now do wnloads the binary successfully. (Notice : After download process is completed, take care of the abnormal power off situ ation(ex. mount/demount battery) within the first booting time. It may causes malfunction) 7) Confirm Download - Reboot the device and confirm whether the device do normal operation. - When completing download, downloader is automatically initialized and ready for connecting next device. |
06-01-2014, 22:15 | #2 (permalink) |
Member: 1892980 Status: Offline Thanks Meter: 10 | After Flashing Using HWK SarsSoft Box. samsung c3322, when turn on a phone it will not start on the screen is only showing GT-C3322 samsung and blinking after few seconds. 1. Powered off phone with battery. 2. Press 1 + 3 3. Plug in usb cable. Flash with Flash loader 7.4.7_SSG_v0.1_Lite Don't forget install drivers from Sunstine directory inside flash loader archive. Now Using Flash Loader For Flashing But Not Working!!! Can't Download mode C3322! Anyone Any Suggest...??? |
