Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
08-16-2014, 14:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Root the Samsung Galaxy S3 Mini Value Edition (i8200)(i8200L) The only metod available to root this phone is with VRoot 1.7.6.5899 this is the chinese version , the english version doesn't work cause i tried and nothing ,i think that was impossible to root it but i tried the chinese version and it works. 1-Download VRoot in it official page , google it because i can't put links here cause i'm new member , the version that works it VRoot 1.7.6.5899 if there are a new version just download it. 2-Install VRoot. 3-Download and install Samsung Drivers , google it to 3-Activate debug mode in developer options , if you dont have developer options go to About Phone and press 7 or 10 times in Build Number or Compilation Number and the developer options will be available , after go to it and activate debug mode. 4-Allow instalation from external sources , ubicated in security options. 5-Open VRoot and wait to detect your phone , if not reconnect the phone to the computer or reinstall drivers. 6-When VRoot detect your phone press Next in VRoot and the root procedure will begin , it will install 2 chinese aplications 1 is like Aptoide and the other is the Superuser , you need SuperSu because it is the more stable , after the root finishes the phone will reboot and you have root acces. (Next Steps are optional because i'm gonna show you how to change to SuperSu) 6-Download SuperSu from Play Store , open it and install binaries. 7-Download Link2SD and make SuperSu a system application. 8-Reboot the phone. 9-Open SuperSu and if it asks you to update binaries , do it. 10-Go to Link2SD and uninstall the chinese apps that VRoot install. i8200N with the chinese version can be rooted, after that, installed supersu according to your method. (VRoot_1.7.8.7753_Setup.exe) english version is an older version http://click.xda-developers.com/api/...7753_Setup.exe (VRoot_1.7.3.4863_english_cid1005_7337ba1e_89.exe) |
08-16-2014, 14:41 | #3 (permalink) |
08-16-2014, 15:09 | #4 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 988667 Status: Offline Sonork: 1593975 Thanks Meter: 42 | thx root done but unlock failed! Waiting for phone... Checking if phone is Rooted... Root Access Granted! Processing... Connecting to phone... Operation failed! |
08-17-2014, 05:29 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear user! You wonder about the root because it had failed and said nothing about unlock. Could you tell me which tool you use to unlock the phone and because you failed. Thank you! |
