Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-28-2014, 14:31 | #1 (permalink) |
Junior Member Join Date: Jun 2006
Member: 299257 Status: Offline Thanks Meter: 19 | samsung P1300 error flash!!!!! but when i try to factory setting nothing happen,after restore complite phone just like first time... try flash with odin error in factoryfs load,but my phone booting normaly,nothing happen.... wipe with recovery mode,just got nothing happen to,phone booting normaly like first time setting... flash with another firmwre just same flashing with odin and BST dongle error.... |
06-28-2014, 14:37 | #2 (permalink) | |
Freak Poster Join Date: Jun 2014 Location: United States Of Islam
Member: 2203737 Status: Offline Sonork: 1656500 Thanks Meter: 462 | Quote:
Other names :Galaxy Tab 2 (7.0), P3100 GSM frequencies :850 900 1800 1900 Standard UMTS :2100 Type :Tablet-phone Dimensions (W x H x D) :193,70 x 122,40 x 10,50 mm Weight :344,00 g Main display :Color / PLS TFT 600 x 1024 px (7.00") 170 ppi Standard battery :Li-Ion 4000 mAh RAM memory :1 GB Memory cards : microSD, microSDHC (up to 32 GB) Operating system :Android 4.0 Ice Cream Sandwich Processor clock :1,00 GHz How to hard reset: Warning! All data will be lost! 1.Power off your tablet 2.Press together volume up + power button until Samsung logo appears on screen 3.Select with volume buttons "wipe data/factory reset" and press power button to confirm 4.Select "yes" with volume buttons and press power to confirm 5.Wait until format ends 6.Press power ton confirm "reboot" 7.Wait until the tablet restarts That's it! http://samsung-updates.com/tag/firmware/ http://www.redmondpie.com/how-to-roo...oid-4.0.3-ics/ | |
06-28-2014, 14:48 | #3 (permalink) | |
Member: 299257 Status: Offline Thanks Meter: 19 | Quote:
06-28-2014, 15:43 | #5 (permalink) | |
Write Firmware Put phone into Download mode. Connect the phone to PC via cable. Install required driver. Select firmware file. Click "Write firmware" button. Follow software instructions (prompts). Note: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don't turn off phone and don't disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Write Firmware to Octopus box http://octopus-server0.no-ip.biz:82/...sung/GT-P3100/ | |
