Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-25-2017, 00:27 | #2 (permalink) |
Freak Poster Join Date: Feb 2005 Location: At the Shop
Member: 120273 Status: Offline Thanks Meter: 57 | I replied in your other post. but will post here too for those looking. As far as I know the ONLY way is server unlock using app device unlock. ** NOTE: I have read people say you can flash a 935U/930U firmware and use compatible box to read code or direct unlock, then it either works while on U firmware or may have to flash back to T (tmobile) firmware? I do not know if this method works or not. I have not tried! IF YOU TRY IT - PLEASE POST RESULTS AND WHAT HARDWARE YOU USED. WE ALL WANT TO KNOW THE RESULTS! Thanks and GOOD LUCK. |
05-26-2017, 15:04 | #3 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Lebanon Age: 36
Member: 1424719 Status: Offline Sonork: 100.1619833 Thanks Meter: 2,563 | There is no free way. TO unlock u phone check the link below: IMEI or online Server Products - GSM-Forum Thread Closed |
