Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-24-2015, 08:42 | #33 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2279412 Status: Offline Thanks Meter: 6 | Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 00B100EC Reading security... error Done with Samsung Tool v.20.5 |
11-01-2015, 08:47 | #35 (permalink) |
Insane Poster Join Date: Jun 2011 Location: INDIA-A.P
Member: 1593885 Status: Offline Sonork: 1652227:mobile Thanks Meter: 7 | plzz help s3802 samsung after flash touch not working i try diffrent frimwares but not working .. before flashing touch is prefct after flash touch is not working |
03-25-2016, 14:37 | #36 (permalink) |
Junior Member Join Date: Mar 2009 Location: india (jammu)
Member: 986313 Status: Offline Sonork: [email protected] Thanks Meter: 7 | flash with urt rj45 on ufs then unlock tipe 00000000 done tested solution |
05-17-2016, 19:14 | #37 (permalink) |
No Life Poster Join Date: Oct 2011 Location: srilanka Age: 32
Member: 1674096 Status: Offline Thanks Meter: 49 | Downloads & Tools: - Samsung S3802 REX 70 DUOS Firmware Package (Extract after downloading). - Samsung S3802 FlashTool (Extract after downloading). - Suitable USB cable for Samsung S3802. - A computer with Windows OS installed. Samsung S3802 REX 70 Firmware Update Steps: - Turn off the device and take out its SIM and memory cards. - From the flasher folder run FlashTool_E2.exe - Now open the extracted firmware folder and you will see 5 files, Drag and drop them at the flashtool window in this order: S3802ODDMC5_USER.dfat S3802xxxxx_BSY.fls S3802xxxxx_CDS.fls S3802ODDMC5_CUST.dfat S3802ODDMC5_ROOT.dfat - Now Check these settings: Custom Order (Must be checked). Erases Calibration! : Select (Unconditional erase each area before write). Baud Rate: 921600 Communication Driver: IMC USB Driver. - Now you can click on Next button, And a new window will appear. - Click on Start USB1 button. - Now you have to connect your Samsung S3802 REX 70 Duos to PC using the USB cable. - There are more than one way to connect your phone, You can try any one of the following: 1- With the phone's battery in, Press and hold Home key then connect the USB cable to it. 2- With the phone's battery in, Press and hold Volume Down + Volume Up keys, Then connect the USB cable to it. 3- Connect the USB cable to phone without battery, After it is detected you can insert the battery. - When Windows detects the device it will ask for Drivers, So you have to browse for the FlashUSB_Driver_1_0_1_0 folder inside the FlashTool folder. - After the FlashTool starts the update process you have to wait for some minutes. - When the operation is done, You will see a Success word, And that means it was done right. - Disconnect the USB cable from phone. - With your Samsung Star 3 Duos on, Do a full reset by this code *2767*3855# - Now when your phone restart it will be ready for using with its new firmware. |
