Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 11-04-2009, 18:49   #1 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 352
samsung s5233a flashing tool
ttp://www.4shared.com/file/12240972..._Atma.html?s=1
But its not from the beginning.I am providing the tutorial in text format here.Do the first few steps as it says and follow the video tutorial for clear understanding.
1. Download Firmware and Multiloader from the site first. (i have attached it)
2. Make sure Samsung PC Studio is installed and communicates with your phone
3. Unrar the firmware in a folder you can easily find it.
4. Remove the Sim and MicroSD from your phone and replace the battery.
5. Now press vol top button+camera key+powerbutton at the same time in switch off mode without attaching the datacable.
6. Soon u will see a new screen which says Download.
7. Now attach the datacable to the phone and open Multiloader which u donwloaded earlier.
8. Select the radio button that includes MSM6250/MSM6250A or BRCM2133 for S5230/5233 (Samsung Star)
9. Select Boot Change,Full Download and master rom boxes.
10. Then click Boot, and select the boot files from the unpacked firmware folder.
11. Click the Amss, Rsrc1, and Rsrc2.
12. Select (Low).r2c NOT (Mid).r2c. (Phone may not restart if you select mid)
13. Then press the Factory FS tab, and select the appropriate files from the firmware folder also.
14. FOTA and ETC fields are left blank.
15. Click the Port Search button, it will find your phone and show the com port is ready.
16. Click the download button and be patient, this will take a few minutes to complete.
17. When it's finished, it will show "ok complete".
18. Unplug the phone from the USB cable, reinstall the sim, MicroSD, and power up the the phone.
19. Now with every thing complete, You can perform a hard reset by typing *2767*3855# into the hand set (but not necessary.)
20. When the phone resets type *#1234# into your handset to check your new firmware ver.
your new Firmware is updated and ready to use.But dont flash s5230 firmware with s5233a it will make the phone dead and it will also eliminate the warrenty of your cell.So be careful to use s5233a firmware which is not available free .Its available only for money.
if u any problem pm at yahoo
Br.
Ali.Imran
Old 11-04-2009, 23:20   #2 (permalink)
Member: 80698
Thanks Meter: 7
man i got s5230 and i wanna flash it with arabic, BUT i saw same model FLASHED with 5233a arabic flash and it works without any error... suggestions? thx
The Following User Says Thank You to homeros10 For This Useful Post:
Old 11-05-2009, 14:14   #3 (permalink)
Member: 156675
Br.
Ali.Imran
brother, i try this instrucctions with two phone and are dead. so someone can help me!
Old 11-07-2009, 19:27   #4 (permalink)
eyestrain's Avatar
Member: 237911
Thanks Meter: 605
the link is not working....
can you give me the correct link i will try your procedure
regards
Old 11-20-2009, 19:06   #5 (permalink)
Member: 2662
Thanks Meter: 2
hi
http://www.4shared.com/file/12240972..._Atma.html?s=1
The Following User Says Thank You to xkux For This Useful Post:
Old 11-20-2009, 19:07   #6 (permalink)
Member: 2662
Thanks Meter: 2
doble massage pardon
Old 11-24-2009, 18:09   #7 (permalink)
anjuman's Avatar
Member: 667941
Sonork: 100.1611812
Thanks Meter: 50
Red face
brother mobile daid complet now no power no bood model no download screen complet daid any solution i try with all box same any solution bro...b4 mobile was ok i want just change laguage turki.
Old 12-20-2009, 13:30   #8 (permalink)
Mehdi Ghorbani's Avatar
Member: 103931
Thanks Meter: 30
For SAMSUNG star type only use BCRM Chip option ....
Old 12-21-2009, 11:55   #9 (permalink)
tsarkh's Avatar
Member: 165812
Sonork: 100:1627635
Thanks Meter: 4,245
And Get All Samsung Original Flasher from HERE
Good Flashing For All
The Following User Says Thank You to tsarkh For This Useful Post:
Old 09-27-2010, 13:29   #10 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 142
s 5603 hang on samsung logo after flash
Old 09-27-2010, 13:30   #11 (permalink)
Member: 867442
Sonork: 100.1602740
Thanks Meter: 142
help me
Old 01-29-2011, 17:50   #12 (permalink)
Member: 1474581
Thanks Meter: 3
haha try and dead ....
Old 01-30-2011, 10:54   #13 (permalink)
Member: 1257334
Sonork: vinusp21
Thanks Meter: 45
Wink samsung D880
samsung d880 imei 00000 so pls any solucation
Z3x Team do you have any idea to release Samsung boot repair tool? Mr.3. Z3X-Team Products 2 03-29-2010 11:51
Samsung S5233A FLASH ERROR kasim UST Pro II 5 11-27-2009 08:17
samsung s5230 flashing with s5233a homeros10 2G Latest Models 5 11-07-2009 15:05
samsung u700 flashing tool akahmed Samsung Flashers, Software, Firmware. 2 11-13-2008 16:17
Page generated in 0.37232 seconds with 8 queries
