Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
02-04-2013, 22:09 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Serbia, Novi Sad Age: 40
Member: 116842 Status: Offline Thanks Meter: 3 | Samsung s5610 flashing problem |
The Following User Says Thank You to nk_darko For This Useful Post: |
02-05-2013, 09:31 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Kabul,Afghanistan Age: 35
Member: 496203 Status: Offline Sonork: 100.1583640 Thanks Meter: 232 | @nk_darko Flash only Ptt file with UFS3 using C3303l cable. Tested. |
The Following User Says Thank You to UNIQUEM For This Useful Post: |
03-08-2013, 18:33 | #9 (permalink) |
Member: 116842 Status: Offline Thanks Meter: 3 | Partition Table: S5610XXKH9.ptt Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2011 August Rev: 9 PROD_ID: 6B943D5E84750AFE SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] NAND Read Done, 131072 byte(s), Time: 00:04 BOOT Ok, 460800 Baud Partition IMAGE Erase Done, 6 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition MAIN Erase Done, 144 block(s), Time: 00:00 Partition PAGED Erase Done, 64 block(s), Time: 00:00 Partition a Erase Done, 424 block(s), Time: 00:00 Partition b Erase Done, 264 block(s), Time: 00:00 Partition c Erase Done, 900 block(s), Time: 00:00 Partition d Erase Done, 160 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition IMAGE Write Done, 786432 bytes(s), Time: 00:24 Partition LCDACT Write Done, 131072 bytes(s), Time: 00:04 Partition MAIN Write Done, 15034368 bytes(s), Time: 07:46 Partition PAGED Write Done, 4356068 bytes(s), Time: 02:15 Partition a Write Done, 37038144 bytes(s), Time: 18:36 Partition b Write Done, 8912640 bytes(s), Time: 04:28 Partition c Write Done, 1822656 bytes(s), Time: 00:55 Partition d Write Done, 145728 bytes(s), Time: 00:04 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition BOOTNAND Write Done, 37120 bytes(s), Time: 00:01 phone only blinks on samsung logo. whats wrong? |
04-27-2013, 09:14 | #14 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Galle, Sri Lanka Age: 40
Member: 77943 Status: Offline Thanks Meter: 56 | Flashing Guide for Samsung S5610 , S5610K 1. Run Flash loader 7.5.3 2. Select "set model" button & brows for S5610_Utopia_Setting_v00.mdl in flashloader derectory 3. tick "main" check box 4. press remove button 5. press "Main partition table" btton 6. Press "brows" at the bottom & select "S5610KOJPKI1.ptt" in your S5610k firmware folder 7. You can see several partition tabs in this window. check every check box available in all tabs. 8. Choose "RS232C" under communication settings & set 921600 as speed. 9. Connect your Z3X box any samsng box you have & Select its' com port number as the COM port 10. Press "start" & connect C3300K Micro UART cable to the phone. Wait until the flash loader finish his job. You are Done !! Remember !! Do not select any CSC file. Last edited by DineshDias; 04-27-2013 at 09:19. |
04-27-2013, 09:29 | #15 (permalink) |
Member: 77943 Status: Offline Thanks Meter: 56 | Up here is my experience on a Blinked S5610K. So in that way I suggest you to use S5610KOJPKI1 version for S5610k. Use a different firmware to avoid getting Binary crash error |
