Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 09-02-2010, 00:28   #1 (permalink)
toto05's Avatar
Member: 145076
Thanks Meter: 220
SAMSUNG S5620 Dead phone Repair FREE!!!!!
Samsung S5620 boot repair solution WITHOUT JTAG. Without any box FIRST IN THE WORLD!!!!
Download
The Following User Says Thank You to toto05 For This Useful Post:
Old 09-02-2010, 00:31   #2 (permalink)
ali.baydur's Avatar
Member: 687932
Sonork: 100.1619892
Thanks Meter: 110
Thanks A alot Bro...Good Share
Old 09-02-2010, 00:37   #3 (permalink)
Member: 179921
Thanks Meter: 35
only usb cable?
how can we connect without any configuration with drivers?
Old 09-02-2010, 00:38   #4 (permalink)
Member: 1358967
Sonork: 100.1585102
Thanks Meter: 99
what about s5150 is there any solution for that model i have dead pcs because i flash it with wrong file
Old 09-02-2010, 00:41   #5 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 243
Originally Posted by ymanzz View Post
only usb cable?
you need to use com cable (UART) for repairing boot area. usb cable can't help you anymore
good luck
Old 09-02-2010, 01:12   #6 (permalink)
Member: 179921
Thanks Meter: 35
you can use usb cable depends on the phone if you press 'volume down,camera,power'
says ''DOWNLOAD'' then you can flash the phone to 'multiloader' and this soft
AFAIK,
if phone does not appear anymore on the screen..then you make or modified UART com
or use any interface rj45 to connect..
Old 09-02-2010, 17:15   #7 (permalink)
Member: 973866
Sonork: 1603443
Thanks Meter: 243
if phone boot is bricked = you can't enter in download mode
if you can't enter in bootloader mode = you can't use usb cable.
if you can't use usb cable = use com cable.
we talk here about boot repair not simple flash for phone
good luck
Old 09-07-2010, 15:23   #8 (permalink)
Member: 194907
Thanks Meter: 102
link is bad please new link add
Old 10-26-2010, 10:17   #9 (permalink)
Member: 221245
Sonork: 100.1612390
Thanks Meter: 45
this solution not work ??????? juste erase boot but can't writh ?????
Old 10-27-2010, 01:40   #10 (permalink)
Member: 388862
Thanks Meter: 69
FREEEEE S5620 boot repair, no need any xyz box !
not work!!!!!!!!!!!!!!!!!!!!!!!
Old 10-27-2010, 09:42   #11 (permalink)
Member: 221245
Sonork: 100.1612390
Thanks Meter: 45
not work!!!!!!!!!!!!!!!!!!!!!!! lso whith z3x not wrk ???? any news /..?
Old 10-27-2010, 20:04   #12 (permalink)
Member: 1159099
Thanks Meter: 6,352
Thumbs down
This Is FAKE..!!! , No Working.
The Following User Says Thank You to xcachorrox For This Useful Post:
Old 04-16-2011, 21:42   #13 (permalink)
Member: 166142
Thanks Meter: 18
* NAND Flash Driver Download
preloader downloading > > > OK
NAND Flash driver downloading > > > OK
Flash Type Checking > > > OK
NAND Bad block check > > > 128 Bad block found
P.Block[55209] ---> S.Block[43043]
P.Block[41118] ---> S.Block[1365]
P.Block[40900] ---> S.Block[16947]
P.Block[61862] ---> S.Block[53521]
P.Block[48752] ---> S.Block[31075]
P.Block[6517] ---> S.Block[10373]
P.Block[61670] ---> S.Block[56544]
P.Block[45753] ---> S.Block[2531]
P.Block[6584] ---> S.Block[44716]
P.Block[730] ---> S.Block[41993]
P.Block[2558] ---> S.Block[45378]
P.Block[36153] ---> S.Block[14580]
P.Block[30311] ---> S.Block[61874]
P.Block[12297] ---> S.Block[57444]
P.Block[18798] ---> S.Block[53509]
P.Block[8024] ---> S.Block[29162]
P.Block[51765] ---> S.Block[36878]
P.Block[8336] ---> S.Block[63734]
P.Block[17657] ---> S.Block[18456]
P.Block[30412] ---> S.Block[17645]
P.Block[26625] ---> S.Block[24925]
P.Block[51482] ---> S.Block[27049]
P.Block[5257] ---> S.Block[8946]
P.Block[18283] ---> S.Block[19921]
P.Block[31303] ---> S.Block[64793]
P.Block[17535] ---> S.Block[55363]
P.Block[49417] ---> S.Block[30074]
P.Block[21273] ---> S.Block[10472]
P.Block[42753] ---> S.Block[56023]
P.Block[20184] ---> S.Block[24767]
P.Block[12228] ---> S.Block[43990]
P.Block[14907] ---> S.Block[19449]
P.Block[10789] ---> S.Block[44617]
P.Block[2287] ---> S.Block[52849]
P.Block[19172] ---> S.Block[16905]
P.Block[19702] ---> S.Block[48472]
P.Block[6966] ---> S.Block[12921]
P.Block[51277] ---> S.Block[34138]
P.Block[63196] ---> S.Block[1196]
P.Block[30408] ---> S.Block[5558]
P.Block[26044] ---> S.Block[7044]
P.Block[47995] ---> S.Block[46302]
P.Block[41080] ---> S.Block[17397]
P.Block[17216] ---> S.Block[29207]
P.Block[58342] ---> S.Block[62611]
P.Block[42530] ---> S.Block[50303]
P.Block[35688] ---> S.Block[25286]
P.Block[41451] ---> S.Block[36314]
P.Block[43304] ---> S.Block[55185]
P.Block[16383] ---> S.Block[9917]
P.Block[6324] ---> S.Block[52276]
P.Block[63126] ---> S.Block[64981]
P.Block[21239] ---> S.Block[7272]
P.Block[24917] ---> S.Block[29497]
P.Block[49317] ---> S.Block[33121]
P.Block[65224] ---> S.Block[61862]
P.Block[20411] ---> S.Block[12830]
P.Block[52922] ---> S.Block[47221]
P.Block[50718] ---> S.Block[39156]
P.Block[25320] ---> S.Block[64922]
P.Block[63573] ---> S.Block[22485]
P.Block[4855] ---> S.Block[33054]
P.Block[1235] ---> S.Block[4034]
P.Block[27156] ---> S.Block[60522]
P.Block[17718] ---> S.Block[34841]
P.Block[17172] ---> S.Block[12379]
P.Block[62315] ---> S.Block[26660]
P.Block[39800] ---> S.Block[5647]
P.Block[36566] ---> S.Block[9058]
P.Block[22070] ---> S.Block[1989]
P.Block[4750] ---> S.Block[63956]
P.Block[23660] ---> S.Block[21174]
P.Block[16333] ---> S.Block[41052]
P.Block[26698] ---> S.Block[21045]
P.Block[972] ---> S.Block[27543]
P.Block[7071] ---> S.Block[49628]
P.Block[48883] ---> S.Block[37030]
P.Block[3281] ---> S.Block[2320]
P.Block[16976] ---> S.Block[52107]
P.Block[28062] ---> S.Block[9586]
P.Block[4582] ---> S.Block[52797]
P.Block[5525] ---> S.Block[5237]
P.Block[32809] ---> S.Block[46377]
P.Block[49779] ---> S.Block[45309]
P.Block[8843] ---> S.Block[59655]
P.Block[15616] ---> S.Block[62014]
P.Block[38194] ---> S.Block[38929]
P.Block[23563] ---> S.Block[29089]
P.Block[11907] ---> S.Block[28697]
P.Block[27663] ---> S.Block[46533]
P.Block[8141] ---> S.Block[26197]
P.Block[3067] ---> S.Block[54742]
P.Block[31458] ---> S.Block[51854]
P.Block[64872] ---> S.Block[33406]
P.Block[16524] ---> S.Block[12360]
P.Block[2440] ---> S.Block[15958]
P.Block[14550] ---> S.Block[22555]
P.Block[8948] ---> S.Block[39657]
P.Block[21572] ---> S.Block[16935]
P.Block[63919] ---> S.Block[48430]
P.Block[42949] ---> S.Block[7980]
P.Block[11890] ---> S.Block[42294]
P.Block[6596] ---> S.Block[15898]
P.Block[63610] ---> S.Block[58501]
P.Block[50735] ---> S.Block[48745]
P.Block[7807] ---> S.Block[10005]
P.Block[43052] ---> S.Block[58984]
P.Block[56320] ---> S.Block[5578]
P.Block[58232] ---> S.Block[7587]
P.Block[55489] ---> S.Block[51719]
P.Block[7524] ---> S.Block[36330]
P.Block[62278] ---> S.Block[52022]
P.Block[5385] ---> S.Block[62101]
P.Block[56955] ---> S.Block[4385]
P.Block[565] ---> S.Block[3669]
P.Block[28802] ---> S.Block[63081]
P.Block[47030] ---> S.Block[21485]
P.Block[62745] ---> S.Block[60893]
P.Block[43356] ---> S.Block[41573]
P.Block[40950] ---> S.Block[38372]
P.Block[20253] ---> S.Block[29096]
P.Block[25638] ---> S.Block[41311]
P.Block[49701] ---> S.Block[16039]
P.Block[24362] ---> S.Block[53576]
P.Block[39111] ---> S.Block[55276]
P.Block[43522] ---> S.Block[57638]
P.Block[50288] ---> S.Block[34771]
P.Block[62504] ---> S.Block[23436]
OK
UART Download Mode > > > Available
Old 07-02-2011, 23:13   #14 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
pinout on pcb please
pin phone damaging
Thanks
Old 08-29-2011, 11:52   #15 (permalink)
Member: 1059194
Sonork: 100.1612797
Thanks Meter: 20
OK
pls give me all etaps for repaire boot
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.45080 seconds with 8 queries
