Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 06-13-2017, 00:38   #76 (permalink)
Member: 2446993
Thanks Meter: 3
not work for me
thanks
Old 06-14-2017, 13:37   #77 (permalink)
Member: 986038
Thanks Meter: 43
me to not warking n G955F thanks hosam
Old 06-15-2017, 13:22   #78 (permalink)
Member: 2702567
It's done with me. G955F Cheers
Old 06-16-2017, 01:28   #79 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,248
Originally Posted by legende85 View Post
not work for me
thanks
What is the problem ??
Old 06-16-2017, 01:28   #80 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,248
Your are always welcome My friend
Old 06-16-2017, 01:28   #81 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,248
Old 06-17-2017, 00:42   #82 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 38
Samsung S8 / S8 Plus 100% Working [FRP][RESET][SOLUTION] !!!
all work smooth and fine like silk.
wbr.
The Following User Says Thank You to dcosmin22 For This Useful Post:
Old 06-17-2017, 06:56   #83 (permalink)
Member: 2727950
J3 prime frp
Can anyone help me remove frp on galaxy J3prime
Old 06-18-2017, 07:26   #84 (permalink)
Member: 1832732
I have a SM-G950U G950USQU1AQEF Verizon USA FRP Locked
I need to get this removed.
What Combination Files or Method can I use?
Old 06-18-2017, 08:38   #85 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 38
Friend , Read full post and you will see, confirmed that is true fact. I was removing OEM and FRP account of G955F/ S8+
Old 06-19-2017, 17:17   #86 (permalink)
Member: 2456749
Thanks Meter: 7
i am sorry when i look at the file for g955u i dont see any sboot image am i doing something wrong
Old 06-19-2017, 20:49   #87 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 38
If YOU have pro version you can se that before x mark sign, or uncheck every field you can select every file on each line(ap, bl, cp, csc). This option in on the right side marked with ..(two points). So if more explanation than this needed than you must go to school( i' m joking). Hope will help. Good day.
Old 06-19-2017, 23:47   #88 (permalink)
Member: 2456749
Thanks Meter: 7
sorry i was trying to run it through odin but he said the sboot file is needed not the actual bootloader which is what i am having trouble finding like what use to exist on the sm-g925 phones when you extracted firmwares youd find a sboot.bin but on these firmwares i dont find them at all
Old 06-19-2017, 23:47   #89 (permalink)
Member: 2456749
Thanks Meter: 7
Old 06-20-2017, 06:04   #90 (permalink)
Member: 2456749
Thanks Meter: 7
if you use the sm-g955u eng-root you can avoid the entire combination issue and just run the adb command "adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1" (without quotation marks) and youll bypass the frp then just enable developer and enable oem unlock and usb debugging and youll resolve it. Hope this helps those like me who couldn't resolve using the files provided. I am sure they work just couldnt figure it out. This method im not sure who developed it at all but i was told by local friend so i do not want to take any credit. P.s. the eng-root file can be found on here just look for bawanyh he posted the files.
The Following User Says Thank You to jeremy93 For This Useful Post:
Page generated in 0.22842 seconds with 9 queries
