Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 09-23-2017, 22:46   #166 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
any way for Canadian version SM-G950W8
Old 09-24-2017, 00:12   #167 (permalink)
Member: 2400913
thank´s a lot, 100% working
Old 09-24-2017, 06:33   #168 (permalink)
Member: 169896
Thanks Meter: 323
get its combination file then do factory reset then use 4files firmware. done
i have personally tested on several G950W and G955W
Sent from my SM-G950W using Tapatalk
Old 09-24-2017, 11:23   #169 (permalink)
Member: 2751370
good job,thanks thank thank tnahn
Old 09-24-2017, 16:46   #170 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
thx for answer
you have combination file for g950w ?
Old 09-25-2017, 15:08   #171 (permalink)
Member: 1940476
Thanks Meter: 27
worked perfectly! just make sure after flashing combination to flash BL, AP,CP,and HOME CSC and not the CSC. then bingo!
Old 09-26-2017, 11:02   #172 (permalink)
Member: 6250
Thanks Meter: 14
G950f???
Not work on g950fxxu1aqf7_g950fpls1aqf3
if tray flash home_csc phone not flashed bcoz frp refuse flash home_csc
Old 09-28-2017, 16:21   #173 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Sir,
iam having G955FXXU1AQH3 in phone, can i use COMBINATION_FA70_G955FXXU1AQDB file to remove frp.
Or will it brick my device because of version in phone is higher than you file.
Pls clear it as much possible.
Old 10-01-2017, 14:44   #174 (permalink)
Member: 2225323
Message:
sir, my englesh in not good but i will try my best
sir i have golden box z3x, using latest samsung tool pro latest verson
29.4 my problem is this
when i frp samsung phones latest like g935f and g610f for frp, all
work done by tool but phone has still frp when i on after all process
i am doing like this
1 flash whole file combination
2 after sucess flash file, when phone on i reset mannually in backup
and reset option
3 after abouve process put download mode and flash firmware
but after sucess on frp still available..
plz help me and tell me process about all frp
Old 10-02-2017, 22:31   #175 (permalink)
Punto-Móvil's Avatar
Member: 1147852
Thanks Meter: 587
Hi there brothers ,
In my case SM-G955f both flash operation went good but phone hangs in logo boot loop , i tried flashing sboot and boot files but software says write firmware failed ad phone reboots.
has anyone faced something like this.
Best Regards
Punto-Movil
Old 10-03-2017, 09:56   #176 (permalink)
Member: 1147852
Thanks Meter: 587
Originally Posted by Punto-Móvil View Post
Hi there brothers ,
Best Regards
Punto-Movil
The solution was a simple hard reset and the phone booted correctly but unfortunately frp is still there.
i Will try again and post result.
Punto-Movil
Old 10-03-2017, 11:45   #177 (permalink)
Member: 1147852
Thanks Meter: 587
Originally Posted by punto-móvil View Post
the solution was a simple hard reset and the phone booted correctly but unfortunately frp is still there.
I will try again and post result.
Punto-movil
worked perfectly, like a charm.
In second try with same files .
After first try hard reset to fix boot loop and try again.
Done in less than 20 min.
Thanks for sharing
best regards
punto-movil
Old 10-05-2017, 06:44   #178 (permalink)
Member: 2187370
Thanks Meter: 2
Thanks it works with SM-950f
Old 10-06-2017, 15:48   #179 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
s8+ from nz g955f frp
will this file work proper?
Old 10-10-2017, 09:34   #180 (permalink)
Member: 1167880
hi
what about G950FXXU1AQH3??
Page generated in 0.24515 seconds with 10 queries
