Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-02-2018, 08:12 | #301 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | 100% worked.... My Samsung S8 done Last edited by ...:::::NP™:::::...; 03-02-2018 at 19:21. Reason: qutote has been removed |
03-03-2018, 18:44 | #307 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
03-08-2018, 04:30 | #309 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2815139 Status: Offline Thanks Meter: 2 | Gracias! A continuacion describo el metodo que me funciono con exito en SM-G955FD Primero flashe el archivo combinacion completo con odin Segundo flashe con z3x el firmware descargado de este post segun mi modelo de la siguiente manera: en la casilla BL solo el archivo SBOOT, en la casilla AP los archivos BOOT, RECOVERY Y SYSTEM Luego cuando inicio desplegue hacia arriba, fui a configuración hice factory reset y reinicio ya sin cuenta Para finalizar le volvi a flashar el firmware completo con z3x y trabajo terminado |
The Following User Says Thank You to wor1981 For This Useful Post: |
03-14-2018, 03:11 | #311 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2657545 Status: Offline Thanks Meter: 11 | G955f has OEM Lock: ON and tried everything but still no luck. Can anyone help? I always get "custom binary blocked by OEM Lock" measage Sent from my F3213 using Tapatalk Last edited by plugin068; 03-14-2018 at 03:28. |
03-14-2018, 07:44 | #312 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | what do you want to do? there is no frp in your phone. go to menu/settings/about/software info/ tap 7 times on build number...go back to menu/developer/oem lock... |
03-17-2018, 04:27 | #313 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2821815 Status: Offline Thanks Meter: 0 | Tried so many so far and still not working. Better S8 950u combination file needed or impossible task [get failed (auth)] android 7.0 security patch dec 1st G950USQS2BQL1 Halp plz? Pm if needed |
03-20-2018, 09:47 | #315 (permalink) | |
Freak Poster Join Date: Mar 2013 Location: In your Mind Age: 35
Member: 1902758 Status: Offline Sonork: 100.1680534 Thanks Meter: 153 | Quote:
The Following User Says Thank You to saifulhaq28 For This Useful Post: |
