Need solutin for sm-g955n thank |
S8+ good file thank u |
Knox will be at 1 after frp remove? |
Step By Step Full Guide & Video Solouation Welcome Friends.. Today I Will See You How To remove FRP From Samsung S8 & S8+ Need : Combination File & Original 4 Part Firmware & ODIN Flasher Lets Start (A) Download Odin Latest (1) Download Combination File (2) Download Original Four Part Firmware Latest (3) At First Flash Combination File Via Odin (4) After open Your Smart Phone Go To Notification Bar & Click Settings iCon (5) Now Enable Devoloper Mode From Down (6) Now Flash Original 4 Part Firmware (Note: Odin CSC Option Select (Important) Home File From Firmware (7) After Flash Compleate When Your Phone Open Recovery Menu Select Rebot Your System (8) After Open Its Want Reset Click Reset (9)After Reset Your Device Open Sucess (10) When Open Your Phone First Time Its Need Click Lock Button 1 Time (11) Now Just Skip All Option Step By Step (12) Its Magic ..Unlock Yor Phone (13) Now Go To Settings And Enable OEM Unlock ... |
[QUOTE=hosam kashto;12516320]Flash by choosing g935f in z3x box[/QUOTPLEAS SHARE FIRM WARE LINK |
Downloaded the combination file for G955U but when I try to load using Odin I get error message: md5 error! Binary is invalid. Downloaded file twice and used 7-Zip to uncompress. |
Figured out my problem Unziped the rar file and then renamed file just by removing the md5 extencion |
works like a charm. after 3 times trying thanks hosam kashto for who facing error binary invalid in odin try to use another box like miracle/z3x tested via miracle |
i have got S8 i flashed combination file working fine AND REMOVE frp then trying to go back its original firmware but its failed on System image. Afterward whenever i tried to flash with original file it says setup connection erorr Odin Initialzation fail and reboot its self and stuck on samsung logo. i used different samsung phone J3 flashing ok Easily i can go download mode on S8 but cant go recovery mode Need help Please |
Help REMOVE frp g950u1 ? |
Can i use odin tool for flashing |
Yes you can use latest version of Odin v3.12.7 |
See Youtube Last Update Quote:
