-   Samsung Flashers, Software, Firmware. (http://forum.gsmhosting.com/vbb/f200/)
-   -   Samsung S8 / S8 Plus 100% Working [FRP][RESET][SOLUTION] !!! (http://forum.gsmhosting.com/vbb/f200/samsung-s8-s8-plus-100-working-frp-reset-solution-2227905/)
hosam kashto 05-28-2017 10:31
Originally Posted by ghafat (Post 12520298)
Is this method work on SM-G950N?Korea Telecom?
I don't try you can try and choose g950u combination i think
ghafat 05-28-2017 10:44
I really want to try but when i search for the stock firmware of my phone(in order to unbrick if something goes wrong with the phone),i cant find one so this is very risky if G950u fails and bricked my phone.
n1viperx 05-28-2017 20:41
Needed root to get msl code, flashed twrp recovery for the root. After i tried maze and atiroot software and all got error, unable to mount partition data, somethhing like that so i decided to reflash soft that give me error with fit file. After i did success install the combinatii. File but factory mode did not finish boot. The download mode is a black screen with some steange text. What can i do to flash good firmware and root for msl code ? Final destinatio. Is unlock via z3x. Mention frp is off on the phone. G955F
n1viperx 05-28-2017 23:24
https://s20.postimg.org/4s3upgkgd/IMG_0991.jpgimgupload
https://s20.postimg.org/rsai1sia5/IMG_0990.jpgpost image
n1viperx 05-28-2017 23:39
Operation: Flash
Selected model: SM-G935F
Software version: 28.2
File analysis... Ok
Total file size: 0x15F58C277 (5621 Mb)
Searching USB Flash interface... COM15 detected
Setup connection... Ok
Set PIT file... Error
Done with Samsung Tool PRO v.28.2
Managed to flash something with odin but i still get this. please help?
n1viperx 05-28-2017 23:56
<ID:0/015> Odin engine v(ID:3.1203)..
<ID:0/015> File analysis..
<ID:0/015> SetupConnection..
<ID:0/015> Initialzation..
<ID:0/015> Set PIT file..
<ID:0/015> DO NOT TURN OFF TARGET!!
<ID:0/015> FAIL!
<ID:0/015>
<ID:0/015> Re-Partition operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
same error in odin.. i dont know how to fix this
pclion 05-29-2017 00:52
u need to flash only the boot sboot from combination and press adb frp reset over z3x... and than after unlocked frp and OEM Unlock u can flash boot sboot from correct stock firmware back...
to flash complete combination firmware is risky....as u can see in this post many devices dead...
n1viperx 05-29-2017 01:18
How can i activate the sub meniu for this flash, i know what you mean to select but i dont have this option to select files
pclion 05-29-2017 03:08
are u now in download mode ?
what is the last state of your device ? black background with green text ? if yes so force your device by holding power vol down home to get into download mode by pressing for 1 minute ..
n1viperx 05-29-2017 03:20
phone has combination file flashed. will not boot fully. if i try download mode it has black screen like in the picture, i try to flash BL file a few seconds then cancel and then i can access download mode normal but if i want to flash ... with full load ap csc bl it just stops at pit file...
hosam kashto 05-29-2017 11:26
I have firmware for this device i will upload it
hosam kashto 05-29-2017 11:28
You mean you need to reset msl to unlock, If that what you need this topic can't help you. Here is solution just for frp reset not msl.
Originally Posted by n1viperx (Post 12520983)
Operation: Flash
File analysis... Ok
Try to use smart switch or the latest version of Odin
hosam kashto 05-29-2017 11:31
Bro, when you flash only sboot and boot from the combination the device, will hang on the logo I tried it, I tried it and I tested flash combination all files and it worked.
hosam kashto 05-29-2017 11:33
Download this firmware from here
and flash it
Page generated in 0.29721 seconds with 5 queries
