you can flash with ODIN. when flash, select AP, BL, CSC. It's working 100% |
Works perfekt thanks for sharing!!!! |
i am having problem with s8 g950f i have flashed with comination file i enable usb debugging power off phone and enter download mode using odin i flash ap ,bl, csc ,using your files odin flashes but gives fail at end because of frp |
what am i doing wrong 1. flashed combination file 2. enabled usb debugging 3. i Dont see OEM in settings or anywhere in menu to enable 4. powered phone off , eneter download mode using odin 5. using G950FXXU1AQDD_OXM1AQDD_Arabic_v7.0_Halabtec i flash all 4 parts BL , AP , CP, CSC 6. Gives error on phone , custom binary omr , blocked by frp lock please advise exactly how to enable oem and exactly which parts of G950FXXU1AQDD_OXM1AQDD_Arabic_v7.0_Halabtec need to be flashed and what is meant by hard reset, through phones menu or volume power up |
@ nbkappa Please read this thread carefully from beginning. Especially:- http://forum.gsmhosting.com/vbb/12516821-post19.html http://forum.gsmhosting.com/vbb/12519940-post30.html |
CUSTOM BINARY (OMR) Blocked by FRP |
I can enable usb debugging with combination file i have attempted to flash BL , AP AND CSC HOME With the firmware provided at this post , it says CUSTOM BINARY FRP OMR BLOCKED With other ORIGINAL stock firmwares , stops at CSC , hidden i think it may be Boot protected to only flash with the original software of the phone that is 3UK but i am not sure why this is happening but it is not allowing combination file then only BL AP AND CSC |
anyone who can help ? |
We Here to help when we have free time in this post everything is simply explain Ohh I forget thanks for sharing how you fix the problem with us |
hello i have frp g955u try download combination file, in odin show md5 error. try on z3x odin protocol version eror any solution? |
flash it by z3x by choosing g935f |
