Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 10-12-2017, 16:45   #181 (permalink)
Member: 694535
Thanks Meter: 49
witch combination file can i use for G9550ZHU1AQG6 ?
Old 10-12-2017, 17:50   #182 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 210
Originally Posted by tiyam 01 View Post
what about G950FXXU1AQH3??
I need solution for this firmware also
Old 10-12-2017, 20:26   #183 (permalink)
Member: 558861
Thanks Meter: 14
Originally Posted by Punto-Móvil View Post
Hi there brothers ,
In my case SM-G955f both flash operation went good but phone hangs in logo boot loop , i tried flashing sboot and boot files but software says write firmware failed ad phone reboots.
has anyone faced something like this.
Best Regards
just install combination file than turn on usb debb and oem unlock
use z3x frp option
install stock firmware thats all
The Following User Says Thank You to mohammadfayyaz For This Useful Post:
Old 10-13-2017, 18:33   #184 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 217
after flash combinacion file ...theres no opcion oem unlock now ken y make appers???
fone is g955f
flash wed COMBINATION_FA70_G955FXXU1AQDB_Halabtech.tar.md5
and COMBINATION_FA70_G955FXXU1AQF1_CL11405575_QB138044 43_REV00_user_mid_noship.tar.md5 but same oem unlock opcions whant appers on developer options
help is need...
Old 10-15-2017, 14:26   #185 (permalink)
Member: 2332515
Sonork: 100.1678906
Thanks Meter: 63
i can help you
you still need help?contact me
Old 10-16-2017, 17:20   #186 (permalink)
Member: 2768686
Sonork: iuo9
hello i can flash with odin and then reset phone from menu. so remove frp?
Old 10-17-2017, 15:19   #187 (permalink)
Crazy Poster
Member: 1731024
Thanks Meter: 11
it work for me on S8...
Old 10-17-2017, 17:30   #188 (permalink)
Member: 1817436
Thanks Meter: 12
Thumbs up Confirm working verry easy !!!
Here an explanation!.
Originally Posted by MORRISGSM View Post
anyone who can help ?
If you read the post carefuly, you can did it all with out problem. Any way.
First: Flash combination file (I did it all with z3x using G935f, my phone G950f)
Second: Flash normal firmware, go to flash section z3x, presets and choose the firmware carpet, then you will see "..." click there, just mark:
BOOT: sboot.bin
PDA:boot.img , recovery.img , sistem.img
CSS: cache.ima.
And flash. That set.
Thank you for the files, and explanation. Work for me like a charm!. Cheers!
Report Post
The Following 2 Users Say Thank You to mkycyan For This Useful Post:
Old 10-18-2017, 19:27   #189 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 336
Originally Posted by hosam kashto View Post
Hello All GSMHOSTING User Here Gift From HalabTech_Team
You need Combination files download from here:
You need firmware download from here:
SM-G955U : G955USQU1AQC8_CL10895874_QB12856026_REV00
Firmware un-rar pass:- halabtechteam
To begin with, You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache.
The phone need 15 min to boot up then only click next-next-next or swipe from up the notification bar and go to setting then to enable OEM and make hard reset.
If your phone still boot hang on logo just re-flash sboot + boot from normal firmware.
Video Of ALL Work From Here
Note: You can choose any model you want to flash by z3x to skip other partition, You don't need to make reset frp by adb only read this topic.
All Done
I can't make this solution work on SM-G950N after write all required files I get the message on phone:
"Device storage corrupt" - "RESET" ?
If I press reset button I have to start allover and the same...
Does anyone knows what I have to do to skip this messahe without reset ???
Old 10-23-2017, 19:41   #190 (permalink)
Member: 2115816
On the CSC you have to flash the HOME_CSC not the CSC, and use Cache from it.
The Following User Says Thank You to soulsearching For This Useful Post:
Old 10-25-2017, 19:08   #191 (permalink)
Member: 51005
Thanks Meter: 3
G955f worked easy. thank you!
Old 10-27-2017, 10:49   #192 (permalink)
Member: 894224
Thanks Meter: 85
thanks works like charm
Old 10-27-2017, 19:29   #193 (permalink)
Member: 666861
Thanks Meter: 18
I tested s8, s8+ .working perfect. Thank you
Old 10-28-2017, 13:24   #194 (permalink)
Member: 2095476
Need solution for sm-g955n please.
Old 10-29-2017, 18:31   #195 (permalink)
Member: 2770834
hi is there any solution for 955w frp locked?
Page generated in 0.19839 seconds with 8 queries
