Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
01-30-2018, 01:23 | #275 (permalink) | |
Junior Member Join Date: Sep 2008
Member: 871296 Status: Offline Thanks Meter: 2 | works Quote:
01-31-2018, 17:20 | #276 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2099365 Status: Offline Thanks Meter: 0 | Hi i have this version G955USQU2BQK5_OYN2BQK5, i try to downgrade to G955USQU1AQDE_OYN1AQDE, but not working i have this error system fused 2>binary1. Please give me the solution for this probleme. Thank u |
02-04-2018, 07:54 | #279 (permalink) |
Freak Poster Join Date: Feb 2010 Location: P A K I S T A N Age: 43
Member: 1242837 Status: Offline Sonork: 100.1653310 Thanks Meter: 53 | samsung s8+ Frp method 10000% tested and ok. Hi HALABTECH Thanks for sharing This method is 100000% tested and safe. thanks Best regards Tausif Mughal Kuku Mobiles Sahiwal Last edited by ...:::::NP™:::::...; 02-06-2018 at 06:10. Reason: quote has been removed |
The Following User Says Thank You to tausifawais For This Useful Post: |
02-04-2018, 07:57 | #280 (permalink) |
Freak Poster Join Date: Dec 2008 Location: uae.abudhabi
Member: 930738 Status: Offline Sonork: 100.1652204 Thanks Meter: 8 | 100% working bypass https://www.youtube.com/channel/UClh...aTHd3txyYCpauw |
02-06-2018, 02:10 | #281 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2382569 Status: Offline Thanks Meter: 1 | This method only works for updates lower than 7 As they have disabled bluetooth connection when making the call |
The Following User Says Thank You to Rhodesy1 For This Useful Post: |
02-07-2018, 00:51 | #283 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | COMBINATION_FA70_G9500_G9508_ZCU1AQE6 not flash?????????????? Operation: Flash Selected model: SM-G9500 Software version: 30.7 File analysis... OK Total file size: 0x822DB6A3 (2082 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Sending abl.elf... error timeout Done with Samsung Tool PRO v.30.7 |
02-07-2018, 21:03 | #285 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | Thanks for the trick , That was the solution for the md5 fverification error in ODin . I used to flash the combination file in octopusbox but after latest update 2.6.4 i started getting msg firmware write failed. One more galaxy S8 done. Thanks again and Best Regards Punto-Movil |
