Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 03-20-2018, 09:49   #316 (permalink)
saifulhaq28's Avatar
Member: 1902758
Sonork: 100.1680534
Thanks Meter: 153
Originally Posted by wor1981 View Post
Gracias!
A continuacion describo el metodo que me funciono con exito en SM-G955FD
Primero flashe el archivo combinacion completo con odin
Segundo flashe con z3x el firmware descargado de este post segun mi modelo de la siguiente manera: en la casilla BL solo el archivo SBOOT,
en la casilla AP los archivos BOOT, RECOVERY Y SYSTEM
Luego cuando inicio desplegue hacia arriba, fui a configuración hice factory reset y reinicio ya sin cuenta
Para finalizar le volvi a flashar el firmware completo con z3x y trabajo terminado
Next time Please write in english...
Old 03-20-2018, 09:54   #317 (permalink)
Member: 1902758
Sonork: 100.1680534
Thanks Meter: 153
Originally Posted by ..Ali Abbas.. View Post
S8+ G955U1 Combination File needed....
PLEAS
This Is Your LINK (Torrent)
Old 03-22-2018, 07:36   #318 (permalink)
Member: 2821815
Originally Posted by saifulhaq28 View Post
[LINK] is your File (Torrent)
Sadly that torrent is dead.
Also, that is the arabic file? This is the US model?
Thank you anyway!
Still auth error so method patched, along with all others?
Can confirm remote FRP removal is viable?
say paid service?
Thanks for all help anyway!
Old 03-22-2018, 08:05   #319 (permalink)
Member: 930738
Sonork: 100.1652204
Thanks Meter: 8
Samsung S8/S8 Plus 100% Working FRP SOLUTION 2018
https://www.youtube.com/watch?v=Yss4MfnvEXk
Old 03-22-2018, 23:47   #320 (permalink)
Member: 2823679
Thanks Meter: 4
thank you anyway bro
Old 03-23-2018, 21:43   #321 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Originally Posted by hosam kashto View Post
[B]
To begin with, You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache.
The phone need 15 min to boot up then only click next-next-next or swipe from up the notification bar and go to setting then to enable OEM and make hard reset.
HALABTECH
for this it working 100%
Old 03-24-2018, 16:30   #322 (permalink)
Member: 2578681
Thanks Meter: 8
Originally Posted by prodisma69 View Post
After flash combination file my s8(g950f) dead. I follow step by step procedure but phone dead. Any solution to alive phone...
Or another solution to frp s8
That phone not dead, usually because different sboot files, now just login to odin mode and flash again with anothers sboot files, you done
Old 03-27-2018, 16:37   #323 (permalink)
Member: 1908841
Sonork: 1654814
Thanks Meter: 48
S 8 G950 F FRP Unlock ok. with Combination
Dear
thanks.
100000% ok Solution.
Old 03-28-2018, 10:40   #324 (permalink)
Member: 523082
Thanks Meter: 9
I succeded this by only using OCTOPUS.
1. I flashed Combination then selected all flashfiles : BOOT, AP, CP, and CSC (HOME) after I only selected: system+sboot+boot+recovery+cache.
its done successfully.
NB: Dont forget to specify on octopus that u want to use original flashfile instead of octopus 1.
The Following 2 Users Say Thank You to imamuka For This Useful Post:
Old 03-29-2018, 22:47   #325 (permalink)
Member: 2645939
Thanks Meter: 3
y para la version G955U1 no consigo conbination
Old 04-01-2018, 02:24   #326 (permalink)
Member: 2146504
Sonork: medd303
Have 2 phones samsung S8 plus android 7 Nougat , every one have an issues tooooo confused
# G955u , succes flashing combination and can't flashing the Rom untill the phone is dead can't open it again , and now im mood HS-USB QDloader 9008 =====> I'm still confused with that issue , i not found the qualcomm files for S8 plus G955u .
# G955N , Failed while flashing comination , get error while used Odin and octoplus box
I think that problem because should enable USB Debugging Mode , But i dont know how to Enable it , and the phone is locked even I tried Headset phone ( *#0808# )
Plzzzzz HEEEEEEELP for any Solution Guys
Old 04-01-2018, 05:41   #327 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 38
You must write in English as forum is an english one
Old 04-04-2018, 15:16   #328 (permalink)
Member: 2722596
s8
not working .....with combination file.
The Following User Says Thank You to jeelani422 For This Useful Post:
Old 04-05-2018, 11:20   #329 (permalink)
Member: 399781
Thanks Meter: 94
g950u tmb frp
flash g950u combi, after phone on go to settings- enable oem- factory reset -
check download mode frp -off
Old 04-05-2018, 11:20   #330 (permalink)
Member: 399781
Thanks Meter: 94
g950u tmb frp done
Page generated in 0.28504 seconds with 9 queries
